GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
28b7a239
28b7a239
Guillaume Melquiond
Merge branch 'bugfix/v0.87'
parents
6825c8fc
fdc992a8
3
Makefile.in
28b7a239
@@ -1032,7 +1032,7 @@ COQVD = $(addsuffix .vd, $(COQLIBS_FILES))
$(SHOW)
'Coqdep $<'
$(HIDE)$(COQDEP)
-R
lib/coq Why3
$(TOTARGET)
all
$(COQVO)
drivers/coq-realizations.aux
all
$(COQVO)
ifneq
"$(MAKECMDGOALS:clean%=clean)" "clean"
ifneq
"$(MAKECMDGOALS:update-coq%=update-coq)" "update-coq"
@@ -1055,6 +1055,8 @@ drivers/coq-realizations.aux: Makefile
endif
all
install_no_local
$(INSTALL_DATA)
$(DATADIR)
/why3/drivers/
src/driver/call_provers.ml
28b7a239
@@ -158,7 +158,7 @@ let print_prover_status fmt = function
Unix
WEXITED
n
fprintf
fmt
"exited with status %d"
n
let
print_steps
fmt
s
if
s
then
fprintf
fmt
", %d steps
s
if
s
then
fprintf
fmt
", %d steps"
s
let
print_prover_result
fmt
pr_answer
ans
pr_status
status
pr_output
out
pr_time
t
theories/floating_point.why
28b7a239
@@ -426,15 +426,15 @@ theory GenFloatSpecFull
is_infinite
x
is_finite
y
is_infinite
r
same_sign
r
x
is_infinite
x
is_infinite
y
same_sign
x
y
is_infinite
r
same_sign
r
x
is_infinite
x
is_infinite
y
diff_sign
x
y
is_NaN
r
is_infinite
x
is_infinite
y
if
same_sign
x
y
then
is_infinite
r
same_sign
r
x
else
is_NaN
r
is_finite
x
is_finite
y
no_overflow
m
value
x
value
y
is_finite
r
value
r
round
m
value
x
value
y
sign_zero_result
m
r
if
same_sign
x
y
then
same_sign
r
x
else
sign_zero_result
m
r
is_finite
x
is_finite
y
not
no_overflow
m
value
x
value
y
SpecialValues
same_sign_real
sign
r
value
x
value
y
@@ -449,15 +449,15 @@ theory GenFloatSpecFull
is_infinite
x
is_finite
y
is_infinite
r
same_sign
r
x
is_infinite
x
is_infinite
y
same_sign
x
y
is_NaN
r
is_infinite
x
is_infinite
y
diff_sign
x
y
is_infinite
r
same_sign
r
x
is_infinite
x
is_infinite
y
if
diff_sign
x
y
then
is_infinite
r
same_sign
r
x
else
is_NaN
r
is_finite
x
is_finite
y
no_overflow
m
value
x
value
y
is_finite
r
value
r
round
m
value
x
value
y
sign_zero_result
m
r
if
diff_sign
x
y
then
same_sign
r
x
else
sign_zero_result
m
r
is_finite
x
is_finite
y
not
no_overflow
m
value
x
value
y
SpecialValues
same_sign_real
sign
r
value
x
value
y
@@ -509,8 +509,8 @@ theory GenFloatSpecFull
is_infinite
r
is_gen_zero
x
is_gen_zero
y
is_NaN
r
product_sign
r
x
y
exact
r
exact
x
exact
y
model
r
model
x
model
y
exact
r
exact
x
exact
y
model
r
model
x
model
y
predicate
of_real_exact_post
x
real
r
t
is_finite
r
value
r
x
exact
r
x
model
r
x
