Commit 283c0c76 authored by Raphael Rieu-Helft's avatar Raphael Rieu-Helft
Add support for C extraction of for loops
parent 2d6e7027
...@@ -37,9 +37,10 @@ module C = struct ...@@ -37,9 +37,10 @@ module C = struct
(* return type, parameter list. Variadic functions not handled. *) (* return type, parameter list. Variadic functions not handled. *)
and proto = ty * (ty * ident) list and proto = ty * (ty * ident) list
and binop = Band | Bor | Beq | Bne | Bassign (* += and co. maybe to add *) and binop = Band | Bor | Beq | Bne | Bassign | Blt | Ble | Bgt | Bge
and unop = Unot | Ustar | Uaddr (* (pre|post)(incr|decr) maybe to add *) and unop = Unot | Ustar | Uaddr | Upreincr | Upostincr | Upredecr | Upostdecr
and expr = and expr =
| Enothing | Enothing
...@@ -416,6 +417,12 @@ module Print = struct ...@@ -416,6 +417,12 @@ module Print = struct
| Unot -> fprintf fmt "!" | Unot -> fprintf fmt "!"
| Ustar -> fprintf fmt "*" | Ustar -> fprintf fmt "*"
| Uaddr -> fprintf fmt "&" | Uaddr -> fprintf fmt "&"
| Upreincr | Upostincr -> fprintf fmt "++"
| Upredecr | Upostdecr -> fprintf fmt "--"
and unop_postfix = function
| Upostincr | Upostdecr -> true
| _ -> false
and print_binop fmt = function and print_binop fmt = function
| Band -> fprintf fmt "&&" | Band -> fprintf fmt "&&"
...@@ -423,11 +430,19 @@ module Print = struct ...@@ -423,11 +430,19 @@ module Print = struct
| Beq -> fprintf fmt "==" | Beq -> fprintf fmt "=="
| Bne -> fprintf fmt "!=" | Bne -> fprintf fmt "!="
| Bassign -> fprintf fmt "=" | Bassign -> fprintf fmt "="
| Blt -> fprintf fmt "<"
| Ble -> fprintf fmt "<="
| Bgt -> fprintf fmt ">"
| Bge -> fprintf fmt ">="
and print_expr ~paren fmt = function and print_expr ~paren fmt = function
| Enothing -> if debug then Format.printf "enothing"; () | Enothing -> if debug then Format.printf "enothing"; ()
| Eunop(u,e) -> fprintf fmt (protect_on paren "%a %a") | Eunop(u,e) ->
print_unop u (print_expr ~paren:true) e if unop_postfix u
then fprintf fmt (protect_on paren "%a%a")
(print_expr ~paren:true) e print_unop u
else fprintf fmt (protect_on paren "%a%a")
| Ebinop(b,e1,e2) -> | Ebinop(b,e1,e2) ->
fprintf fmt (protect_on paren "%a %a %a") fprintf fmt (protect_on paren "%a %a %a")
(print_expr ~paren:true) e1 print_binop b (print_expr ~paren:true) e2 (print_expr ~paren:true) e1 print_binop b (print_expr ~paren:true) e2
...@@ -488,7 +503,12 @@ module Print = struct ...@@ -488,7 +503,12 @@ module Print = struct
(print_stmt ~braces:true) (Sblock([],e)) (print_stmt ~braces:true) (Sblock([],e))
| Swhile (e,b) -> fprintf fmt "while (%a)@;<1 2>%a" | Swhile (e,b) -> fprintf fmt "while (%a)@;<1 2>%a"
(print_expr ~paren:false) e (print_stmt ~braces:true) (Sblock([],b)) (print_expr ~paren:false) e (print_stmt ~braces:true) (Sblock([],b))
| Sfor _ -> raise (Unprinted "for loops") | Sfor (einit, etest, eincr, s) ->
fprintf fmt "for (%a; %a; %a)@;<1 2>%a"
(print_expr ~paren:false) einit
(print_expr ~paren:false) etest
(print_expr ~paren:false) eincr
(print_stmt ~braces:true) (Sblock([],s))
| Sbreak -> fprintf fmt "break;" | Sbreak -> fprintf fmt "break;"
| Sreturn Enothing -> fprintf fmt "return;" | Sreturn Enothing -> fprintf fmt "return;"
| Sreturn e -> fprintf fmt "return %a;" (print_expr ~paren:true) e | Sreturn e -> fprintf fmt "return %a;" (print_expr ~paren:true) e
...@@ -904,7 +924,26 @@ module MLToC = struct ...@@ -904,7 +924,26 @@ module MLToC = struct
expr info {env with computes_return_value = true} r expr info {env with computes_return_value = true} r
| Eraise (_, None) -> assert false (* nothing to pass to return *) | Eraise (_, None) -> assert false (* nothing to pass to return *)
| Eraise _ -> raise (Unsupported "non break/return exception raised") | Eraise _ -> raise (Unsupported "non break/return exception raised")
| Efor _ -> raise (Unsupported "for loops") (*TODO*) | Efor (i, sb, dir, eb, body) ->
begin match i.pv_vs.vs_ty.ty_node with
| Tyapp ({ ts_def = Range _ },_) ->
let ty = ty_of_ty info i.pv_vs.vs_ty in
let di = C.Ddecl(ty, [i.pv_vs.vs_name, Enothing]) in
let ei = C.Evar (i.pv_vs.vs_name) in
let init_e = C.Ebinop (Bassign, ei, C.Evar (sb.pv_vs.vs_name)) in
let incr_op = match dir with To -> C.Upostincr | DownTo -> C.Upostdecr in
let incr_e = C.Eunop (incr_op, ei) in
let test_op = match dir with To -> C.Ble | DownTo -> C.Bge in
let test_e = C.Ebinop (test_op, ei, C.Evar (eb.pv_vs.vs_name)) in
let env' = { env with computes_return_value = false;
in_unguarded_loop = true;
breaks =
if env.in_unguarded_loop
then Sid.empty else env.breaks } in
let bd, bs = expr info env' body in
[di], C.Sfor(init_e, test_e, incr_e, C.Sblock (bd,bs))
| Ematch (({e_node = Eapp(rs,_)} as e1), [Ptuple rets,e2], []) | Ematch (({e_node = Eapp(rs,_)} as e1), [Ptuple rets,e2], [])
when List.for_all when List.for_all
(function | Pwild (*ghost*) | Pvar _ -> true |_-> false) (function | Pwild (*ghost*) | Pvar _ -> true |_-> false)
