Commit 26d05648 authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
new example euler290
parent 4850f8fb
......@@ -10,10 +10,12 @@
In the following, we prove the correctness of a recursive function f
which takes m, a, and b as arguments and returns the number of such n.
Memoization must be added if one wants to solve the initial problem.
in a reasonable amount of time.
(See for instance fib_memo.mlw for an example of memoized function.) *)
module M
module Euler290
use import int.Int
use import ref.Ref
use import int.EuclideanDivision
......@@ -21,68 +23,70 @@ module M
function sum_digits int : int
axiom Sum_digits_def : forall n : int. sum_digits n =
axiom Sum_digits_def: forall n : int. sum_digits n =
if n <= 0 then 0 else sum_digits (div n 10) + mod n 10
(* the number of n st 0 <= n mod 10 < c and sd(n) = sd(137n+a)+b *)
type int3 = (int,int,int)
predicate p (d:int3) (n:int) =
predicate p (d: int3) (n: int) =
let (a,b,c) = d in
0 <= mod n 10 < c /\ sum_digits n = sum_digits (137 * n + a) + b
clone int.NumOfParam as P with type param = int3, predicate pr = p
function solution(a b m : int) : int = P.num_of (a,b,10) 0 (power 10 m)
function solution(a b m: int) : int = P.num_of (a,b,10) 0 (power 10 m)
(* short cut for the number of n st n mod 10 = c and ... *)
function num_of_modc (d:int3) (x y:int) : int =
function num_of_modc (d: int3) (x y: int) : int =
let (a,b,c) = d in
P.num_of (a,b,c+1) x y - P.num_of (a,b,c) x y
(* helper lemmas *)
lemma Base:
forall a b : int. 0 <= a -> sum_digits a + b = 0 -> p (a,b,10) 0
forall a b: int. 0 <= a -> sum_digits a + b = 0 -> p (a,b,10) 0
lemma Empty:
forall a b x y : int. P.num_of (a,b,0) x y = 0
forall a b x y: int. P.num_of (a,b,0) x y = 0
lemma Induc:
forall a b c : int. 0 <= a -> 0 <= c < 10 ->
forall a b c: int. 0 <= a -> 0 <= c < 10 ->
let x = 137 * c + a in
let a' = div x 10 in
let b' = mod x 10 + b - c in
forall m : int. m > 0 ->
forall m: int. m > 0 ->
solution a' b' (m-1) = num_of_modc (a,b,c) 0 (power 10 m)
(* code *)
use import int.ComputerDivision
let rec sd n
requires { n >= 0 } ensures { result = sum_digits n }
let rec sd (n: int) : int
requires { n >= 0 }
variant { n }
= if n = 0 then 0 else sd (div n 10) + mod n 10
(* f(m,a,b) = the number of 0 <= n < 10^m such that
digitsum(137n+a) + b = digitsum(n). *)
let rec f m a b
digitsum(137n + a) + b = digitsum(n). *)
let rec f (m a b: int) : int
requires { 0 <= m /\ 0 <= a }
ensures { result = solution a b m }
variant { m }
= if m = 0 then begin
(* only n = 0 is possible *)
if sd a + b = 0 then 1 else 0
end else begin
let sum = ref 0 in
let c = ref 0 in
while !c <= 9 do (* n = 10n' + c *)
invariant { 0 <= !c <= 10 /\ !sum = P.num_of (a,b,!c) 0 (power 10 m) }
variant { 10 - !c }
let x = 137 * !c + a in
for c = 0 to 9 do (* count the n st n mod 10 = c *)
invariant { !sum = P.num_of (a,b,c) 0 (power 10 m) }
let q = div x 10 in
let r = mod x 10 in
sum := !sum + f (m-1) q (r + b - !c);
c := !c + 1
sum := !sum + f (m-1) q (r + b - c)
done;
!sum
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE why3session PUBLIC "-//Why3//proof session v2//EN" "http://why3.lri.fr/why3session.dtd">
<why3session shape_version="4">
<prover
id="0"
name="Alt-Ergo"
version="0.95.2"/>
<prover
id="1"
name="CVC3"
version="2.4.1"/>
<file
name="../euler290.mlw"
verified="false"
expanded="true">
<theory
name="Euler290"
locfile="../euler290.mlw"
loclnum="17" loccnumb="7" loccnume="15"
verified="false"
expanded="true">
<goal
name="Base"
loclnum="49" loccnumb="8" loccnume="12"
sum="a800be5522f47c3fbb0d82c9e60e4aa0"
proved="true"
expanded="false"
shape="apaTuple3V0V1c10c0Iainfix =ainfix +asum_digitsV0V1c0Iainfix &lt;=c0V0F">
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.01"/>
</proof>
</goal>
<goal
name="Empty"
loclnum="52" loccnumb="8" loccnume="13"
sum="ec43ace9c5ab9d4d7394fe6c1c604544"
proved="true"
expanded="false"
shape="ainfix =anum_ofaTuple3V0V1c0V2V3c0F">
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.06"/>
</proof>
</goal>
<goal
name="Induc"
loclnum="55" loccnumb="8" loccnume="13"
sum="cf43691d3fcaec2492b10c5ac20df569"
proved="false"
expanded="true"
shape="ainfix =asolutionV4V5ainfix -V6c1anum_of_modcaTuple3V0V1V2c0apowerc10V6Iainfix &gt;V6c0FLainfix -ainfix +amodV3c10V1V2LadivV3c10Lainfix +ainfix *c137V2V0Iainfix &lt;V2c10Aainfix &lt;=c0V2Iainfix &lt;=c0V0F">
</goal>
<goal
name="WP_parameter sd"
loclnum="67" loccnumb="10" loccnume="12"
expl="VC for sd"
sum="2d339bcd0e2d3a0a64e418be1b8470c6"
proved="true"
expanded="false"
shape="iainfix =ainfix +asum_digitsV1amodV0c10asum_digitsV0Aainfix &gt;=V1c0Aainfix &lt;V1V0Aainfix &lt;=c0V0LadivV0c10ainfix =c0asum_digitsV0ainfix =V0c0Iainfix &gt;=V0c0F">
<label
name="expl:VC for sd"/>
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.22"/>
</proof>
</goal>
<goal
name="WP_parameter f"
loclnum="75" loccnumb="10" loccnume="11"
expl="VC for f"
sum="747029b96bc67621d69f2403c2b42456"
proved="true"
expanded="false"
shape="iainfix =V3asolutionV1V2V0Iainfix =V3anum_ofaTuple3V1V2ainfix +c9c1c0apowerc10V0Aainfix =V8anum_ofaTuple3V1V2ainfix +V4c1c0apowerc10V0Iainfix =V8ainfix +V3asolutionV6ainfix -ainfix +amodV5c10V2V4V7FAainfix &lt;=c0V6Aainfix &lt;=c0V7Aainfix &lt;V7V0Aainfix &lt;=c0V0Lainfix -V0c1LadivV5c10Lainfix +ainfix *c137V4V1Iainfix =V3anum_ofaTuple3V1V2V4c0apowerc10V0Iainfix &lt;=V4c9Aainfix &lt;=c0V4FFAainfix =c0anum_ofaTuple3V1V2c0c0apowerc10V0Iainfix &lt;=c0c9Aainfix =c0asolutionV1V2V0Iainfix &gt;c0c9ainfix =ic0c1ainfix =ainfix +asum_digitsV1V2c0asolutionV1V2V0Aainfix &gt;=V1c0ainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
name="expl:VC for f"/>
<transf
name="split_goal_wp"
proved="true"
expanded="false">
<goal
name="WP_parameter f.1"
expl="1. precondition"
sum="33549ab3d57be34931226ccd0b65225e"
proved="true"
expanded="false"
shape="preconditionainfix &gt;=V1c0Iainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.03"/>
</proof>
</goal>
<goal
name="WP_parameter f.2"
expl="2. postcondition"
sum="7755175ab539038173c1ea75868f2bd8"
proved="true"
expanded="false"
shape="postconditionainfix =ic0c1ainfix =ainfix +asum_digitsV1V2c0asolutionV1V2V0Iainfix &gt;=V1c0Iainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="1.70"/>
</proof>
</goal>
<goal
name="WP_parameter f.3"
expl="3. postcondition"
sum="0e636ef68fb8ecb78a3fc9776fed83e4"
proved="true"
expanded="false"
shape="postconditionainfix =c0asolutionV1V2V0Iainfix &gt;c0c9INainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.02"/>
</proof>
</goal>
<goal
name="WP_parameter f.4"
expl="4. loop invariant init"
sum="d6b312ab912bcac4e24806c370c84aa3"
proved="true"
expanded="false"
shape="loop invariant initainfix =c0anum_ofaTuple3V1V2c0c0apowerc10V0Iainfix &lt;=c0c9INainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
</proof>
</goal>
<goal
name="WP_parameter f.5"
expl="5. variant decrease"
sum="03bcd47b917f7102016280a9d25451f3"
proved="true"
expanded="false"
shape="variant decreaseainfix &lt;V7V0Aainfix &lt;=c0V0Lainfix -V0c1LadivV5c10Lainfix +ainfix *c137V4V1Iainfix =V3anum_ofaTuple3V1V2V4c0apowerc10V0Iainfix &lt;=V4c9Aainfix &lt;=c0V4FFIainfix &lt;=c0c9INainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
</proof>
</goal>
<goal
name="WP_parameter f.6"
expl="6. precondition"
sum="8c4279522a5afd47f25feddb2bf6da50"
proved="true"
expanded="false"
shape="preconditionainfix &lt;=c0V6Aainfix &lt;=c0V7Lainfix -V0c1LadivV5c10Lainfix +ainfix *c137V4V1Iainfix =V3anum_ofaTuple3V1V2V4c0apowerc10V0Iainfix &lt;=V4c9Aainfix &lt;=c0V4FFIainfix &lt;=c0c9INainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
</proof>
</goal>
<goal
name="WP_parameter f.7"
expl="7. loop invariant preservation"
sum="bfa28bd4703499893c6377c9d72f5924"
proved="true"
expanded="false"
shape="loop invariant preservationainfix =V8anum_ofaTuple3V1V2ainfix +V4c1c0apowerc10V0Iainfix =V8ainfix +V3asolutionV6ainfix -ainfix +amodV5c10V2V4V7FIainfix &lt;=c0V6Aainfix &lt;=c0V7Lainfix -V0c1LadivV5c10Lainfix +ainfix *c137V4V1Iainfix =V3anum_ofaTuple3V1V2V4c0apowerc10V0Iainfix &lt;=V4c9Aainfix &lt;=c0V4FFIainfix &lt;=c0c9INainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
<transf
name="inline_goal"
proved="true"
expanded="false">
<goal
name="WP_parameter f.7.1"
expl="1. loop invariant preservation"
sum="140d7d31a2c129f7f00367a760487594"
proved="true"
expanded="false"
shape="loop invariant preservationainfix =V8anum_ofaTuple3V1V2ainfix +V4c1c0apowerc10V0Iainfix =V8ainfix +V3asolutionV6ainfix -ainfix +amodV5c10V2V4V7FIainfix =c0V6Oainfix &lt;c0V6Aainfix =c0V7Oainfix &lt;c0V7Lainfix -V0c1LadivV5c10Lainfix +ainfix *c137V4V1Iainfix =V3anum_ofaTuple3V1V2V4c0apowerc10V0Iainfix =V4c9Oainfix &lt;V4c9Aainfix =c0V4Oainfix &lt;c0V4FFIainfix =c0c9Oainfix &lt;c0c9INainfix =V0c0Iainfix =c0V1Oainfix &lt;c0V1Aainfix =c0V0Oainfix &lt;c0V0F">
<label
<proof
prover="1"
timelimit="60"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="47.04"/>
</proof>
</goal>
</transf>
</goal>
<goal
name="WP_parameter f.8"
expl="8. postcondition"
sum="ca337390e8505769e64d34de5d331c65"
proved="true"
expanded="false"
shape="postconditionainfix =V3asolutionV1V2V0Iainfix =V3anum_ofaTuple3V1V2ainfix +c9c1c0apowerc10V0FIainfix &lt;=c0c9INainfix =V0c0Iainfix &lt;=c0V1Aainfix &lt;=c0V0F">
<label
<proof
prover="0"
timelimit="10"
memlimit="1000"
obsolete="false"
archived="false">
</proof>
</goal>
</transf>
</goal>
</theory>
</file>
</why3session>
