Commit 269c5530 authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
un debut de manuel
parent 83c69bf9
\newtheorem{example}{Example}[chapter]
% common Why title page
\newcommand{\whytitlepage}[4]{%
\begin{titlepage}
\begin{center}
~\vfill
\rule\textwidth{0.1cm}\\[0.5cm]
\begin{Huge}\sffamily
#1 % title
\end{Huge}
\\[1cm]
\begin{Large}\sffamily
#2
\end{Large}
\\[0.1cm]
\rule\textwidth{0.1cm}\\[1cm]
Version #3\\[3cm]
#4
\vfill
\today\\
INRIA Team-Project \emph{Proval} \url{http://proval.lri.fr} \\
INRIA Saclay - \^Ile-de-France \& LRI, CNRS UMR 8623\\
4, rue Jacques Monod, 91893 Orsay cedex, France
\end{center}
\end{titlepage}}
\newcommand{\why}{\textsf{Why}}
\newcommand{\Why}{\why}
\newcommand{\java}{\textsc{Java}\index{Java@\textsf{Java}}}
\newcommand{\Java}{\java}
\newcommand{\krakatoa}{\textsf{Krakatoa}\index{Krakatoa@\textsf{Krakatoa}}}
\newcommand{\Krakatoa}{\krakatoa}
\newcommand{\caduceus}{\textsf{Caduceus}\index{Caduceus@\textsf{Caduceus}}}
\newcommand{\Caduceus}{\caduceus}
\newcommand{\coq}{\textsf{Coq}\index{Coq@\textsf{Coq}}}
\newcommand{\Coq}{\coq}
\newcommand{\pvs}{\textsf{PVS}\index{PVS@\textsf{PVS}}}
\newcommand{\kw}[1]{\ensuremath{\mathsf{#1}}}
% types
\newcommand{\bool}{\kw{bool}}
\newcommand{\unit}{\kw{unit}}
%\newcommand{\tref}[1]{\ensuremath{#1~\kw{ref}}}
\newcommand{\tref}[1]{\ensuremath{#1~\mathsf{ref}}}
\newcommand{\tarray}[2]{\ensuremath{\kw{array}~#1~\kw{of}~#2}}
% constructs
\newcommand{\prepost}[3]{\ensuremath{\{#1\}\,#2\,\{#3\}}}
\newcommand{\result}{\ensuremath{\mathit{result}}}
\newcommand{\void}{\kw{void}}
\newcommand{\access}[1]{\ensuremath{!#1}}
\newcommand{\assign}[2]{\ensuremath{#1~:=~#2}}
\newcommand{\pref}[1]{\ensuremath{\kw{ref}~#1}}
\newcommand{\taccess}[2]{\ensuremath{#1\texttt{[}#2\texttt{]}}}
\newcommand{\tassign}[3]{\ensuremath{#1\texttt{[}#2\texttt{]}~\texttt{:=}~#3}}
\newcommand{\faccess}[2]{\ensuremath{(\mathit{access}~#1~#2)}}
\newcommand{\fupdate}[3]{\ensuremath{(\mathit{update}~#1~#2~#3)}}
%\newcommand{\taccess}[2]{\ensuremath{#1[#2]}}
%\newcommand{\tassign}[3]{\ensuremath{#1[#2]~:=~#3}}
%\newcommand{\faccess}[2]{\ensuremath{(\mathit{access}~#1~#2)}}
%\newcommand{\fupdate}[3]{\ensuremath{(\mathit{update}~#1~#2~#3)}}
% \newcommand{\block}[1]{\ensuremath{\kw{begin}~#1~\kw{end}}}
\newcommand{\seq}[2]{\ensuremath{#1;~#2}}
%\newcommand{\plabel}[2]{\ensuremath{#1:#2}}
\newcommand{\plabel}[2]{\ensuremath{#1\texttt{:}#2}}
\newcommand{\assert}[2]{\ensuremath{\kw{assert}~\{#1\};~#2}}
\newcommand{\while}[4]{\ensuremath{\kw{while}~#1~\kw{do}~\{\kw{invariant}~#2~\kw{variant}~#3\}~#4~\kw{done}}}
\newcommand{\ite}[3]{\ensuremath{\kw{if}~#1~\kw{then}~#2~\kw{else}~#3}}
\newcommand{\fun}[3]{\ensuremath{\kw{fun}~#1:#2\rightarrow#3}}
\newcommand{\app}[2]{\ensuremath{(#1~#2)}}
\newcommand{\rec}[4]{\ensuremath{\kw{rec}~#1:#2~\{\kw{variant}~#3\}=#4}}
\newcommand{\letin}[3]{\ensuremath{\kw{let}~#1=#2~\kw{in}~#3}}
\newcommand{\raisex}[2]{\ensuremath{\kw{raise}~(#1~#2)}}
\newcommand{\exn}[1]{\ensuremath{\kw{Exn}~#1}}
\newcommand{\try}[2]{\ensuremath{\kw{try}~#1~\kw{with}~#2~\kw{end}}}
\newcommand{\coerce}[2]{\ensuremath{(#1:#2)}}
\newcommand{\statement}{\textit{statement}}
\newcommand{\program}{\textit{program}}
\newcommand{\expression}{\textit{expression}}
\newcommand{\predicate}{\textit{predicate}}
% inference rules
\newcommand{\espacev}{\rule{0in}{1em}}
\newcommand{\espacevn}{\rule[-0.4em]{0in}{1em}}
\newcommand{\irule}[2]
{\frac{\espacevn\displaystyle#1}{\espacev\displaystyle#2}}
\newcommand{\typage}[3]{#1 \, \vdash \, #2 : #3}
\newcommand{\iname}[1]{\textsf{#1}}
\newcommand{\emptyef}{\bot}
\newcommand{\wf}[1]{#1~\kw{wf}}
\newcommand{\pur}[1]{#1~\kw{pure}}
\newcommand{\variant}[1]{#1~\kw{variant}}
\newcommand{\wpre}[2]{\ensuremath{\mathit{wp}(#1,#2)}}
\newcommand{\wprx}[3]{\ensuremath{\mathit{wp}(#1,#2,#3)}}
\newcommand{\barre}[1]{\ensuremath{\overline{#1}}}
% backslash keywords
\newcommand{\ttkw}[1]{\texttt{#1}}
\newcommand{\bskw}[1]{\ttkw{\char'134 #1}}
\newcommand{\bkw}[1]{\ttkw{\textbf{#1}}}
\newcommand{\caml}{\textsf{Caml}}
\newcommand{\ergo}{\textsf{Ergo}\index{Ergo@\textsf{Ergo}}}
\newcommand{\yices}{\textsf{Yices}\index{Yices@\textsf{Yices}}}
\newcommand{\harvey}{\textsf{haRVey}\index{haRVey@\textsf{haRVey}}}
\newcommand{\simplify}{\textsf{Simplify}\index{Simplify@\textsf{Simplify}}}
\newcommand{\mizar}{\textsf{Mizar}\index{Mizar@\textsf{Mizar}}}
\newcommand{\hollight}{\textsf{HOL Light}\index{HOL Light@\textsf{HOL Light}}}
\newcommand{\isabelle}{\textsf{Isabelle/HOL}\index{Isabelle/HOL@\textsf{Isabelle/HOL}}}
\newcommand{\holfour}{\textsf{HOL 4}\index{HOL 4@\textsf{HOL 4}}}
\newcommand{\cvclite}{\textsf{CVC Lite}\index{CVC Lite@\textsf{CVC Lite}}}
\newcommand{\cvcthree}{\textsf{CVC 3}\index{CVC 3@\textsf{CVC 3}}}
\newcommand{\zenon}{\textsf{Zenon}\index{Zenon@\textsf{Zenon}}}
\newcommand{\jml}{\textsc{JML}\index{JML@\textsf{JML}}}
\newcommand{\caveat}{\paragraph{Caveat.}}
\newcommand{\caveats}{\paragraph{Caveats.}}
% BNF syntax
\newenvironment{syntax}{\begin{tabular}{lrll}}{\end{tabular}}
\newcommand{\te}[1]{\texttt{#1}}
\newcommand{\nt}[1]{$\langle$\textsl{#1}$\rangle$}
\newcommand{\indexnt}[1]{\index{#1@\textsl{#1}, grammar entry}}
\newcommand{\indextt}[1]{\index{#1@\texttt{#1}}}
\newcommand{\repstar}{$^{\star}$}
\newcommand{\repstarsep}[1]{$^{\star}_#1$}
\newcommand{\repplus}{$^+$}
\newcommand{\repplussep}[1]{$^+_#1$}
\newcommand{\orelse}{$\mid$}
\newcommand{\is}{ & $::=$ &}
\newcommand{\newl}{ \\ & $|$ &}
%%% Local Variables:
%%% mode: latex
%%% TeX-master: "doc"
%%% End:
This diff is collapsed.
