Commit 26729a97 authored by MARCHE Claude's avatar MARCHE Claude
update roadmap and a few details in the doc
parent f51b953d
...@@ -72,6 +72,7 @@ ...@@ -72,6 +72,7 @@
- PRIORITAIRE, JCF, ANDREI - PRIORITAIRE, JCF, ANDREI
* Coq plugin * Coq plugin
** ajout de bases de hint
* Coq output * Coq output
- corriger l'incoherence, comprendre si on veut vraiment accepter - corriger l'incoherence, comprendre si on veut vraiment accepter
...@@ -89,8 +90,9 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990 ...@@ -89,8 +90,9 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990
== New Features to announce == == New Features to announce ==
* Coq Realizations * Coq realizations
* tool why3session with commands latex, html, etc * Coq plugin
* tool why3session, including commands latex, html, stats
* tool why3doc * tool why3doc
* Support for several versions of the same prover * Support for several versions of the same prover
* Improved IDE: * Improved IDE:
...@@ -118,7 +120,7 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990 ...@@ -118,7 +120,7 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990
- standard library online, using why3doc - standard library online, using why3doc
- API doc, produced using ocamldoc, to http://why3.lri.fr/api/ - API doc, produced using ocamldoc, to http://why3.lri.fr/api/
Note: check that URL of API doc is correct in doc/api.tex line 9. Note: check that URL of API doc is correct in doc/api.tex line 9.
- update the main HTML page (where is the sources ?) - update the main HTML page (sources are in why3-papers/www)
- add links to extra resources like - add links to extra resources like
http://why3.lri.fr/jfla-2012/, http://www.lri.fr/~marche/MPRI-2-36-1/, http://why3.lri.fr/jfla-2012/, http://www.lri.fr/~marche/MPRI-2-36-1/,
http://proval.lri.fr/gallery/index.en.html http://proval.lri.fr/gallery/index.en.html
...@@ -126,16 +128,25 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990 ...@@ -126,16 +128,25 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990
* Announce the distrib * Announce the distrib
- What to put in the announcement: see New Features above - What to put in the announcement: see New Features above
* The next commit : add +git to the version in file Version * The next commit : add +git to the version in file Version
* Announce the why3 tactic on Coq Club
== TODOs == == TODOs ==
* Document the Coq plugin and tactic
** option timelimit <n>
** renommer "coq-plugin" en "coq-tactic"
* (JCF, ANDREI) add all examples from the VSTTE 2012 competition * (JCF, ANDREI) add all examples from the VSTTE 2012 competition
* (CLAUDE) Ajouter page provers sur le site web why3
* Documentation * Documentation
- (GUILLAUME) Realisations Coq, comment fait l'utilisateur pour faire ses realisations - (GUILLAUME) Realisations Coq, comment fait l'utilisateur pour faire ses realisations
ne pas oublier de dire que les dependances avec le .why ou .mlw: ne sera pas vérifié ne pas oublier de dire que les dependances avec le .why ou .mlw: ne sera pas vérifié
- (WHO?) revoir documentation du smoke detector - (CLAUDE) revoir documentation du smoke detector
- (WHO?) Documenter l'utilisation de plusieurs version du meme prouveur comme CVC3 et Z3 - Documenter l'utilisation de plusieurs versions du meme prouveur comme CVC3 et Z3
DONE, mais reorganiser la section, lien sur la page web des prouveurs
- (CLAUDE) Documenter les popups qui peuvent apparaitre dans why3ide quand les prouveurs ont changé. Et les mettre au point: - (CLAUDE) Documenter les popups qui peuvent apparaitre dans why3ide quand les prouveurs ont changé. Et les mettre au point:
. Lors d'un replay, le dialogue "replace proof" apparait un nombre important de fois, . Lors d'un replay, le dialogue "replace proof" apparait un nombre important de fois,
il faut absolument pouvoir interrompre, ou donner une reponse qui soit appliquée pour le reste. il faut absolument pouvoir interrompre, ou donner une reponse qui soit appliquée pour le reste.
...@@ -143,13 +154,18 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990 ...@@ -143,13 +154,18 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990
. le dialogue "replace proof" est de toute facon trop large, et les choix possibles sont confus. . le dialogue "replace proof" est de toute facon trop large, et les choix possibles sont confus.
- DONE (ANDREI) ajouter option a why3config pour ajouter association ident-executable - DONE (ANDREI) ajouter option a why3config pour ajouter association ident-executable
mais remplacer le ":" par " " (Arg.Tuple)
- (CLAUDE) meme ordre d'idee: ne pas ecraser "default editor" et "timelimit" - (CLAUDE) meme ordre d'idee: ne pas ecraser "default editor" et "timelimit"
DONE, en fait c'était déjà le cas
- (WHO?) complete api.tex: explain how to build theories, apply - (WHO?) complete api.tex: explain how to build theories, apply
transformations, write new functions on terms (A) transformations, write new functions on terms (A)
- (ANDREI?) complete manpages.tex: section "Drivers of external provers" - (ANDREI?) complete manpages.tex: section "Drivers of external provers"
- (WHO?) make the glossary available - (WHO?) make the glossary available
* permettre d'utiliser emacs/proof general a la place de coqide depuis why3ide
* (CLAUDE) why3session * (CLAUDE) why3session
- deplacer option -bench de why3replayer dans une commande de why3session
- passe sur la documentation ecrite par Francois reecrite par Guillaume - passe sur la documentation ecrite par Francois reecrite par Guillaume
- DONE "why3replayer -latex" remplacé par "why3session latex" - DONE "why3replayer -latex" remplacé par "why3session latex"
- DONE "why3html" remplacé par "why3session html" - DONE "why3html" remplacé par "why3session html"
...@@ -160,7 +176,6 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990 ...@@ -160,7 +176,6 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990
- entree makefile pour produire la bibliotheque standard de Why3 en HTML - entree makefile pour produire la bibliotheque standard de Why3 en HTML
(pour mettre sur le site Web) (pour mettre sur le site Web)
* provers * provers
- DONE (CLAUDE) Ensure that we kill a prover after some time (ressurect %T ? with a - DONE (CLAUDE) Ensure that we kill a prover after some time (ressurect %T ? with a
meaning like twice the value of %t ?), because we cannot be sure they always meaning like twice the value of %t ?), because we cannot be sure they always
Fran\c{c}ois Bobot$^{1,2}$ \\ Fran\c{c}ois Bobot$^{1,2}$ \\
Jean-Christophe Filli\^atre$^{1,2}$ \\ Jean-Christophe Filli\^atre$^{1,2}$ \\
Claude March\'e$^{2,1}$ \\ Claude March\'e$^{2,1}$ \\
Guillaume Melquiond$^{2,1}$\\
Andrei Paskevich$^{1,2}$ Andrei Paskevich$^{1,2}$
\end{tabular} \end{tabular}
\end{Large} \end{Large}
...@@ -224,6 +225,8 @@ are the following. ...@@ -224,6 +225,8 @@ are the following.
\input{realizations.tex} \input{realizations.tex}
% Coq tactic
% \chapter{Complete API documentation} *) % \chapter{Complete API documentation} *)
% \label{chap:apidoc} *) % \label{chap:apidoc} *)
...@@ -8,7 +8,7 @@ Generating the skeleton for a theory is done by passing to \why the ...@@ -8,7 +8,7 @@ Generating the skeleton for a theory is done by passing to \why the
the theories to realize, and the target directory. the theories to realize, and the target directory.
\begin{verbatim} \begin{verbatim}
\why3 --realize -D path/to/drivers/coq-realize.drv why3 --realize -D path/to/drivers/coq-realize.drv
-T env_path.theory_name -o path/to/target/dir/ -T env_path.theory_name -o path/to/target/dir/
\end{verbatim} \end{verbatim}
