Commit 24fc5f16 authored by Léon Gondelman's avatar Léon Gondelman
new example for balance
parent 37162168
......@@ -50,3 +50,67 @@ module Balance
if balls[6] < balls[7] then 6 else 7
module Balance12
use import int.Int
use import array.Array
(* All values in balls[lo..hi[ are equal to [w], apart from balls[lb]
which is of a different weight (lighter or heavier) . *)
predicate spec (balls: array int) (lo hi j: int) (w: int) (b: bool) =
0 <= lo <= j < hi <= length balls &&
(forall i: int. lo <= i < hi -> i <> j -> balls[i] = w) &&
(if b then balls[j] < w else balls[j] > w)
(* j : the index of the different ball,
b : the status (lighter or heavier) of the different ball
False True meaning heavier and True meaining lighter *)
let solve12 (balls: array int) (ghost w j: int) (ghost b: bool) : (int, bool)
requires { spec balls 0 12 j w b }
ensures { result = (j, b) }
if balls[0] + balls[1] + balls[2] + balls[3] =
balls[4] + balls[5] + balls[6] + balls[7]
then
if balls[0] + balls[8] = balls[9] + balls[10]
then
if balls[0] < balls[11]
then (11, False)
else (11, True)
else if balls[0] + balls[8] < balls[9] + balls[10]
then
if balls[9] = balls[10] then (8, True)
else if balls[9] < balls[10] then (10, False) else (9, False)
else
if balls[9] = balls[10] then (8, False)
else if balls[9] < balls[10] then (9, True) else (10, True)
else if balls[0] + balls[1] + balls[2] + balls[3] <
then
if balls[0] + balls[1] + balls[4] = balls[2] + balls[5] + balls[8]
then
if balls[6] = balls[7] then (3, True)
else if balls[6] < balls[7] then (7, False) else (6, False)
else if balls[0] + balls[1] + balls[4] < balls[2] + balls[5] + balls[8]
then
if balls[0] = balls[1] then (5, False)
else if balls[0] < balls[1] then (0, True) else (1, True)
else
if balls[4] = balls[8] then (2, True) else (4, False)
else
then
if balls[6] = balls[7] then (3, False)
else if balls[6] < balls[7] then (6, True) else (7, True)
then
if balls[2] = balls[5] then (4, True )
else if balls[2] < balls[5] then (5, False) else (2, False)
else
if balls[0] = balls[1] then (5, True) else
if balls[0] < balls[1] then (1, False) else (0, False)
\ No newline at end of file
This diff is collapsed.
