GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
24fc5f16
24fc5f16
Léon Gondelman
new example for balance
37162168
2
2 changed files
274 additions
31 deletions
+274
-31
examples/balance.mlw
+64
examples/balance/why3session.xml
+210
-31
24fc5f16
@@ -50,3 +50,67 @@ module Balance
if balls[6] < balls[7] then 6 else 7
module Balance12
use import int.Int
use import array.Array
(* All values in balls[lo..hi[ are equal to [w], apart from balls[lb]
which is of a different weight (lighter or heavier) . *)
predicate spec (balls: array int) (lo hi j: int) (w: int) (b: bool) =
0 <= lo <= j < hi <= length balls &&
(forall i: int. lo <= i < hi -> i <> j -> balls[i] = w) &&
(if b then balls[j] < w else balls[j] > w)
(* j : the index of the different ball,
b : the status (lighter or heavier) of the different ball
False True meaning heavier and True meaining lighter *)
let solve12 (balls: array int) (ghost w j: int) (ghost b: bool) : (int, bool)
requires { spec balls 0 12 j w b }
ensures { result = (j, b) }
if balls[0] + balls[1] + balls[2] + balls[3] =
balls[4] + balls[5] + balls[6] + balls[7]
then
if balls[0] + balls[8] = balls[9] + balls[10]
then
if balls[0] < balls[11]
then (11, False)
else (11, True)
else if balls[0] + balls[8] < balls[9] + balls[10]
then
if balls[9] = balls[10] then (8, True)
else if balls[9] < balls[10] then (10, False) else (9, False)
else
if balls[9] = balls[10] then (8, False)
else if balls[9] < balls[10] then (9, True) else (10, True)
else if balls[0] + balls[1] + balls[2] + balls[3] <
then
if balls[0] + balls[1] + balls[4] = balls[2] + balls[5] + balls[8]
then
if balls[6] = balls[7] then (3, True)
else if balls[6] < balls[7] then (7, False) else (6, False)
else if balls[0] + balls[1] + balls[4] < balls[2] + balls[5] + balls[8]
then
if balls[0] = balls[1] then (5, False)
else if balls[0] < balls[1] then (0, True) else (1, True)
else
if balls[4] = balls[8] then (2, True) else (4, False)
else
then
if balls[6] = balls[7] then (3, False)
else if balls[6] < balls[7] then (6, True) else (7, True)
then
if balls[2] = balls[5] then (4, True )
else if balls[2] < balls[5] then (5, False) else (2, False)
else
if balls[0] = balls[1] then (5, True) else
if balls[0] < balls[1] then (1, False) else (0, False)
\ No newline at end of file
24fc5f16
@@ -5,6 +5,14 @@
id=
"0"
name=
"Alt-Ergo"
version=
"0.95.1"
<prover
id=
"1"
name=
"Alt-Ergo"
version=
"0.95.2"
<prover
id=
"2"
name=
"CVC3"
version=
"2.4.1"
<file
name=
"../balance.mlw"
verified=
"true"
@@ -20,7 +28,7 @@
locfile=
"../balance.mlw"
loclnum=
"30"
loccnumb=
"6"
loccnume=
"12"
expl=
"VC for solve3"
sum=
3ad2ea87083b374f53889b0a9978f4c5
sum=
61ba3368e43fbedfd0d77a85c221861d
proved=
"true"
expanded=
"true"
shape=
"iainfix =iainfix +V2c2ainfix +V2c1ainfix >agetV1V2agetV1V6V3Aainfix <V2V0Aainfix <=c0V2Aainfix <V6V0Aainfix <=c0V6Lainfix +V2c1ainfix =V2V3ainfix <agetV1V2agetV1V5Aainfix <V2V0Aainfix <=c0V2Aainfix <V5V0Aainfix <=c0V5Lainfix +V2c1Iaspecamk arrayV0V1V2ainfix +V2c3V3V4Aainfix <=c0V0F"
@@ -30,17 +38,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.02"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
</goal>
<goal
name=
"WP_parameter solve8"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"VC for solve8"
sum=
d31361585e559e5c179090a88a5ccdeb
sum=
c7e175f18776c2a5fe136fb90574093f
proved=
"true"
expanded=
"true"
shape=
"iiainfix =ic7c6ainfix <agetV1c6agetV1c7V2Aainfix <c6V0Aainfix <=c0c6Aainfix <c7V0Aainfix <=c0c7aspecV4c3ainfix +c3c3V2V3ainfix >ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1Aainfix <c2V0Aainfix <=c0c2Aainfix <c3V0Aainfix <=c0c3Aainfix <c4V0Aainfix <=c0c4Aainfix <c5V0Aainfix <=c0c5aspecV4c0ainfix +c0c3V2V3ainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1Aainfix <c2V0Aainfix <=c0c2Aainfix <c3V0Aainfix <=c0c3Aainfix <c4V0Aainfix <=c0c4Aainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -55,7 +71,7 @@
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"1. index in array bounds"
sum=
b2d40a695281102206c57ffef269a7b
b"
sum=
6a926496ec2fc5fae3feee17218eafa
b"
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -65,17 +81,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.02"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.2"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"2. index in array bounds"
sum=
"9
c6175549bbf28b86d966b903bac4e62
sum=
"9
75c6025bde09cff09e970371f18f543
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -85,6 +109,14 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
"true"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
@@ -95,7 +127,7 @@
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"3. index in array bounds"
sum=
f6912272fe1d882bc93fc208c49f7818
sum=
479606dd06d14fc5f000f81557cd09e9
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -105,6 +137,14 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
"true"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
@@ -115,7 +155,7 @@
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"4. index in array bounds"
sum=
312128fcc4d69b83a16700ff15607aff
sum=
9b1074d5dcdc780843225fac52f28c88
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -125,6 +165,14 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
"true"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
@@ -135,7 +183,7 @@
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"5. index in array bounds"
sum=
c39db593354d8d388a14517730b5a4ae
sum=
ae8999d91cac2dc2f9f0c03bd79676b3
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -145,17 +193,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.03"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.00"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.6"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"6. index in array bounds"
sum=
d48753cf76cd4c110f08b345e58b0577
sum=
58a91047781856be201c8e4623240d88
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -165,6 +221,14 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
"true"
archived=
"false"
<result
status=
"valid"
time=
"0.00"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.00"
@@ -175,7 +239,7 @@
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"7. precondition"
sum=
013f897984932d02e06a771270dc3d1f
sum=
34f24aec5759081fee36b1644c8429a2
proved=
"true"
expanded=
"false"
shape=
"preconditionaspecV4c0ainfix +c0c3V2V3Iainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -185,17 +249,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.03"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.05"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.8"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"8. index in array bounds"
sum=
1ceb9b706381e5de75351694ecf8dbe0
sum=
88e96f60b490680d6c249a30486ace46
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -205,17 +277,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.02"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.9"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"9. index in array bounds"
sum=
b0aa1e8c453fb14a0c496427fe72c261
sum=
ac6ac6f1a460a5f86a3f2adf3ac50014
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -225,17 +305,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.02"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.10"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"10. index in array bounds"
sum=
4d642559ec83039923a2496f4e23c8dd
sum=
09e57bdf69b9d7e778bfcbec3f7b54eb
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -245,17 +333,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.00"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.11"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"11. index in array bounds"
sum=
ccc3323c04090655cab8a1ff7873574b
sum=
38b655ba3c73a177cfbf78b8baa6082a
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -265,17 +361,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.02"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.12"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"12. index in array bounds"
sum=
2408d061a0b1ecd4c87f16d7e41725ae
sum=
6d2c10b66c462a0d9b0f19a794da2a87
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -285,6 +389,14 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
"true"
archived=
"false"
<result
status=
"valid"
time=
"0.02"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.02"
@@ -295,7 +407,7 @@
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"13. index in array bounds"
sum=
690c698a413c66bc1693b12cb66955c7
sum=
b47140fc58b644b4ac9d5b7679aee6f6
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -305,6 +417,14 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
"true"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
@@ -315,7 +435,7 @@
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"14. precondition"
sum=
2620171d7414e045b8365fbe66eb334
8"
sum=
b3b8375d53b28e76a2d3682683a3c89
8"
proved=
"true"
expanded=
"false"
shape=
"preconditionaspecV4c3ainfix +c3c3V2V3Iainfix >ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -325,17 +445,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.04"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.10"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.15"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"15. index in array bounds"
sum=
d9200f7b3d36b8483637f1183b33120
6"
sum=
831d05791c705cdc721163d39eecd41
6"
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c7V0Aainfix <=c0c7INainfix >ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -345,17 +473,25 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.02"
</proof>
</goal>
<goal
name=
"WP_parameter solve8.16"
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"16. index in array bounds"
sum=
2fa7c6a4347a6f7978963a52fc87741f
sum=
a62bd0cff55006d72867d31f0d27a80d
proved=
"true"
expanded=
"false"
shape=
"index in array boundsainfix <c6V0Aainfix <=c0c6Iainfix <c7V0Aainfix <=c0c7INainfix >ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
@@ -365,6 +501,14 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
"true"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.01"
@@ -375,9 +519,9 @@
locfile=
"../balance.mlw"
loclnum=
"39"
loccnumb=
"6"
loccnume=
"12"
expl=
"17. postcondition"
sum=
a3b67d2c6ba952e455a09a5cdfe83011
sum=
2440fb80af7ec657e33026f1e85b604f
proved=
"true"
expanded=
tru
e"
expanded=
fals
e"
shape=
"postconditionainfix =ic7c6ainfix <agetV1c6agetV1c7V2Iainfix <c6V0Aainfix <=c0c6Iainfix <c7V0Aainfix <=c0c7INainfix >ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5INainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c2ainfix +ainfix +agetV1c3agetV1c4agetV1c5Iainfix <c0V0Aainfix <=c0c0Iainfix <c1V0Aainfix <=c0c1Iainfix <c2V0Aainfix <=c0c2Iainfix <c3V0Aainfix <=c0c3Iainfix <c4V0Aainfix <=c0c4Iainfix <c5V0Aainfix <=c0c5IaspecV4c0c8V2V3Aainfix <=c0V0Lamk arrayV0V1F"
<label
name=
"expl:VC for solve8"
@@ -385,13 +529,48 @@
prover=
"0"
timelimit=
"10"
memlimit=
"1000"
obsolete=
fals
e"
obsolete=
tru
e"
archived=
"false"
<result
status=
"valid"
time=
"0.20"
</proof>
<proof
prover=
"1"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.10"
</proof>
</goal>
</transf>
</goal>
</theory>
<theory
name=
"Balance12"
locfile=
"../balance.mlw"
loclnum=
"56"
loccnumb=
"7"
loccnume=
"16"
verified=
"true"
expanded=
"true"
<goal
name=
"WP_parameter solve12"
locfile=
"../balance.mlw"
loclnum=
"71"
loccnumb=
"5"
loccnume=
"12"
expl=
"VC for solve12"
sum=
"a05df0918d7e59201dc1c3ff73fdefe8"
proved=
"true"
expanded=
"false"
shape=
"iiiiiiainfix =V4aFalseAainfix =V3c0ainfix =V4aFalseAainfix =V3c1ainfix <agetV1c0agetV1c1Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1ainfix =aTrueV4Aainfix =c5V3ainfix =agetV1c0agetV1c1Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1iiainfix =V4aFalseAainfix =V3c2ainfix =V4aFalseAainfix =V3c5ainfix <agetV1c2agetV1c5Aainfix <c2V0Aainfix <=c0c2Aainfix <c5V0Aainfix <=c0c5ainfix =aTrueV4Aainfix =c4V3ainfix =agetV1c2agetV1c5Aainfix <c2V0Aainfix <=c0c2Aainfix <c5V0Aainfix <=c0c5ainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c4ainfix +ainfix +agetV1c2agetV1c5agetV1c8Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1Aainfix <c4V0Aainfix <=c0c4Aainfix <c2V0Aainfix <=c0c2Aainfix <c5V0Aainfix <=c0c5Aainfix <c8V0Aainfix <=c0c8iiainfix =V4aTrueAainfix =V3c7ainfix =V4aTrueAainfix =V3c6ainfix <agetV1c6agetV1c7Aainfix <c6V0Aainfix <=c0c6Aainfix <c7V0Aainfix <=c0c7ainfix =aFalseV4Aainfix =c3V3ainfix =agetV1c6agetV1c7Aainfix <c6V0Aainfix <=c0c6Aainfix <c7V0Aainfix <=c0c7ainfix =ainfix +ainfix +agetV1c0agetV1c1agetV1c4ainfix +ainfix +agetV1c2agetV1c5agetV1c8Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1Aainfix <c4V0Aainfix <=c0c4Aainfix <c2V0Aainfix <=c0c2Aainfix <c5V0Aainfix <=c0c5Aainfix <c8V0Aainfix <=c0c8iiiainfix =V4aFalseAainfix =V3c4ainfix =V4aTrueAainfix =V3c2ainfix =agetV1c4agetV1c8Aainfix <c4V0Aainfix <=c0c4Aainfix <c8V0Aainfix <=c0c8iiainfix =V4aTrueAainfix =V3c1ainfix =V4aTrueAainfix =V3c0ainfix <agetV1c0agetV1c1Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1ainfix =aFalseV4Aainfix =c5V3ainfix =agetV1c0agetV1c1Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1ainfix <ainfix +ainfix +agetV1c0agetV1c1agetV1c4ainfix +ainfix +agetV1c2agetV1c5agetV1c8Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1Aainfix <c4V0Aainfix <=c0c4Aainfix <c2V0Aainfix <=c0c2Aainfix <c5V0Aainfix <=c0c5Aainfix <c8V0Aainfix <=c0c8iiainfix =V4aFalseAainfix =V3c6ainfix =V4aFalseAainfix =V3c7ainfix <agetV1c6agetV1c7Aainfix <c6V0Aainfix <=c0c6Aainfix <c7V0Aainfix <=c0c7ainfix =aTrueV4Aainfix =c3V3ainfix =agetV1c6agetV1c7Aainfix <c6V0Aainfix <=c0c6Aainfix <c7V0Aainfix <=c0c7ainfix =ainfix +ainfix +agetV1c0agetV1c1agetV1c4ainfix +ainfix +agetV1c2agetV1c5agetV1c8Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1Aainfix <c4V0Aainfix <=c0c4Aainfix <c2V0Aainfix <=c0c2Aainfix <c5V0Aainfix <=c0c5Aainfix <c8V0Aainfix <=c0c8ainfix <ainfix +ainfix +ainfix +agetV1c0agetV1c1agetV1c2agetV1c3ainfix +ainfix +ainfix +agetV1c4agetV1c5agetV1c6agetV1c7Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1Aainfix <c2V0Aainfix <=c0c2Aainfix <c3V0Aainfix <=c0c3Aainfix <c4V0Aainfix <=c0c4Aainfix <c5V0Aainfix <=c0c5Aainfix <c6V0Aainfix <=c0c6Aainfix <c7V0Aainfix <=c0c7iiiiainfix =V4aTrueAainfix =V3c10ainfix =V4aTrueAainfix =V3c9ainfix <agetV1c9agetV1c10Aainfix <c9V0Aainfix <=c0c9Aainfix <c10V0Aainfix <=c0c10ainfix =aFalseV4Aainfix =c8V3ainfix =agetV1c9agetV1c10Aainfix <c9V0Aainfix <=c0c9Aainfix <c10V0Aainfix <=c0c10iiainfix =V4aFalseAainfix =V3c9ainfix =V4aFalseAainfix =V3c10ainfix <agetV1c9agetV1c10Aainfix <c9V0Aainfix <=c0c9Aainfix <c10V0Aainfix <=c0c10ainfix =aTrueV4Aainfix =c8V3ainfix =agetV1c9agetV1c10Aainfix <c9V0Aainfix <=c0c9Aainfix <c10V0Aainfix <=c0c10ainfix <ainfix +agetV1c0agetV1c8ainfix +agetV1c9agetV1c10Aainfix <c0V0Aainfix <=c0c0Aainfix <c8V0Aainfix <=c0c8Aainfix <c9V0Aainfix <=c0c9Aainfix <c10V0Aainfix <=c0c10iainfix =V4aTrueAainfix =V3c11ainfix =V4aFalseAainfix =V3c11ainfix <agetV1c0agetV1c11Aainfix <c0V0Aainfix <=c0c0Aainfix <c11V0Aainfix <=c0c11ainfix =ainfix +agetV1c0agetV1c8ainfix +agetV1c9agetV1c10Aainfix <c0V0Aainfix <=c0c0Aainfix <c8V0Aainfix <=c0c8Aainfix <c9V0Aainfix <=c0c9Aainfix <c10V0Aainfix <=c0c10ainfix =ainfix +ainfix +ainfix +agetV1c0agetV1c1agetV1c2agetV1c3ainfix +ainfix +ainfix +agetV1c4agetV1c5agetV1c6agetV1c7Aainfix <c0V0Aainfix <=c0c0Aainfix <c1V0Aainfix <=c0c1Aainfix <c2V0Aainfix <=c0c2Aainfix <c3V0Aainfix <=c0c3Aainfix <c4V0Aainfix <=c0c4Aainfix <c5V0Aainfix <=c0c5Aainfix <c6V0Aainfix <=c0c6Aainfix <c7V0Aainfix <=c0c7Iaspecamk arrayV0V1c0c12V3V2V4Aainfix <=c0V0F"
<label
name=
"expl:VC for solve12"
<proof
prover=
"2"
timelimit=
"5"
memlimit=
"1000"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"1.10"
</proof>
</goal>
</theory>
</file>
</why3session>
