Commit 24586c78 authored by Claude Marche's avatar Claude Marche
Playing with Coq realizations of polymorphic types
parent 15dac784
(* This file is generated by Why3's Coq driver *)
(* Beware! Only edit allowed sections below *)
Require Import BuiltIn.
Require BuiltIn.
Require int.Int.
(* Why3 assumption *)
Inductive list (a:Type) {a_WT:WhyType a} :=
| Nil : list a
| Cons : a -> (list a) -> list a.
Axiom list_WhyType : forall (a:Type) {a_WT:WhyType a}, WhyType (list a).
Existing Instance list_WhyType.
Implicit Arguments Nil [[a] [a_WT]].
Implicit Arguments Cons [[a] [a_WT]].
Fixpoint length {a:Type} {a_WT:WhyType a}(l:(list a)) {struct l}: Z :=
match l with
| Nil => 0%Z
| (Cons _ r) => (1%Z + (length r))%Z
end.
(* Why3 goal *)
Lemma Length_nonnegative : forall {a:Type} {a_WT:WhyType a}, forall (l:(list
a)), (0%Z <= (length l))%Z.
intros a a_WT l.
Qed.
(* Why3 goal *)
Lemma Length_nil : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a)),
((length l) = 0%Z) <-> (l = (Nil :(list a))).
intros a a_WT l.
Qed.
Require BuiltIn.
| Nil : list a
