GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
22d325ab
22d325ab
MARCHE Claude
new headers
9ea5cab3
164
Makefile.in
22d325ab
# Copyright (C) 2010- #
# Fran
c
ois Bobot
# Fran
ç
ois Bobot #
# Jean-Christophe Filli
a
tre
â
tre #
Johannes Kanig
Claude Marché
# Andrei Paskevich #
# This software is free software; you can redistribute it and/or #
bench/plugins/helloworld.ml
22d325ab
(* Copyright (C) 2010- *)
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
(* Jean-Christophe Filli
a
tre
â
tre *)
Johannes Kanig
Claude Marché
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
configure.in
22d325ab
# Fran
c
ois Bobot
# Fran
ç
ois Bobot #
a
tre
â
tre #
Johannes Kanig
Claude Marché
examples/plugins/genequlin.ml
22d325ab
(* François Bobot *)
(* Jean-Christophe Filliâtre *)
(* Claude Marché *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
examples/use_api.ml
22d325ab
(* Claude Marché *)
This
file
builds
some
goals
using
the
API
calls
This
file
builds
some
goals
using
the
API
calls
the
alt
ergo
prover
to
check
them
the
alt
ergo
prover
to
check
them
misc/headache_config.txt
22d325ab
# Objective Caml source
# no header
| "META.in" -> no
| "stdlib.ml[i]?" -> no
| ".*\\.ml[il4]?" -> frame open:"(*" line:"*" close:"*)"
| ".*\\.ml[il4]?\\.in" -> frame open:"(*" line:"*" close:"*)"
| ".*\\.mly" -> frame open:"/*" line:"*" close:"*/"
# C source
# C source
| ".*\\.c" -> frame open:"/*" line:"*" close:"*/"
# Misc
# Misc
| "configure.in" -> frame open:"#" line:"#" close:"#"
| "Makefile.in" -> frame open:"#" line:"#" close:"#"
| "Makefile" -> frame open:"#" line:"#" close:"#"
| "README" -> frame open:"#" line:"#" close:"#"
| "README.*" -> frame open:"*" line:"*" close:"*"
| "META.in" -> no
misc/header.txt
22d325ab
Copyright (C) 2010
Copyright (C) 2010
Fran
c
ois Bobot
Fran
ç
ois Bobot
a
tre
â
tre
Johannes Kanig
Claude Marché
Andrei Paskevich
Andrei Paskevich
src/bench/bench.ml
22d325ab
(* Claude Marché *)
open
Thread
open
Thread
open
Why
open
Why
open
Env
open
Env
src/bench/bench.mli
22d325ab
(* Claude Marché *)
open
Why
open
Why
open
Env
open
Env
src/bench/whybench.ml
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/config/whyconfig.ml
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/coq-plugin/g_whytac.ml4
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/coq-plugin/whytac.ml
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/core/decl.ml
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/core/decl.mli
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/core/env.ml
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/core/env.mli
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/core/ident.ml
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/core/ident.mli
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
src/core/pattern.ml
22d325ab
(* Fran
c
ois Bobot
(* Fran
ç
ois Bobot *)
a
tre
â
tre *)
Johannes Kanig
Claude Marché
Prev
2
3
4
5
9
Next
Supports
