GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
22cfca3f
22cfca3f
François Bobot
benchrc : A way to describe bench
f4af8ebb
10
10 changed files
282 additions
11 deletions
+282
-11
Makefile.in
Makefile.in
+1
-1
src/bench/bench.ml
src/bench/bench.ml
+3
-2
src/bench/bench.mli
src/bench/bench.mli
+2
-1
src/bench/benchrc.ml
+166
src/bench/benchrc.mli
+68
src/bench/whybench.ml
+1
-2
src/util/rc.mli
src/util/rc.mli
+6
src/util/rc.mll
src/util/rc.mll
+17
-5
src/util/util.ml
src/util/util.ml
+13
src/util/util.mli
src/util/util.mli
+5
Makefile.in
22cfca3f
@@ -455,7 +455,7 @@ endif
# BENCH
BENCH_FILES
bench whybench
BENCH_FILES
bench whybench
benchrc
BENCHMODULES
addprefix
src/bench/,
$(BENCH_FILES)
src/bench/bench.ml
22cfca3f
@@ -40,7 +40,7 @@ type 'a tool = {
type
a
prob
ptask
env
task
a
task
list
(** needed for tenv *)
ptrans
task
list
trans
ptrans
env
task
list
trans
type
a
b
result
tool
a
@@ -103,7 +103,8 @@ let call s callback tool prob =
(** Apply trans *)
let
iter_task
pval
task
MTask
start
s
let
trans
Trans
compose_l
prob
ptrans
Trans
singleton
tool
ttrans
in
let
trans
Trans
compose_l
prob
ptrans
tool
tenv
Trans
singleton
tool
ttrans
in
apply_transformation_l
callback
trans_cb
pval
trans
task
in
(** Split *)
let
ths
prob
ptask
tool
tenv
tool
tuse
in
src/bench/bench.mli
22cfca3f
@@ -40,7 +40,8 @@ type 'a tool = {
type
a
prob
ptask
env
task
a
task
list
(** needed for tenv and tuse *)
ptrans
task
list
trans
ptrans
env
task
list
trans
(** perhaps should be merged in
ptask *)
22cfca3f
(* Copyright (C) 2010- *)
(* Francois Bobot *)
(* Jean-Christophe Filliatre *)
(* Johannes Kanig *)
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
open
Format
open
Bench
open
Why
open
Util
open
Theory
type
output
(** on stdout *)
Average
Timeline
(** In a file *)
Csv
type
bench
(* tool_name, prover_name *)
btools
string
string
tool
list
(* prob_name, file_name, theory name *)
bprobs
string
string
string
prob
list
boutputs
output
list
type
benchrc
tools
string
string
tool
list
Mstr
t
probs
string
string
string
prob
Mstr
t
benchs
bench
Mstr
t
open
Whyconf
open
Rc
let
read_tools
wc
map
name
section
(* loadpath *)
let
wc_main
get_main
wc
in
let
loadpath
get_stringl
default
section
"loadpath"
in
let
loadpath
append
loadpath
Whyconf
loadpath
wc_main
in
(* limit *)
let
timelimit
get_int
default
timelimit
wc_main
section
"timelimit"
in
let
memlimit
get_int
default
memlimit
wc_main
section
"memlimit"
in
(* env *)
let
env
Env
create_env
Lexer
retrieve
loadpath
in
(* transformations *)
let
transforms
get_stringl
default
section
"transform"
in
let
lookup
acc
t
Trans
compose
Trans
lookup_transform
t
env
acc
in
let
transforms
fold_left
lookup
Trans
identity
transforms
in
(* use *)
let
use
get_stringl
default
section
"use"
in
let
load_use
task
s
let
file
th
match
Util
split_string_rev
s
_
eprintf
"Bad theory qualifier %s"
s
exit
a
l
rev
l
a
in
let
th
Env
find_theory
env
file
th
in
Task
use_export
task
th
in
let
use
fold_left
load_use
None
use
in
(* provers *)
let
provers
get_stringl
default
section
"prover"
in
let
find_provers
s
try
let
p
Mstr
find
s
get_provers
wc
in
s
p
driver
p
command
(* TODO add exceptions pehaps inside rc.ml in fact*)
Not_found
eprintf
"Prover %s not found.@."
s
exit
in
let
provers
map
find_provers
provers
in
let
provers
try
let
driver
get_string
section
"driver"
in
let
command
get_string
section
"command"
in
"driver"
driver
command
provers
MissingField
_
provers
in
let
load_driver
n
d
c
n
Driver
load_driver
env
d
c
in
let
provers
map
load_driver
provers
in
let
create_tool
n
driver
command
tval
name
n
ttrans
transforms
tdriver
driver
tcommand
command
tenv
env
tuse
use
ttime
timelimit
tmem
memlimit
in
Mstr
add
name
map
create_tool
provers
map
let
read_probs
map
name
section
let
transforms
get_stringl
default
section
"transform"
in
let
gen_trans
env
let
lookup
acc
t
Trans
compose_l
try
Trans
singleton
Trans
lookup_transform
t
env
Trans
UnknownTrans
_
Trans
lookup_transform_l
t
env
acc
in
let
transforms
fold_left
lookup
Trans
identity_l
transforms
in
transforms
in
(* format *)
let
format
get_stringo
section
"format"
in
(* files *)
let
files
get_stringl
default
section
"file"
in
let
gen
env
task
let
fwhy
let
read_one
fname
let
cin
open_in
fname
in
let
m
Env
read_channel
format
format
env
fname
cin
in
close_in
cin
let
ths
Mnm
bindings
m
in
rev_map
fun
n
th
name
fname
n
th
ths
in
let
map
name
th
name
Task
split_theory
th
None
task
in
let
fold
acc
n
l
rev_append
rev_map
fun
v
n
v
l
acc
in
files
map
read_one
list_flatten_rev
rev_map
map
fold_left
fold
in
Scheduler
do_why_sync
fwhy
in
Mstr
add
name
ptask
gen
ptrans
gen_trans
map
let
read_bench
mtools
mprobs
map
name
section
let
tools
get_stringl
section
"tools"
in
let
lookup
s
try
Mstr
find
s
mtools
Not_found
eprintf
"Undefined tools %s@."
s
exit
in
let
tools
list_flatten_rev
map
lookup
tools
in
let
probs
get_stringl
section
"probs"
in
let
lookup
s
try
Mstr
find
s
mprobs
Not_found
eprintf
"Undefined probs %s@."
s
exit
in
let
probs
map
lookup
probs
in
let
outputs
get_stringl
default
section
"probs"
in
let
check
function
"average"
Average
"timeline"
Timeline
"csv"
Csv
s
eprintf
"Unknown output %s"
s
exit
in
let
outputs
map
check
outputs
in
Mstr
add
name
btools
tools
bprobs
probs
boutputs
outputs
map
let
read_file
wc
f
let
rc
from_file
f
in
let
tools
get_family
rc
"tools"
in
let
tools
fold_left
read_tools
wc
Mstr
empty
tools
in
let
probs
get_family
rc
"probs"
in
let
probs
fold_left
read_probs
Mstr
empty
probs
in
let
benchs
get_family
rc
"bench"
in
let
benchs
fold_left
read_bench
tools
probs
Mstr
empty
benchs
in
tools
tools
probs
probs
benchs
benchs
22cfca3f
[probs "myprobs"]
file = "examples/monbut.why" #relatives to the rc file
file = "examples/monprogram.mlw"
theory = "monprogram.T"
goal = "monbut.T.G"
transform = "split_goal" #applied in the order
transform = "..."
transform = "..."
[tools "mytools"]
prover = cvc3
prover = altergo
#or only one
driver = "..."
command = "..."
loadpath = "..." #added to the one in why.conf
loadpath = "..."
timelimit = 30
memlimit = 300
use = "toto.T" #use the theory toto (allow to add metas)
transform = "simplify_array" #only 1 to 1
[bench "mybench"]
tools = "mytools"
tools = ...
probs = "myprobs"
probs = ...
output = "csv"
output = "average"
output = "timeline"
open
Bench
open
Why
open
Util
type
output
(** on stdout *)
Average
Timeline
(** In a file *)
Csv
type
bench
btools
string
string
tool
list
bprobs
string
string
string
prob
list
boutputs
output
list
type
benchrc
tools
string
string
tool
list
Mstr
t
probs
string
string
string
prob
Mstr
t
benchs
bench
Mstr
t
val
read_file
Whyconf
config
string
benchrc
22cfca3f
@@ -331,9 +331,8 @@ let () =
(* let memo = Trans.store (fun task -> gen env task) in *)
(* Trans.apply memo) in *)
let
gen
_
_
tlist
in
let
gen
env
task
Scheduler
do_why_sync
gen
env
task
in
B
ptask
gen
ptrans
transl
ptrans
fun
_
transl
acc
in
probs
Queue
fold
fold_prob
opt_queue
src/util/rc.mli
22cfca3f
@@ -104,6 +104,8 @@ val get_int : ?default:int -> section -> string -> int
@raise Multiple_value if the key appears multiple time.
val
get_into
section
string
int
option
val
get_intl
default
int
list
section
string
int
list
(** [get_intl ~default section key] one key to many value
@@ -131,6 +133,8 @@ val get_bool : ?default:bool -> section -> string -> bool
val
get_booll
default
bool
list
section
string
bool
list
(** Same as {!get_intl} but on bool *)
val
get_boolo
section
string
bool
option
val
set_bool
section
string
bool
section
(** Same as {!set_int} but on bool *)
@@ -144,6 +148,8 @@ val get_string : ?default:string -> section -> string -> string
val
get_stringl
default
string
list
section
string
string
list
(** Same as {!get_intl} but on string *)
val
get_stringo
section
string
string
option
val
set_string
section
string
string
section
(** Same as {!set_int} but on string *)
src/util/rc.mll
22cfca3f
@@ -148,18 +148,26 @@ let set_family t sname sections =
let
set
arg
section
Some
arg
section
in
Mstr
add
sname
map
set
sections
t
let
get_value
read
section
key
let
l
Mstr
find
key
section
in
match
l
assert
false
v
read
key
v
v1
v2
::_
raise
DuplicateField
key
v1
v2
let
get_value
read
default
section
key
try
let
l
Mstr
find
key
section
in
match
l
assert
false
v
read
key
v
v1
v2
::_
raise
DuplicateField
key
v1
v2
get_value
read
section
key
Not_found
match
default
None
raise
MissingField
key
Some
v
v
let
get_valueo
read
section
key
try
Some
get_value
read
section
key
Not_found
None
let
get_valuel
read
default
section
key
try
let
l
Mstr
find
key
section
in
@@ -196,16 +204,20 @@ let wstring s = RCstring s
let
get_int
get_value
rint
let
get_intl
get_valuel
rint
let
get_into
get_valueo
rint
let
set_int
set_value
wint
let
set_intl
set_valuel
wint
let
get_bool
get_value
rbool
let
get_booll
get_valuel
rbool
let
get_boolo
get_valueo
rbool
let
set_bool
set_value
wbool
let
set_booll
set_valuel
wbool
let
get_string
get_value
rstring
let
get_stringl
get_valuel
rstring
let
get_stringo
get_valueo
rstring
let
set_string
set_value
wstring
let
set_stringl
set_valuel
wstring
src/util/util.ml
22cfca3f
@@ -118,6 +118,9 @@ let list_compare cmp l1 l2 = match l1,l2 with
a1
l1
a2
l2
let
c
cmp
a1
a2
in
if
c
then
compare
l1
l2
else
c
let
list_flatten_rev
fl
fold_left
fun
acc
l
rev_append
l
acc
fl
(* boolean fold accumulators *)
exception
FoldSkip
@@ -129,6 +132,16 @@ let any_fn pr _ t = pr t && raise FoldSkip
let
ttrue
_
true
let
ffalse
_
false
(* useful function on string *)
let
split_string_rev
s
c
let
rec
aux
acc
i
try
let
j
String
index_from
s
i
c
in
aux
String
sub
s
i
j
i
acc
j
Not_found
String
sub
s
i
String
length
s
i
acc
Invalid_argument
_
acc
in
aux
(* Set and Map on ints and strings *)
module
Int
struct
type
t
int
let
compare
Pervasives
compare
src/util/util.mli
22cfca3f
@@ -89,6 +89,8 @@ val list_fold_product_l :
val
list_compare
a
a
int
a
list
a
list
int
val
list_flatten_rev
a
list
list
a
list
exception
FoldSkip
@@ -105,6 +107,9 @@ val ffalse : 'a -> bool
val
ttrue
a
bool
(** [ttrue] constant function [true] *)
val
split_string_rev
string
char
string
list
module
Mint
Map
S
type
key
int
