GitLab
What's new
10
Support
Community forum
Keyboard shortcuts
Why3
why3
20f53fc1
20f53fc1
BOLDO Sylvie
Committed by
Guillaume Melquiond
Nov 23, 2011
SB and GM: add realization for FP arithmetic
647d63e7
7
7 changed files
759 additions
2 deletions
+759
-2
Makefile.in
Makefile.in
+6
-1
lib/coq/floating_point/Double.v
+146
lib/coq/floating_point/GenFloat.v
+437
lib/coq/floating_point/Rounding.v
+10
lib/coq/floating_point/Single.v
+156
src/printer/coq.ml
src/printer/coq.ml
+3
theories/floating_point.why
+1
-1
Makefile.in
20f53fc1
@@ -845,7 +845,10 @@ COQLIBS_INT = $(addprefix lib/coq/int/, $(COQLIBS_INT_FILES))
COQLIBS_REAL_FILES
Abs FromInt MinMax Real Square
COQLIBS_REAL
addprefix
lib/coq/real/,
$(COQLIBS_REAL_FILES)
COQLIBS_FILES
$(COQLIBS_INT)
$(COQLIBS_REAL)
COQLIBS_FP_FILES
Rounding GenFloat Single Double
COQLIBS_FP
addprefix
lib/coq/floating_point/,
$(COQLIBS_FP_FILES)
COQLIBS_FILES
$(COQLIBS_INT)
$(COQLIBS_REAL)
$(COQLIBS_FP)
COQV
addsuffix
.v,
$(COQLIBS_FILES)
COQVO
addsuffix
.vo,
$(COQLIBS_FILES)
@@ -859,8 +862,10 @@ install_no_local::
mkdir
-p
$(LIBDIR)
/why3/coq
mkdir
-p
$(LIBDIR)
/why3/coq/int
mkdir
-p
$(LIBDIR)
/why3/coq/real
mkdir
-p
$(LIBDIR)
/why3/coq/floating_point
cp
addsuffix
.vo,
$(COQLIBS_INT)
$(LIBDIR)
/why3/coq/int/
cp
addsuffix
.vo,
$(COQLIBS_REAL)
$(LIBDIR)
/why3/coq/real/
cp
addsuffix
.vo,
$(COQLIBS_FP)
$(LIBDIR)
/why3/coq/floating_point/
install_local
$(COQVO)
20f53fc1
This
file
is
generated
Why3
s
Coq
driver
Beware
Only
edit
allowed
sections
below
Require
Import
ZArith
Require
Import
Rbase
Require
Import
Rbasic_fun
Require
int
Int
Require
real
Real
Require
real
Abs
Require
real
FromInt
Require
floating_point
Rounding
Require
Import
floating_point
GenFloat
Definition
double
Type
t
53
1024.
Definition
round
floating_point
Rounding
mode
R
R
round
53
1024.
Definition
round_logic
floating_point
Rounding
mode
R
double
round_logic
53
1024
refl_equal
true
refl_equal
true
Definition
value
double
R
value
53
1024.
Definition
exact
double
R
exact
53
1024.
Definition
model
double
R
model
53
1024.
Definition
round_error
x
double
R
Rabs
value
x
exact
x
R
Definition
total_error
x
double
R
Rabs
value
x
model
x
R
Definition
no_overflow
m
floating_point
Rounding
mode
x
R
Prop
Rabs
round
m
x
9007199254740991
19958403095347198116563727130368385660674512604354575415025472424372118918689640657849579654926357010893424468441924952439724379883935936607391717982848314203200056729510856765175377214443629871826533567445439239933308104551208703888888552684480441575071209068757560416423584952303440099278848
R
R
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Bounded_real_no_overflow
forall
m
floating_point
Rounding
mode
x
R
Rabs
x
9007199254740991
R
R
no_overflow
m
x
YOU
MAY
EDIT
THE
PROOF
BELOW
exact
53
1024
refl_equal
true
refl_equal
true
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_monotonic
forall
m
floating_point
Rounding
mode
x
R
y
R
x
y
R
round
m
x
round
m
y
R
YOU
MAY
EDIT
THE
PROOF
BELOW
now
apply
Round_monotonic
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_idempotent
forall
m1
floating_point
Rounding
mode
m2
floating_point
Rounding
mode
x
R
round
m1
round
m2
x
round
m2
x
YOU
MAY
EDIT
THE
PROOF
BELOW
now
apply
Round_idempotent
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_value
forall
m
floating_point
Rounding
mode
x
double
round
m
value
x
value
x
YOU
MAY
EDIT
THE
PROOF
BELOW
now
apply
Round_value
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Bounded_value
forall
x
double
Rabs
value
x
9007199254740991
R
R
YOU
MAY
EDIT
THE
PROOF
BELOW
now
apply
Bounded_value
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Exact_rounding_for_integers
forall
m
floating_point
Rounding
mode
i
Z
9007199254740992
Z
Z
i
Z
i
9007199254740992
Z
Z
round
m
IZR
i
IZR
i
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
m
i
Hi
now
apply
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_down_le
forall
x
R
round
floating_point
Rounding
Down
x
x
R
YOU
MAY
EDIT
THE
PROOF
BELOW
now
apply
Round_down_le
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_up_ge
forall
x
R
x
round
floating_point
Rounding
Up
x
R
YOU
MAY
EDIT
THE
PROOF
BELOW
now
apply
Round_up_ge
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_down_neg
forall
x
R
round
floating_point
Rounding
Down
x
R
round
floating_point
Rounding
Up
x
R
YOU
MAY
EDIT
THE
PROOF
BELOW
now
apply
Round_down_neg
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_up_neg
forall
x
R
round
floating_point
Rounding
Up
x
R
round
floating_point
Rounding
Down
x
R
YOU
MAY
EDIT
THE
PROOF
BELOW
now
apply
Round_up_neg
Qed
DO
NOT
EDIT
BELOW
20f53fc1
This
file
is
generated
Why3
s
Coq
driver
Beware
Only
edit
allowed
sections
below
Require
Import
ZArith
Require
Import
Rbase
Require
Import
Rbasic_fun
Require
int
Int
Require
real
Real
Require
real
Abs
Require
real
FromInt
Require
floating_point
Rounding
Require
Import
Fcore
Require
Import
Fappli_IEEE
Require
Import
int
Abs
Section
GenFloat
Global
Coercion
B2R_coercion
prec
emax
B2R
prec
emax
Variable
prec
emax
Z
Hypothesis
Hprec
Zlt_bool
prec
true
Hypothesis
Hemax
Zlt_bool
prec
emax
true
Let
emin
3
emax
prec
Z
Let
fexp
FLT_exp
emin
prec
Lemma
Hprec
prec
Z
revert
Hprec
now
case
Zlt_bool_spec
Qed
Lemma
Hemax
prec
emax
Z
revert
Hemax
now
case
Zlt_bool_spec
Qed
Let
binary_round_correct
binary_round_sign_shl_correct
prec
emax
Hprec
Hemax
Record
t
Set
mk_fp
binary
binary_float
prec
emax
value
binary
R
exact
R
model
R
Record
t_strict
Set
mk_fp_strict
datum
t
finite
is_finite
prec
emax
binary
datum
true
Import
Rounding
Definition
rnd_of_mode
m
mode
match
m
NearestTiesToEven
mode_NE
ToZero
mode_ZR
Up
mode_UP
Down
mode_DN
NearestTiesToAway
mode_NA
Definition
r_to_fp
rnd
x
binary_float
prec
emax
let
r
round
radix2
fexp
round_mode
rnd
x
in
let
m
Ztrunc
scaled_mantissa
radix2
fexp
r
in
let
e
canonic_exponent
radix2
fexp
r
in
match
m
Z0
B754_zero
prec
emax
false
Zpos
m
FF2B
_
_
_
proj1
rnd
false
m
e
Zneg
m
FF2B
_
_
_
proj1
rnd
true
m
e
Lemma
is_finite_FF2B
forall
f
H
is_finite
prec
emax
FF2B
prec
emax
f
H
match
f
F754_finite
_
_
_
true
F754_zero
_
true
_
false
Proof
now
intros
Qed
Theorem
r_to_fp_correct
forall
rnd
x
let
r
round
radix2
fexp
round_mode
rnd
x
in
Rabs
r
bpow
radix2
emax
R
is_finite
prec
emax
r_to_fp
rnd
x
true
r_to_fp
rnd
x
r
R
Proof
intros
rnd
x
r
Bx
unfold
r_to_fp
fold
r
assert
Gx
generic_format
radix2
fexp
r
apply
generic_format_round
apply
FLT_exp_correct
exact
Hprec
assert
Hr
Z2R
Ztrunc
scaled_mantissa
radix2
fexp
r
scaled_mantissa
radix2
fexp
r
apply
sym_eq
now
apply
scaled_mantissa_generic
revert
Hr
case_eq
Ztrunc
scaled_mantissa
radix2
fexp
r
intros
_
Hx
repeat
split
apply
Rmult_eq_reg_r
bpow
radix2
canonic_exponent
radix2
fexp
r
now
rewrite
Rmult_0_l
apply
Rgt_not_eq
apply
bpow_gt_0
intros
p
Hp
Hx
case
intros
Hv
unfold
F2R
Fnum
Fexp
cond_Zopp
rewrite
Hx
scaled_mantissa_bpow
rewrite
round_generic
Gx
rewrite
Rlt_bool_true
Bx
intros
H
split
rewrite
is_finite_FF2B
revert
H
assert
r
R
intros
H
rewrite
H
scaled_mantissa_0
in
Hx
now
apply
Z2R_neq
Zpos
p
now
case
now
rewrite
B2R_FF2B
intros
p
Hp
Hx
case
intros
Hv
unfold
F2R
Fnum
Fexp
cond_Zopp
Zopp
rewrite
Hx
rewrite
round_generic
Gx
rewrite
Rlt_bool_true
Bx
intros
H
split
rewrite
is_finite_FF2B
revert
H
assert
r
R
intros
H
rewrite
H
scaled_mantissa_0
in
Hx
now
apply
Z2R_neq
Zneg
p
now
case
now
rewrite
B2R_FF2B
Qed
Theorem
r_to_fp_format
forall
rnd
x
FLT_format
radix2
emin
prec
x
Rabs
x
bpow
radix2
emax
R
r_to_fp
rnd
x
x
R
Proof
intros
rnd
x
Fx
Bx
assert
Gx
generic_format
radix2
fexp
x
apply
FLT_format_generic
apply
Fx
exact
Hprec
pattern
x
at
2
rewrite
round_generic
rnd
round_mode
rnd
Gx
refine
proj2
r_to_fp_correct
_
_
_
now
rewrite
round_generic
Gx
Qed
Definition
r_to_fp_aux
m
mode
r
r1
r2
R
mk_fp
r_to_fp
rnd_of_mode
m
r
r1
r2
Definition
round
floating_point
Rounding
mode
R
R
fun
m
round
radix2
fexp
round_mode
rnd_of_mode
m
Definition
round_logic
floating_point
Rounding
mode
R
t
fun
m
r
r_to_fp_aux
m
r
r
r
Definition
round_error
x
t
R
Rabs
value
x
exact
x
R
Definition
total_error
x
t
R
Rabs
value
x
model
x
R
Definition
max
R
F2R
Float
radix2
Zpower
2
prec
emax
prec
Definition
no_overflow
m
floating_point
Rounding
mode
x
R
Prop
Rabs
round
m
x
max
R
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
forall
m
floating_point
Rounding
mode
x
R
Rabs
x
max
R
no_overflow
m
x
YOU
MAY
EDIT
THE
PROOF
BELOW
Proof
intros
m
x
Hx
apply
Rabs_le
assert
generic_format
radix2
fexp
max
apply
generic_format_canonic_exponent
unfold
canonic_exponent
rewrite
ln_beta_F2R
rewrite
ln_beta_unique
_
_
prec
ring_simplify
prec
emax
prec
Z
unfold
fexp
FLT_exp
rewrite
Zmax_l
apply
Zle_refl
unfold
emin
generalize
Hprec
Hemax
clear
omega
rewrite
Z2R_abs
Zabs_eq
2
Z2R_Zpower
split
apply
Z2R_le
apply
Zlt_succ_le
change
2
prec
Z
Zpred
2
prec
Z
rewrite
Zsucc_pred
apply
lt_Z2R
change
2
Z
radix_val
radix2
rewrite
2
Z2R_Zpower
apply
bpow_lt
apply
Zlt_pred
apply
Zlt_le_weak
exact
Hprec
generalize
Hprec
clear
omega
apply
Z2R_lt
apply
Zlt_pred
apply
Zlt_le_weak
exact
Hprec
generalize
Hprec
clear
omega
apply
Zlt_succ_le
change
2
prec
Z
Zpred
2
prec
Z
rewrite
Zsucc_pred
change
2
Z
radix_val
radix2
apply
Zpower_gt_0
apply
Zlt_le_weak
exact
Hprec
apply
Zgt_not_eq
cut
2
2
prec
Z
clear
omega
change
radix2
radix2
prec
Z
apply
le_Z2R
rewrite
2
Z2R_Zpower
apply
bpow_le
generalize
Hprec
clear
omega
apply
Zlt_le_weak
exact
Hprec
easy
generalize
Rabs_le_inv
_
_
Hx
split
erewrite
round_generic
x
Ropp
max
apply
round_monotone
2
proj1
H0
apply
FLT_exp_correct
exact
Hprec
now
apply
generic_format_opp
rewrite
round_generic
rnd
round_mode
rnd_of_mode
m
H
apply
round_monotone
2
proj2
H0
apply
FLT_exp_correct
exact
Hprec
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_monotonic
forall
m
floating_point
Rounding
mode
x
R
y
R
x
y
R
round
m
x
round
m
y
R
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
m
x
y
Hxy
apply
round_monotone
2
Hxy
apply
FLT_exp_correct
exact
Hprec
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_idempotent
forall
m1
floating_point
Rounding
mode
m2
floating_point
Rounding
mode
x
R
round
m1
round
m2
x
round
m2
x
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
m1
m2
x
apply
round_generic
apply
apply
FLT_exp_correct
exact
Hprec
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_value
forall
m
floating_point
Rounding
mode
x
t
round
m
value
x
value
x
YOU
MAY
EDIT
THE
PROOF
BELOW
Proof
intros
m
x
apply
round_generic
apply
generic_format_B2R
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
This
is
not
an
axiom
this
is
proved
in
flocq
2.0
Axiom
le_pred_lt_bis
forall
beta
radix
fexp
Z
Z
valid_exp
fexp
forall
x
y
R
F
beta
fexp
x
F
beta
fexp
y
y
R
x
y
R
x
pred
beta
fexp
y
R
Lemma
Bounded_value
forall
x
t
Rabs
value
x
max
R
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
x
replace
max
pred
radix2
fexp
bpow
radix2
emax
apply
le_pred_lt_bis
apply
FLT_exp_correct
exact
Hprec
apply
generic_format_abs
apply
generic_format_B2R
apply
generic_format_bpow
unfold
fexp
FLT_exp
emin
clear
zify
generalize
Hprec
Hemax
omega
apply
bpow_gt_0
apply
B2R_lt_emax
unfold
pred
rewrite
ln_beta_bpow
ring_simplify
emax
Z
rewrite
Req_bool_true
2
easy
unfold
fexp
FLT_exp
emin
rewrite
Zmax_l
unfold
max
F2R
simpl
pattern
emax
at
replace
emax
prec
emax
prec
Z
ring
rewrite
bpow_plus
change
2
Z
radix_val
radix2
rewrite
Z2R_minus
Z2R_Zpower
simpl
ring
apply
Zlt_le_weak
exact
Hprec
clear
generalize
Hprec
Hemax
omega
Qed
DO
NOT
EDIT
BELOW
Definition
max_representable_integer
Z
Zpower
2
prec
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
forall
m
floating_point
Rounding
mode
i
Z
Z
i
Z
i
Z
round
m
IZR
i
IZR
i
YOU
MAY
EDIT
THE
PROOF
BELOW
Proof
intros
m
z
Hz
apply
round_generic
assert
Zabs
z
Z
apply
Abs_le
Hz
destruct
Zle_lt_or_eq
_
_
H
as
Bz
Bz
clear
H
Hz
apply
FLT_format_generic
exact
Hprec
exists
Float
radix2
z
unfold
F2R
simpl
split
rewrite
Z2R_IZR
now
rewrite
Rmult_1_r
split
easy
clear
unfold
emin
generalize
Hprec
Hemax
omega
unfold
in
Bz
change
2
Z
radix_val
radix2
in
Bz
destruct
z
as
z
z
unfold
Zabs
in
Bz
apply
generic_format_0
rewrite
Bz
rewrite
Z2R_IZR
Z2R_Zpower
apply
generic_format_bpow
unfold
fexp
FLT_exp
emin
clear
generalize
Hprec
Hemax
zify
omega
apply
Zlt_le_weak
apply
Hprec
change
Zneg
z
Zopp
Zpos
z
rewrite
Bz
Z2R_IZR
Z2R_opp
rewrite
Z2R_Zpower
apply
generic_format_opp
apply
generic_format_bpow
unfold
fexp
FLT_exp
emin
clear
generalize
Hprec
Hemax
zify
omega
apply
Zlt_le_weak
apply
Hprec
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_down_le
forall
x
R
round
floating_point
Rounding
Down
x
x
R
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
x
eapply
round_DN_pt
apply
FLT_exp_correct
exact
Hprec
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_up_ge
forall
x
R
x
round
floating_point
Rounding
Up
x
R
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
x
eapply
round_UP_pt
apply
FLT_exp_correct
exact
Hprec
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Lemma
Round_down_neg
forall
x
R
round
floating_point
Rounding
Down
x
R
round
floating_point
Rounding
Up
x
R
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
x
apply
round_opp
Qed
DO
NOT
EDIT
BELOW
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
