Commit 20ba6edf authored by Andrei Paskevich's avatar Andrei Paskevich
add checks in "clone" and "meta" instructions
parent 99b99b0a
...@@ -355,8 +355,8 @@ list1_comma_subst: ...@@ -355,8 +355,8 @@ list1_comma_subst:
subst: subst:
| NAMESPACE ns EQUAL ns { CSns ($2, $4) } | NAMESPACE ns EQUAL ns { CSns ($2, $4) }
| TYPE qualid EQUAL qualid { CStsym ($2, $4) } | TYPE qualid EQUAL qualid { CStsym ($2, $4) }
| FUNCTION qualid EQUAL qualid { CSlsym ($2, $4) } | FUNCTION qualid EQUAL qualid { CSfsym ($2, $4) }
| PREDICATE qualid EQUAL qualid { CSlsym ($2, $4) } | PREDICATE qualid EQUAL qualid { CSpsym ($2, $4) }
| LEMMA qualid { CSlemma $2 } | LEMMA qualid { CSlemma $2 }
| GOAL qualid { CSgoal $2 } | GOAL qualid { CSgoal $2 }
...@@ -375,8 +375,8 @@ list1_meta_arg_sep_comma: ...@@ -375,8 +375,8 @@ list1_meta_arg_sep_comma:
meta_arg: meta_arg:
| TYPE qualid { PMAts $2 } | TYPE qualid { PMAts $2 }
| FUNCTION qualid { PMAls $2 } | FUNCTION qualid { PMAfs $2 }
| PREDICATE qualid { PMAls $2 } | PREDICATE qualid { PMAps $2 }
| PROP qualid { PMApr $2 } | PROP qualid { PMApr $2 }
| STRING { PMAstr $1 } | STRING { PMAstr $1 }
| INTEGER { PMAint $1 } | INTEGER { PMAint $1 }
...@@ -105,7 +105,8 @@ type use = { ...@@ -105,7 +105,8 @@ type use = {
type clone_subst = type clone_subst =
| CSns of qualid option * qualid option | CSns of qualid option * qualid option
| CStsym of qualid * qualid | CStsym of qualid * qualid
| CSlsym of qualid * qualid | CSfsym of qualid * qualid
| CSpsym of qualid * qualid
| CSlemma of qualid | CSlemma of qualid
| CSgoal of qualid | CSgoal of qualid
...@@ -145,7 +146,8 @@ type prop_kind = ...@@ -145,7 +146,8 @@ type prop_kind =
type metarg = type metarg =
| PMAts of qualid | PMAts of qualid
| PMAls of qualid | PMAfs of qualid
| PMAps of qualid
| PMApr of qualid | PMApr of qualid
| PMAstr of string | PMAstr of string
| PMAint of string | PMAint of string
...@@ -37,6 +37,8 @@ exception TypeArity of qualid * int * int ...@@ -37,6 +37,8 @@ exception TypeArity of qualid * int * int
exception Clash of string exception Clash of string
exception PredicateExpected exception PredicateExpected
exception TermExpected exception TermExpected
exception FSymExpected of lsymbol
exception PSymExpected of lsymbol
exception BadNumberOfArguments of Ident.ident * int * int exception BadNumberOfArguments of Ident.ident * int * int
exception ClashTheory of string exception ClashTheory of string
exception UnboundTheory of qualid exception UnboundTheory of qualid
...@@ -78,6 +80,10 @@ let () = Exn_printer.register (fun fmt e -> match e with ...@@ -78,6 +80,10 @@ let () = Exn_printer.register (fun fmt e -> match e with
fprintf fmt "syntax error: predicate expected" fprintf fmt "syntax error: predicate expected"
| TermExpected -> | TermExpected ->
fprintf fmt "syntax error: term expected" fprintf fmt "syntax error: term expected"
| FSymExpected ls ->
fprintf fmt "%a is not a function symbol" Pretty.print_ls ls
| PSymExpected ls ->
fprintf fmt "%a is not a predicate symbol" Pretty.print_ls ls
| BadNumberOfArguments (s, n, m) -> | BadNumberOfArguments (s, n, m) ->
fprintf fmt "@[Symbol `%s' is applied to %d terms,@ " s.id_string n; fprintf fmt "@[Symbol `%s' is applied to %d terms,@ " s.id_string n;
fprintf fmt "but is expecting %d arguments@]" m fprintf fmt "but is expecting %d arguments@]" m
...@@ -207,6 +213,17 @@ let find_tysymbol q uc = find_tysymbol_ns q (get_namespace uc) ...@@ -207,6 +213,17 @@ let find_tysymbol q uc = find_tysymbol_ns q (get_namespace uc)
let find_lsymbol_ns = find_ns ns_find_ls let find_lsymbol_ns = find_ns ns_find_ls
let find_lsymbol q uc = find_lsymbol_ns q (get_namespace uc) let find_lsymbol q uc = find_lsymbol_ns q (get_namespace uc)
let find_fsymbol_ns q ns =
let ls = find_lsymbol_ns q ns in
if ls.ls_value = None then error ~loc:(qloc q) (FSymExpected ls) else ls
let find_psymbol_ns q ns =
if ls.ls_value <> None then error ~loc:(qloc q) (PSymExpected ls) else ls
let find_fsymbol q uc = find_fsymbol_ns q (get_namespace uc)
let find_psymbol q uc = find_psymbol_ns q (get_namespace uc)
let find_namespace_ns = find_ns ns_find_ns let find_namespace_ns = find_ns ns_find_ns
let find_namespace q uc = find_namespace_ns q (get_namespace uc) let find_namespace q uc = find_namespace_ns q (get_namespace uc)
...@@ -1119,9 +1136,15 @@ let add_decl env lenv th = function ...@@ -1119,9 +1136,15 @@ let add_decl env lenv th = function
if Mts.mem ts1 s.inst_ts if Mts.mem ts1 s.inst_ts
then error ~loc (Clash ts1.ts_name.id_string); then error ~loc (Clash ts1.ts_name.id_string);
{ s with inst_ts = Mts.add ts1 ts2 s.inst_ts } { s with inst_ts = Mts.add ts1 ts2 s.inst_ts }
| CSlsym (p,q) -> | CSfsym (p,q) ->
let ls1 = find_lsymbol_ns p t.th_export in let ls1 = find_fsymbol_ns p t.th_export in
let ls2 = find_lsymbol q th in let ls2 = find_fsymbol q th in
if Mls.mem ls1 s.inst_ls
then error ~loc (Clash ls1.ls_name.id_string);
{ s with inst_ls = Mls.add ls1 ls2 s.inst_ls }
| CSpsym (p,q) ->
let ls1 = find_psymbol_ns p t.th_export in
let ls2 = find_psymbol q th in
if Mls.mem ls1 s.inst_ls if Mls.mem ls1 s.inst_ls
then error ~loc (Clash ls1.ls_name.id_string); then error ~loc (Clash ls1.ls_name.id_string);
{ s with inst_ls = Mls.add ls1 ls2 s.inst_ls } { s with inst_ls = Mls.add ls1 ls2 s.inst_ls }
...@@ -1163,7 +1186,8 @@ let add_decl env lenv th = function ...@@ -1163,7 +1186,8 @@ let add_decl env lenv th = function
let s = id.id in let s = id.id in
let convert = function let convert = function
| PMAts q -> MAts (find_tysymbol q th) | PMAts q -> MAts (find_tysymbol q th)
| PMAls q -> MAls (find_lsymbol q th) | PMAfs q -> MAls (find_fsymbol q th)
| PMAps q -> MAls (find_psymbol q th)
| PMApr q -> MApr (find_prop q th) | PMApr q -> MApr (find_prop q th)
| PMAstr s -> MAstr s | PMAstr s -> MAstr s
| PMAint i -> MAint (int_of_string i) | PMAint i -> MAint (int_of_string i)
