Commit 203733cd authored by MARCHE Claude's avatar MARCHE Claude
Jessie3: !x in contracts
parent dd556464
...@@ -105,6 +105,9 @@ let ref_fun : Mlw_expr.psymbol = ...@@ -105,6 +105,9 @@ let ref_fun : Mlw_expr.psymbol =
| Mlw_module.PS p -> p | Mlw_module.PS p -> p
| _ -> assert false | _ -> assert false
let get_logic_fun : Term.lsymbol =
find ref_module.Mlw_module.mod_theory "prefix !"
let get_fun : Mlw_expr.psymbol = let get_fun : Mlw_expr.psymbol =
match match
Mlw_module.ns_find_ps ref_module.Mlw_module.mod_export ["prefix !"] Mlw_module.ns_find_ps ref_module.Mlw_module.mod_export ["prefix !"]
...@@ -179,6 +182,36 @@ let rec logic_type ty = ...@@ -179,6 +182,36 @@ let rec logic_type ty =
let any _ty =
Mlw_expr.e_const (Number.ConstInt (Number.int_const_dec "0"))
let mk_ref ty =
let pv =
Mlw_ty.create_pvsymbol (Ident.id_fresh "a") (Mlw_ty.vty_value ty)
in
let ity = Mlw_ty.ity_app_fresh ref_type [ty] in
let vta = Mlw_ty.vty_arrow [pv] (Mlw_ty.VTvalue (Mlw_ty.vty_value ity)) in
Mlw_expr.e_arrow ref_fun vta
let mk_get ref_ty ty =
let pv = Mlw_ty.create_pvsymbol (Ident.id_fresh "r") ref_ty in
let vta = Mlw_ty.vty_arrow [pv] (Mlw_ty.VTvalue (Mlw_ty.vty_value ty)) in
Mlw_expr.e_arrow get_fun vta
let mk_set ref_ty ty =
(* (:=) has type (r:ref 'a) (v:'a) unit *)
let pv1 = Mlw_ty.create_pvsymbol (Ident.id_fresh "r") ref_ty in
let pv2 =
Mlw_ty.create_pvsymbol (Ident.id_fresh "v") (Mlw_ty.vty_value ty)
in
let vta =
Mlw_ty.vty_arrow [pv1;pv2]
(Mlw_ty.VTvalue (Mlw_ty.vty_value Mlw_ty.ity_unit))
in
Mlw_expr.e_arrow set_fun vta
...@@ -247,7 +280,31 @@ let get_lvar lv = ...@@ -247,7 +280,31 @@ let get_lvar lv =
try try
Hashtbl.find bound_vars lv.lv_id Hashtbl.find bound_vars lv.lv_id
with Not_found -> with Not_found ->
Self.fatal "variable %d not found" lv.lv_id Self.fatal "logic variable %s (%d) not found" lv.lv_name lv.lv_id
let program_vars = Hashtbl.create 257
let create_var v =
let id = Ident.id_fresh v.vname in
let ty = ctype v.vtype in
let def = Mlw_expr.e_app (mk_ref ty) [any ty] in
let let_defn = Mlw_expr.create_let_defn id def in
let vs = match let_defn.Mlw_expr.let_sym with
| Mlw_expr.LetV vs -> vs
| Mlw_expr.LetA _ -> assert false
in
Self.result "create program variable %s (%d)" v.vname v.vid;
Hashtbl.add program_vars v.vid (vs,true,ty);
let_defn
let get_var v =
try
Hashtbl.find program_vars v.vid
with Not_found ->
Self.fatal "program variable %s (%d) not found" v.vname v.vid
let logic_symbols = Hashtbl.create 257 let logic_symbols = Hashtbl.create 257
...@@ -274,7 +331,17 @@ let result_vsymbol = ...@@ -274,7 +331,17 @@ let result_vsymbol =
let tlval (host,offset) = let tlval (host,offset) =
match host,offset with match host,offset with
| TResult _, TNoOffset -> Term.t_var !result_vsymbol | TResult _, TNoOffset -> Term.t_var !result_vsymbol
| TVar lv, TNoOffset -> Term.t_var (get_lvar lv) | TVar lv, TNoOffset ->
begin
match lv.lv_origin with
| None -> Term.t_var (get_lvar lv)
| Some v ->
let (v,is_mutable,_ty) = get_var v in
if is_mutable then
t_app get_logic_fun [Term.t_var v.Mlw_ty.pv_vs]
else
| TVar _, (TField (_, _)|TModel (_, _)|TIndex (_, _)) -> | TVar _, (TField (_, _)|TModel (_, _)|TIndex (_, _)) ->
Self.not_yet_implemented "tlval TVar" Self.not_yet_implemented "tlval TVar"
| TResult _, _ -> | TResult _, _ ->
...@@ -282,19 +349,21 @@ let tlval (host,offset) = ...@@ -282,19 +349,21 @@ let tlval (host,offset) =
| TMem _, _ -> | TMem _, _ ->
Self.not_yet_implemented "tlval Mem" Self.not_yet_implemented "tlval Mem"
let rec term_node t = type label = Here | Old | At of string
let rec term_node ~label t =
match t with match t with
| TConst cst -> Term.t_const (logic_constant cst) | TConst cst -> Term.t_const (logic_constant cst)
| TLval lv -> tlval lv | TLval lv -> tlval lv
| TBinOp (op, t1, t2) -> bin (term t1) op (term t2) | TBinOp (op, t1, t2) -> bin (term ~label t1) op (term ~label t2)
| TUnOp (op, t) -> unary op (term t) | TUnOp (op, t) -> unary op (term ~label t)
| TCastE (_, _) -> Self.not_yet_implemented "term_node TCastE" | TCastE (_, _) -> Self.not_yet_implemented "term_node TCastE"
| Tapp (li, labels, args) -> | Tapp (li, labels, args) ->
begin begin
match labels with match labels with
let ls = get_lsymbol li in let ls = get_lsymbol li in
let args = List.map (fun x -> snd(term x)) args in let args = List.map (fun x -> snd(term ~label x)) args in
t_app ls args t_app ls args
| _ -> | _ ->
Self.not_yet_implemented "term_node Tapp with labels" Self.not_yet_implemented "term_node Tapp with labels"
...@@ -302,11 +371,13 @@ let rec term_node t = ...@@ -302,11 +371,13 @@ let rec term_node t =
| Tat (t, lab) -> | Tat (t, lab) ->
begin begin
match lab with match lab with
| LogicLabel(None, "Here") -> snd (term t) | LogicLabel(None, "Here") -> snd (term ~label:Here t)
| LogicLabel(None, "Old") -> | LogicLabel(None, "Old") -> snd (term ~label:Old t)
Self.not_yet_implemented "term_node Tat/Old" | LogicLabel(None, lab) -> snd (term ~label:(At lab) t)
| _ -> | LogicLabel(Some _, _lab) ->
Self.not_yet_implemented "term_node Tat" Self.not_yet_implemented "term_node Tat/LogicLabel/Some"
| StmtLabel _ ->
Self.not_yet_implemented "term_node Tat/StmtLabel"
end end
| TSizeOf _ | TSizeOf _
| TSizeOfE _ | TSizeOfE _
...@@ -335,7 +406,7 @@ let rec term_node t = ...@@ -335,7 +406,7 @@ let rec term_node t =
| Tlet (_, _) -> | Tlet (_, _) ->
Self.not_yet_implemented "term_node" Self.not_yet_implemented "term_node"
and term t = (t.term_type, term_node t.term_node) and term ~label t = (t.term_type, term_node ~label t.term_node)
...@@ -354,18 +425,18 @@ let rel (ty1,t1) op (ty2,t2) = ...@@ -354,18 +425,18 @@ let rel (ty1,t1) op (ty2,t2) =
| (Rlt|Rgt|Rle),_,_ -> | (Rlt|Rgt|Rle),_,_ ->
Self.not_yet_implemented "rel" Self.not_yet_implemented "rel"
let rec predicate p = let rec predicate ~label p =
match p with match p with
| Pfalse -> Term.t_false | Pfalse -> Term.t_false
| Ptrue -> Term.t_true | Ptrue -> Term.t_true
| Prel (op, t1, t2) -> rel (term t1) op (term t2) | Prel (op, t1, t2) -> rel (term ~label t1) op (term ~label t2)
| Pforall (lv, p) -> | Pforall (lv, p) ->
let l = List.map create_lvar lv in let l = List.map create_lvar lv in
Term.t_forall_close l [] (predicate_named p) Term.t_forall_close l [] (predicate_named ~label p)
| Pimplies (p1, p2) -> | Pimplies (p1, p2) ->
Term.t_implies (predicate_named p1) (predicate_named p2) Term.t_implies (predicate_named ~label p1) (predicate_named ~label p2)
| Pand (p1, p2) -> | Pand (p1, p2) ->
Term.t_and (predicate_named p1) (predicate_named p2) Term.t_and (predicate_named ~label p1) (predicate_named ~label p2)
| Papp (_, _, _) | Papp (_, _, _)
| Pseparated _ | Pseparated _
| Por (_, _) | Por (_, _)
...@@ -385,7 +456,7 @@ let rec predicate p = ...@@ -385,7 +456,7 @@ let rec predicate p =
| Psubtype (_, _) -> | Psubtype (_, _) ->
Self.not_yet_implemented "predicate" Self.not_yet_implemented "predicate"
and predicate_named p = predicate p.content and predicate_named ~label p = predicate ~label p.content
...@@ -449,7 +520,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) = ...@@ -449,7 +520,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
Decl.create_param_decl ls Decl.create_param_decl ls
| LBterm d -> | LBterm d ->
let ls,args = create_lsymbol li in let ls,args = create_lsymbol li in
let (_ty,d) = term d in let (_ty,d) = term ~label:Here d in
let def = Decl.make_ls_defn ls args d in let def = Decl.make_ls_defn ls args d in
Decl.create_logic_decl [def] Decl.create_logic_decl [def]
| _ -> | _ ->
...@@ -472,7 +543,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) = ...@@ -472,7 +543,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
in in
Decl.create_prop_decl Decl.create_prop_decl
(if is_axiom then Decl.Paxiom else Decl.Plemma) (if is_axiom then Decl.Paxiom else Decl.Plemma)
pr (predicate_named p) pr (predicate_named ~label:Here p)
in in
(theories,d::decls) (theories,d::decls)
| _ -> | _ ->
...@@ -513,56 +584,6 @@ let identified_proposition p = ...@@ -513,56 +584,6 @@ let identified_proposition p =
(* statements *) (* statements *)
let any _ty =
let mk_ref ty =
let pv =
in
let pv2 =
in
let vta =
in
let create_var v =
in
let_defn
let get_var v =
try
with Not_found ->
let lval (host,offset) = let lval (host,offset) =
...@@ -593,7 +614,7 @@ let seq e1 e2 = ...@@ -593,7 +614,7 @@ let seq e1 e2 =
let annot a e = let annot a e =
match (Annotations.code_annotation_of_rooted a).annot_content with match (Annotations.code_annotation_of_rooted a).annot_content with
| AAssert ([],pred) -> | AAssert ([],pred) ->
let p = predicate_named pred in let p = predicate_named ~label:Here pred in
let a = Mlw_expr.e_assert Mlw_expr.Aassert p in let a = Mlw_expr.e_assert Mlw_expr.Aassert p in
seq a e seq a e
| AAssert(_labels,_pred) -> | AAssert(_labels,_pred) ->
...@@ -848,7 +869,7 @@ let fundecl fdec = ...@@ -848,7 +869,7 @@ let fundecl fdec =
in in
let body = fdec.sbody in let body = fdec.sbody in
let contract = Annotations.funspec kf in let contract = Annotations.funspec kf in
let _pre,post,_ass = extract_simple_contract contract in let pre,post,_ass = extract_simple_contract contract in
let ret_type = ctype (Kernel_function.get_return_type kf) in let ret_type = ctype (Kernel_function.get_return_type kf) in
let result = let result =
Term.create_vsymbol (Ident.id_fresh "result") Term.create_vsymbol (Ident.id_fresh "result")
...@@ -859,8 +880,10 @@ let fundecl fdec = ...@@ -859,8 +880,10 @@ let fundecl fdec =
List.map create_var (Kernel_function.get_locals kf) List.map create_var (Kernel_function.get_locals kf)
in in
let spec = { let spec = {
Mlw_ty.c_pre = Term.t_true; Mlw_ty.c_pre = predicate_named ~label:Here pre;
c_post = Term.t_eps (Term.t_close_bound result (predicate_named post)); c_post =
Term.t_eps
(Term.t_close_bound result (predicate_named ~label:Here post));
c_xpost = Mlw_ty.Mexn.empty; c_xpost = Mlw_ty.Mexn.empty;
c_effect = Mlw_ty.eff_empty; c_effect = Mlw_ty.eff_empty;
c_variant = []; c_variant = [];
...@@ -9,6 +9,17 @@ int f(int x) { ...@@ -9,6 +9,17 @@ int f(int x) {
return x+1; return x+1;
#if 0
int g;
/*@ ensures g == \old(g)+x;
void h(int x) {
g += x;
#endif
Local Variables: Local Variables:
...@@ -2,6 +2,28 @@ ...@@ -2,6 +2,28 @@
[jessie3] user error: WARNING: Variable Frama_C_bzero not translated [jessie3] user error: WARNING: Variable Frama_C_bzero not translated
[jessie3] user error: WARNING: Variable Frama_C_copy_block not translated [jessie3] user error: WARNING: Variable Frama_C_copy_block not translated
[jessie3] processing function f [jessie3] processing function f
[kernel] Plug-in jessie3 aborted: unimplemented feature. [jessie3] found 0 logic decl(s)
You may send a feature request at http://bts.frama-c.com with: [jessie3] made 0 theory(ies)
'[Plug-in jessie3] term_node Tat/Old'. [jessie3] made 1 function(s)
[jessie3] running theory 1:
[jessie3] theory C_Functions
(* use why3.BuiltIn *)
(* use why3.Bool *)
(* use why3.Unit *)
(* use why3.Prelude *)
(* use int.Int *)
(* use real.Real *)
(* use ref.Ref *)
goal WP_parameter_f :
forall x:int.
forall us_retres:int. us_retres = (x + 1) -> us_retres = (x + 1)
[jessie3] Alt-Ergo 0.94, Alt-Ergo 0.95, CVC3 2.2, CVC3 2.4.1, Z3 3.2, Z3 4.2
[jessie3] Task 1: Valid, Valid, Valid, Valid, Valid, Valid
...@@ -5,4 +5,4 @@ ...@@ -5,4 +5,4 @@
[jessie3] processing function isqrt [jessie3] processing function isqrt
[kernel] Plug-in jessie3 aborted: unimplemented feature. [kernel] Plug-in jessie3 aborted: unimplemented feature.
You may send a feature request at http://bts.frama-c.com with: You may send a feature request at http://bts.frama-c.com with:
'[Plug-in jessie3] term_node Tat/Old'. '[Plug-in jessie3] rel'.
...@@ -174,7 +174,14 @@ val e_label_copy : expr -> expr -> expr ...@@ -174,7 +174,14 @@ val e_label_copy : expr -> expr -> expr
val e_value : pvsymbol -> expr val e_value : pvsymbol -> expr
val e_arrow : psymbol -> vty_arrow -> expr val e_arrow : psymbol -> vty_arrow -> expr
(** DOCUMENTATION NEEDED PLEASE *) (** [e_arrow p ty] instantiates the program function symbol [p] into a
program expression having the given value type [ty], instantiating
appropriately the type variables and region variables. The
resulting expression can be applied to arguments using [e_app]
given below.
See also [examples/use_api/use_api.ml]
exception ValueExpected of expr exception ValueExpected of expr
exception ArrowExpected of expr exception ArrowExpected of expr
...@@ -187,6 +194,12 @@ exception GhostRaise of expr * xsymbol ...@@ -187,6 +194,12 @@ exception GhostRaise of expr * xsymbol
(* a ghost expression writes in a non-ghost region or raises an exception *) (* a ghost expression writes in a non-ghost region or raises an exception *)
val e_app : expr -> expr list -> expr val e_app : expr -> expr list -> expr
(** [e_app e el] builds the application of [e] to arguments [el].
[e] is typically constructed using [e_arrow] defined above].
val e_lapp : lsymbol -> expr list -> ity -> expr val e_lapp : lsymbol -> expr list -> ity -> expr
val e_plapp : plsymbol -> expr list -> ity -> expr val e_plapp : plsymbol -> expr list -> ity -> expr
