Commit 1f836cd2 authored by François Bobot's avatar François Bobot
add open stdlib where needed
parent 231fc690
...@@ -112,7 +112,7 @@ LIBGENERATED = src/util/rc.ml src/parser/lexer.ml \ ...@@ -112,7 +112,7 @@ LIBGENERATED = src/util/rc.ml src/parser/lexer.ml \
src/driver/driver_parser.mli src/driver/driver_parser.ml \ src/driver/driver_parser.mli src/driver/driver_parser.ml \
src/driver/driver_lexer.ml src/driver/driver_lexer.ml
LIB_UTIL = exn_printer debug pp loc print_tree \ LIB_UTIL = stdlib exn_printer debug pp loc print_tree \
hashweak hashcons util sysutil rc hashweak hashcons util sysutil rc
LIB_CORE = ident ty term pattern decl theory task pretty env printer trans LIB_CORE = ident ty term pattern decl theory task pretty env printer trans
...@@ -17,6 +17,8 @@ ...@@ -17,6 +17,8 @@
open Stdlib
(** Logic Declarations *) (** Logic Declarations *)
open Ident open Ident
...@@ -17,6 +17,7 @@ ...@@ -17,6 +17,7 @@
open Stdlib
open Util open Util
(** Labels *) (** Labels *)
open Stdlib
(** Identifiers *) (** Identifiers *)
(** {2 Labels} *) (** {2 Labels} *)
open Stdlib
(** Terms and Formulas *) (** Terms and Formulas *)
open Stdlib
(** Theories and Namespaces *) (** Theories and Namespaces *)
open Stdlib
(** Types *) (** Types *)
...@@ -13,6 +13,8 @@ ...@@ -13,6 +13,8 @@
(* $Id: map.ml 10468 2010-05-25 13:29:43Z frisch $ *) (* $Id: map.ml 10468 2010-05-25 13:29:43Z frisch $ *)
module Map = struct
module type OrderedType = module type OrderedType =
sig sig
type t type t
...@@ -29,7 +31,8 @@ module type S = ...@@ -29,7 +31,8 @@ module type S =
val add: key -> 'a -> 'a t -> 'a t val add: key -> 'a -> 'a t -> 'a t
val singleton: key -> 'a -> 'a t val singleton: key -> 'a -> 'a t
val remove: key -> 'a t -> 'a t val remove: key -> 'a t -> 'a t
val merge: (key -> 'a option -> 'b option -> 'c option) -> 'a t -> 'b t -> 'c t val merge: (key -> 'a option -> 'b option -> 'c option)
val compare: ('a -> 'a -> int) -> 'a t -> 'a t -> int val compare: ('a -> 'a -> int) -> 'a t -> 'a t -> int
val equal: ('a -> 'a -> bool) -> 'a t -> 'a t -> bool val equal: ('a -> 'a -> bool) -> 'a t -> 'a t -> bool
val iter: (key -> 'a -> unit) -> 'a t -> unit val iter: (key -> 'a -> unit) -> 'a t -> unit
...@@ -124,23 +127,23 @@ module Make(Ord: OrderedType) = struct ...@@ -124,23 +127,23 @@ module Make(Ord: OrderedType) = struct
let rec mem x = function let rec mem x = function
Empty -> Empty ->
false false
| Node(l, v, d, r, _) -> | Node(l, v, _d, r, _) ->
let c = Ord.compare x v in let c = Ord.compare x v in
c = 0 || mem x (if c < 0 then l else r) c = 0 || mem x (if c < 0 then l else r)
let rec min_binding = function let rec min_binding = function
Empty -> raise Not_found Empty -> raise Not_found
| Node(Empty, x, d, r, _) -> (x, d) | Node(Empty, x, d, _r, _) -> (x, d)
| Node(l, x, d, r, _) -> min_binding l | Node(l, _x, _d, _r, _) -> min_binding l
let rec max_binding = function let rec max_binding = function
| Node(l, x, d, Empty, _) -> (x, d) | Node(_l, x, d, Empty, _) -> (x, d)
| Node(l, x, d, r, _) -> max_binding r | Node(_l, _x, _d, r, _) -> max_binding r
let rec remove_min_binding = function let rec remove_min_binding = function
Empty -> invalid_arg "Map.remove_min_elt" Empty -> invalid_arg "Map.remove_min_elt"
| Node(Empty, x, d, r, _) -> r | Node(Empty, _x, _d, r, _) -> r
| Node(l, x, d, r, _) -> bal (remove_min_binding l) x d r | Node(l, x, d, r, _) -> bal (remove_min_binding l) x d r
let merge t1 t2 = let merge t1 t2 =
...@@ -154,7 +157,7 @@ module Make(Ord: OrderedType) = struct ...@@ -154,7 +157,7 @@ module Make(Ord: OrderedType) = struct
let rec remove x = function let rec remove x = function
Empty -> Empty ->
Empty Empty
| Node(l, v, d, r, h) -> | Node(l, v, d, r, _h) ->
if c = 0 then if c = 0 then
merge l r merge l r
...@@ -211,7 +214,8 @@ module Make(Ord: OrderedType) = struct ...@@ -211,7 +214,8 @@ module Make(Ord: OrderedType) = struct
let rec part (t, f as accu) = function let rec part (t, f as accu) = function
| Empty -> accu | Empty -> accu
| Node(l, v, d, r, _) -> | Node(l, v, d, r, _) ->
part (part (if p v d then (add v d t, f) else (t, add v d f)) l) r in part (part (if p v d then (add v d t, f)
part (Empty, Empty) s part (Empty, Empty) s
(* Same as create and bal, but no assumptions are made on the (* Same as create and bal, but no assumptions are made on the
...@@ -260,7 +264,7 @@ module Make(Ord: OrderedType) = struct ...@@ -260,7 +264,7 @@ module Make(Ord: OrderedType) = struct
| (Node (l1, v1, d1, r1, h1), _) when h1 >= height s2 -> | (Node (l1, v1, d1, r1, h1), _) when h1 >= height s2 ->
let (l2, d2, r2) = split v1 s2 in let (l2, d2, r2) = split v1 s2 in
concat_or_join (merge f l1 l2) v1 (f v1 (Some d1) d2) (merge f r1 r2) concat_or_join (merge f l1 l2) v1 (f v1 (Some d1) d2) (merge f r1 r2)
| (_, Node (l2, v2, d2, r2, h2)) -> | (_, Node (l2, v2, d2, r2, _h2)) ->
let (l1, d1, r1) = split v2 s1 in let (l1, d1, r1) = split v2 s1 in
concat_or_join (merge f l1 l2) v2 (f v2 d1 (Some d2)) (merge f r1 r2) concat_or_join (merge f l1 l2) v2 (f v2 d1 (Some d2)) (merge f r1 r2)
| _ -> | _ ->
...@@ -312,3 +316,5 @@ module Make(Ord: OrderedType) = struct ...@@ -312,3 +316,5 @@ module Make(Ord: OrderedType) = struct
let choose = min_binding let choose = min_binding
end end
(* $Id: map.mli 10483 2010-05-31 12:48:13Z doligez $ *) (* $Id: map.mli 10483 2010-05-31 12:48:13Z doligez $ *)
module Map : sig
(** Association tables over ordered types. (** Association tables over ordered types.
This module implements applicative association tables, also known as This module implements applicative association tables, also known as
...@@ -192,3 +194,5 @@ module type S = ...@@ -192,3 +194,5 @@ module type S =
module Make (Ord : OrderedType) : S with type key = Ord.t module Make (Ord : OrderedType) : S with type key = Ord.t
(** Functor building an implementation of the map structure (** Functor building an implementation of the map structure
given a totally ordered type. *) given a totally ordered type. *)
...@@ -16,7 +16,7 @@ ...@@ -16,7 +16,7 @@
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *) (* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
open Stdlib
(* useful combinators *) (* useful combinators *)
let ($) f x = f x let ($) f x = f x
open Stdlib
(** Useful functions *) (** Useful functions *)
val ($) : ('a -> 'b) -> 'a -> 'b val ($) : ('a -> 'b) -> 'a -> 'b
