Commit 1f741cb7 authored by Andrei Paskevich's avatar Andrei Paskevich
Parser: accept type casts in let patterns
parent e0e1f59c
...@@ -430,9 +430,8 @@ let quant_vars ~strict env vl = ...@@ -430,9 +430,8 @@ let quant_vars ~strict env vl =
Mstr.set_union acc env, vl Mstr.set_union acc env, vl
let check_used_var t vs = let check_used_var t vs =
if t_v_occurs vs t = 0 then
let s = vs.vs_name.id_string in let s = vs.vs_name.id_string in
if not (String.length s > 0 && s.[0] = '_') then if (s = "" || s.[0] <> '_') && t_v_occurs vs t = 0 then
Warning.emit ?loc:vs.vs_name.id_loc "unused variable %s" s Warning.emit ?loc:vs.vs_name.id_loc "unused variable %s" s
let check_exists_implies f = match f.t_node with let check_exists_implies f = match f.t_node with
...@@ -503,6 +503,11 @@ term_: ...@@ -503,6 +503,11 @@ term_:
| Pwild -> Tlet (id_anonymous $2.pat_loc, $4, $6) | Pwild -> Tlet (id_anonymous $2.pat_loc, $4, $6)
| Ptuple [] -> Tlet (id_anonymous $2.pat_loc, | Ptuple [] -> Tlet (id_anonymous $2.pat_loc,
{ $4 with term_desc = Tcast ($4, PTtuple []) }, $6) { $4 with term_desc = Tcast ($4, PTtuple []) }, $6)
| Pcast ({pat_desc = Pvar id}, ty) ->
Tlet (id, { $4 with term_desc = Tcast ($4, ty) }, $6)
| Pcast ({pat_desc = Pwild}, ty) ->
let id = id_anonymous $2.pat_loc in
| _ -> Tmatch ($4, [$2, $6]) } | _ -> Tmatch ($4, [$2, $6]) }
| MATCH term WITH match_cases(term) END | MATCH term WITH match_cases(term) END
{ Tmatch ($2, $4) } { Tmatch ($2, $4) }
...@@ -655,36 +660,30 @@ expr_: ...@@ -655,36 +660,30 @@ expr_:
| Eidapp (Qident id, [e1;e2]) when id.id_str = mixfix "[]" -> | Eidapp (Qident id, [e1;e2]) when id.id_str = mixfix "[]" ->
Eidapp (Qident {id with id_str = mixfix "[]<-"}, [e1;e2;$3]) Eidapp (Qident {id with id_str = mixfix "[]<-"}, [e1;e2;$3])
| _ -> raise Error } | _ -> raise Error }
| LET pattern EQUAL seq_expr IN seq_expr | LET top_ghost pattern EQUAL seq_expr IN seq_expr
{ match $2.pat_desc with
| Pvar id -> Elet (id, Gnone, $4, $6)
| Pwild -> Elet (id_anonymous $2.pat_loc, Gnone, $4, $6)
| Ptuple [] -> Elet (id_anonymous $2.pat_loc, Gnone,
{ $4 with expr_desc = Ecast ($4, PTtuple []) }, $6)
| _ -> Ematch ($4, [$2, $6]) }
| LET GHOST pat_arg EQUAL seq_expr IN seq_expr
{ match $3.pat_desc with { match $3.pat_desc with
| Pvar id -> Elet (id, Gghost, $5, $7) | Pvar id -> Elet (id, $2, $5, $7)
| Pwild -> Elet (id_anonymous $3.pat_loc, Gghost, $5, $7) | Pwild -> Elet (id_anonymous $3.pat_loc, $2, $5, $7)
| Ptuple [] -> Elet (id_anonymous $3.pat_loc, Gghost, | Ptuple [] -> Elet (id_anonymous $3.pat_loc, $2,
{ $5 with expr_desc = Ecast ($5, PTtuple []) }, $7) { $5 with expr_desc = Ecast ($5, PTtuple []) }, $7)
| _ -> Ematch ({ $5 with expr_desc = Eghost $5 }, [$3, $7]) } | Pcast ({pat_desc = Pvar id}, ty) ->
| LET labels(lident) fun_defn IN seq_expr Elet (id, $2, { $5 with expr_desc = Ecast ($5, ty) }, $7)
{ Efun ($2, Gnone, $3, $5) } | Pcast ({pat_desc = Pwild}, ty) ->
| LET labels(lident_op_id) fun_defn IN seq_expr let id = id_anonymous $3.pat_loc in
{ Efun ($2, Gnone, $3, $5) } Elet (id, $2, { $5 with expr_desc = Ecast ($5, ty) }, $7)
| LET GHOST labels(lident) fun_defn IN seq_expr | _ ->
{ Efun ($3, Gghost, $4, $6) } let e = match $2 with
| LET GHOST labels(lident_op_id) fun_defn IN seq_expr | Glemma -> Loc.errorm ~loc:($3.pat_loc)
{ Efun ($3, Gghost, $4, $6) } "`let lemma' cannot be used with complex patterns"
| LET labels(lident_op_id) EQUAL seq_expr IN seq_expr | Gghost -> { $5 with expr_desc = Eghost $5 }
{ Elet ($2, Gnone, $4, $6) } | Gnone -> $5 in
| LET GHOST labels(lident_op_id) EQUAL seq_expr IN seq_expr Ematch (e, [$3, $7]) }
{ Elet ($3, Gghost, $5, $7) } | LET top_ghost labels(lident_op_id) EQUAL seq_expr IN seq_expr
| LET LEMMA labels(lident_rich) EQUAL seq_expr IN seq_expr { Elet ($3, $2, $5, $7) }
{ Elet ($3, Glemma, $5, $7) } | LET top_ghost labels(lident) fun_defn IN seq_expr
| LET LEMMA labels(lident_rich) fun_defn IN seq_expr { Efun ($3, $2, $4, $6) }
{ Efun ($3, Glemma, $4, $6) } | LET top_ghost labels(lident_op_id) fun_defn IN seq_expr
| LET REC with_list1(rec_defn) IN seq_expr | LET REC with_list1(rec_defn) IN seq_expr
{ Erec ($3, $5) } { Erec ($3, $5) }
| fun_expr | fun_expr
...@@ -1095,7 +1095,7 @@ let spec_invariant env pvs vty spec = ...@@ -1095,7 +1095,7 @@ let spec_invariant env pvs vty spec =
(** Abstract values *) (** Abstract values *)
let warn_unused s loc = let warn_unused s loc =
if not (String.length s > 0 && s.[0] = '_') then if s = "" || s.[0] <> '_' then
Warning.emit ?loc "unused variable %s" s Warning.emit ?loc "unused variable %s" s
let check_used_pv e pv = if not (Spv.mem pv e.e_syms.syms_pv) then let check_used_pv e pv = if not (Spv.mem pv e.e_syms.syms_pv) then
