Commit 1efe8899 authored by Andrei Paskevich's avatar Andrei Paskevich
Eval_match: update add_var wrt the last change in Ity
parent 97d33f03
...@@ -102,7 +102,8 @@ let new_point = ...@@ -102,7 +102,8 @@ let new_point =
fun () -> incr c; !c fun () -> incr c; !c
(* notes: (* notes:
- do not collapse on Eif and Ecase in k_expr when the type is fragile *) - do not collapse on Eif and Ecase in k_expr when the type is fragile
let add_var kn st v = let add_var kn st v =
let rp = ref st.s_points in let rp = ref st.s_points in
...@@ -111,11 +112,13 @@ let add_var kn st v = ...@@ -111,11 +112,13 @@ let add_var kn st v =
| Tyapp (s, tl) -> | Tyapp (s, tl) ->
let s = restore_its s in let s = restore_its s in
if not s.its_fragile && (* no need to go any further *) if not s.its_fragile && (* no need to go any further *)
List.for_all (fun f -> f.its_frozen) s.its_arg_flg then P 0 else List.for_all (fun f -> f.its_frozen) s.its_arg_flg &&
List.for_all (fun f -> f.its_frozen) s.its_reg_flg then P 0 else
let sbs = List.fold_right2 Mtv.add s.its_ts.ts_args tl Mtv.empty in let sbs = List.fold_right2 Mtv.add s.its_ts.ts_args tl Mtv.empty in
let d = find_its_defn kn s in let d = find_its_defn kn s in
if s.its_private || (s.its_nonfree && not s.its_fragile) then if s.its_nonfree then if s.its_fragile then (* breakable record *)
(* unbreakable invariant *) assert false (* TODO *)
else (* unbreakable record *)
let add_field m f = let add_field m f =
let pj = ls_of_rs f in let pj = ls_of_rs f in
let ty = Ty.ty_inst sbs (Opt.get f.rs_field).pv_vs.vs_ty in let ty = Ty.ty_inst sbs (Opt.get f.rs_field).pv_vs.vs_ty in
...@@ -123,11 +126,7 @@ let add_var kn st v = ...@@ -123,11 +126,7 @@ let add_var kn st v =
| P 0 -> m | c -> Mls.add pj c m in | P 0 -> m | c -> Mls.add pj c m in
let pjs = List.fold_left add_field Mls.empty d.itd_fields in let pjs = List.fold_left add_field Mls.empty d.itd_fields in
if Mls.is_empty pjs then P 0 else R pjs if Mls.is_empty pjs then P 0 else R pjs
else if s.its_nonfree then else (* constructible type *)
(* breakable invariant *)
else
let add_field m f = Mpv.add (Opt.get f.rs_field) (ls_of_rs f) m in let add_field m f = Mpv.add (Opt.get f.rs_field) (ls_of_rs f) m in
let pjm = List.fold_left add_field Mpv.empty d.itd_fields in let pjm = List.fold_left add_field Mpv.empty d.itd_fields in
let add_constr m c = let add_constr m c =
...@@ -145,11 +144,10 @@ let add_var kn st v = ...@@ -145,11 +144,10 @@ let add_var kn st v =
let pat = pat_app cs pl ty in let pat = pat_app cs pl ty in
let v = Svs.choose pat.pat_vars in let v = Svs.choose pat.pat_vars in
down ((leaf, pat)::stem) (t_var v) ty_f in down ((leaf, pat)::stem) (t_var v) ty_f in
let fdl = List.map2 conv_field c.rs_cty.cty_args tyl in Mls.add cs (List.map2 conv_field c.rs_cty.cty_args tyl) m in
let whole = function P 0 -> true | _ -> false in
if List.for_all whole fdl then m else Mls.add cs fdl m in
let css = List.fold_left add_constr Mls.empty d.itd_constructors in let css = List.fold_left add_constr Mls.empty d.itd_constructors in
if Mls.is_empty css then P 0 else C css let chk _ l = List.for_all (function P 0 -> true | _ -> false) l in
if Mls.for_all chk css then P 0 else C css
in in
match down [] (t_var v) v.vs_ty with match down [] (t_var v) v.vs_ty with
| P 0 -> st (* not broken *) | P 0 -> st (* not broken *)
