Commit 1d3d25c8 authored by Andrei Paskevich's avatar Andrei Paskevich
Typing: remove excessive traversal
parent 32b7287f
...@@ -812,7 +812,7 @@ let add_types muc tdl = ...@@ -812,7 +812,7 @@ let add_types muc tdl =
let oms, pjl = Lists.map_fold_left get_pj Sstr.empty pjl in let oms, pjl = Lists.map_fold_left get_pj Sstr.empty pjl in
(create_user_id id, pjl) :: List.map (get_cs oms) csl (create_user_id id, pjl) :: List.map (get_cs oms) csl
| [] -> assert false in | [] -> assert false in
if not (Hstr.mem htd x) then (* if not (Hstr.mem htd x) then *)
begin match try Some (Hstr.find hts x) with Not_found -> None with begin match try Some (Hstr.find hts x) with Not_found -> None with
| Some s -> | Some s ->
Hstr.add htd x (create_rec_variant_decl s csl) Hstr.add htd x (create_rec_variant_decl s csl)
...@@ -832,7 +832,7 @@ let add_types muc tdl = ...@@ -832,7 +832,7 @@ let add_types muc tdl =
let ghost = d.td_vis = Abstract || fd.f_ghost in let ghost = d.td_vis = Abstract || fd.f_ghost in
nms, (fd.f_mutable, create_pvsymbol id ~ghost ity) in nms, (fd.f_mutable, create_pvsymbol id ~ghost ity) in
let _,fl = Lists.map_fold_left get_fd Sstr.empty fl in let _,fl = Lists.map_fold_left get_fd Sstr.empty fl in
if d.td_vis <> Public || d.td_mut then Loc.errorm ~loc if d.td_vis <> Public || d.td_mut then Loc.errorm ~loc
...@@ -865,7 +865,7 @@ let add_types muc tdl = ...@@ -865,7 +865,7 @@ let add_types muc tdl =
let id, args = Mstr.find x alg in let id, args = Mstr.find x alg in
let s = create_itysymbol_pure id args in let s = create_itysymbol_pure id args in
Hstr.add hts x s; Hstr.add hts x s;
visit ~alias ~alg x (Mstr.find x def); (* visit ~alias ~alg x (Mstr.find x def); *)
s s
| Qident {id_str = x} when Mstr.mem x def -> | Qident {id_str = x} when Mstr.mem x def ->
visit ~alias ~alg x (Mstr.find x def); visit ~alias ~alg x (Mstr.find x def);
Supports Markdown
