Commit 1c6818c3 authored by MARCHE Claude's avatar MARCHE Claude
auto-detection of prover (ongoing work)
parent 20574b18
......@@ -242,6 +242,77 @@ let preferences c =
let ( _ : GWindow.Buttons.about) = dialog#run () in
dialog#destroy ()
(* auto-detection of provers *)
type prover_kind = ATP | ITP
type prover_autodetection_data =
{ kind : prover_kind;
prover_id : string;
mutable prover_name : string;
mutable commands : string list;
mutable version_switch : string;
mutable version_regexp : string;
mutable versions_ok : string list;
mutable versions_old : string list;
let default k id =
{ kind = k;
prover_id = id;
prover_name = "";
commands = [];
version_switch = "";
version_regexp = "";
versions_ok = [];
versions_old = [];
let load_prover d (key, value) =
match key with
| "name" -> d.prover_name <- Rc.string value
| "command" -> d.commands <- Rc.string value :: d.commands
| "version_switch" -> d.version_switch <- Rc.string value
| "version_regexp" -> d.version_regexp <- Rc.string value
| "version_ok" -> d.versions_ok <- Rc.string value :: d.versions_ok
| "version_old" -> d.versions_old <- Rc.string value :: d.versions_old
| s ->
eprintf "unknown key [%s] in autodetection data@." s;
exit 1
let load acc (key,l) =
match key with
| ["ATP" ; id] ->
let d = default ATP id in
List.iter (load_prover d) l;
d :: acc
| ["ITP" ; id] ->
let d = default ITP id in
d :: acc
| s :: _ ->
eprintf "unknown section [%s] in auto detection data@." s;
exit 1
| [] -> assert false
let read_auto_detection_data () =
try
let rc = Rc.from_file "prover-detection-data.conf" in
List.fold_left load [] rc
| Failure "lexing" ->
eprintf "Syntax error in prover-detection-data.conf@.";
exit 2
| Not_found ->
eprintf "prover-detection-data.conf not found@.";
exit 2
Local Variables:
compile-command: "unset LANG; make -C ../.. bin/whyide.opt"
