Commit 1a0d9e4a authored by Clément Fumex's avatar Clément Fumex
Coq realization of bv theory:
- generation in the makefile
- proofs done
Remove complex axioms from Pow2int in bv.why.
Add guards in rotates axioms in bv.why.
parent 01d2e275
...@@ -868,13 +868,16 @@ COQLIBS_OPTION = $(addprefix lib/coq/option/, $(COQLIBS_OPTION_FILES)) ...@@ -868,13 +868,16 @@ COQLIBS_OPTION = $(addprefix lib/coq/option/, $(COQLIBS_OPTION_FILES))
COQLIBS_SEQ_FILES = Seq COQLIBS_SEQ_FILES = Seq
COQLIBS_SEQ = $(addprefix lib/coq/seq/, $(COQLIBS_SEQ_FILES)) COQLIBS_SEQ = $(addprefix lib/coq/seq/, $(COQLIBS_SEQ_FILES))
COQLIBS_BV_FILES = Pow2int BV_Gen
COQLIBS_BV = $(addprefix lib/coq/bv/, $(COQLIBS_BV_FILES))
ifeq (@enable_coq_fp_libs@,yes) ifeq (@enable_coq_fp_libs@,yes)
COQLIBS_FP_FILES = Rounding SingleFormat Single DoubleFormat Double COQLIBS_FP_FILES = Rounding SingleFormat Single DoubleFormat Double
COQLIBS_FP_ALL_FILES = GenFloat $(COQLIBS_FP_FILES) COQLIBS_FP_ALL_FILES = GenFloat $(COQLIBS_FP_FILES)
COQLIBS_FP = $(addprefix lib/coq/floating_point/, $(COQLIBS_FP_ALL_FILES)) COQLIBS_FP = $(addprefix lib/coq/floating_point/, $(COQLIBS_FP_ALL_FILES))
endif endif
COQLIBS_FILES = lib/coq/BuiltIn lib/coq/HighOrd $(COQLIBS_INT) $(COQLIBS_BOOL) $(COQLIBS_REAL) $(COQLIBS_NUMBER) $(COQLIBS_SET) $(COQLIBS_MAP) $(COQLIBS_LIST) $(COQLIBS_OPTION) $(COQLIBS_SEQ) $(COQLIBS_FP) COQLIBS_FILES = lib/coq/BuiltIn lib/coq/HighOrd $(COQLIBS_INT) $(COQLIBS_BOOL) $(COQLIBS_REAL) $(COQLIBS_NUMBER) $(COQLIBS_SET) $(COQLIBS_MAP) $(COQLIBS_LIST) $(COQLIBS_OPTION) $(COQLIBS_SEQ) $(COQLIBS_FP) $(COQLIBS_BV)
drivers/coq-realizations.aux: Makefile drivers/coq-realizations.aux: Makefile
$(if $(QUIET),@echo 'Generate $@' &&) \ $(if $(QUIET),@echo 'Generate $@' &&) \
...@@ -899,6 +902,8 @@ drivers/coq-realizations.aux: Makefile ...@@ -899,6 +902,8 @@ drivers/coq-realizations.aux: Makefile
echo 'theory option.'"$$f"' meta "realized_theory" "option.'"$$f"'", "" end'; done; \ echo 'theory option.'"$$f"' meta "realized_theory" "option.'"$$f"'", "" end'; done; \
for f in $(COQLIBS_SEQ_FILES); do \ for f in $(COQLIBS_SEQ_FILES); do \
echo 'theory seq.'"$$f"' meta "realized_theory" "seq.'"$$f"'", "" end'; done; \ echo 'theory seq.'"$$f"' meta "realized_theory" "seq.'"$$f"'", "" end'; done; \
for f in $(COQLIBS_BV_FILES); do \
echo 'theory bv.'"$$f"' meta "realized_theory" "bv.'"$$f"'", "" end'; done; \
for f in $(COQLIBS_FP_FILES); do \ for f in $(COQLIBS_FP_FILES); do \
echo 'theory floating_point.'"$$f"' meta "realized_theory" "floating_point.'"$$f"'", "" end'; done; \ echo 'theory floating_point.'"$$f"' meta "realized_theory" "floating_point.'"$$f"'", "" end'; done; \
...@@ -924,6 +929,8 @@ install_no_local:: ...@@ -924,6 +929,8 @@ install_no_local::
cp $(addsuffix .vo, $(COQLIBS_OPTION)) $(LIBDIR)/why3/coq/option/ cp $(addsuffix .vo, $(COQLIBS_OPTION)) $(LIBDIR)/why3/coq/option/
mkdir -p $(LIBDIR)/why3/coq/seq mkdir -p $(LIBDIR)/why3/coq/seq
cp $(addsuffix .vo, $(COQLIBS_SEQ)) $(LIBDIR)/why3/coq/seq/ cp $(addsuffix .vo, $(COQLIBS_SEQ)) $(LIBDIR)/why3/coq/seq/
mkdir -p $(LIBDIR)/why3/coq/bv
cp $(addsuffix .vo, $(COQLIBS_BV)) $(LIBDIR)/why3/coq/bv/
mkdir -p $(LIBDIR)/why3/coq/floating_point mkdir -p $(LIBDIR)/why3/coq/floating_point
cp $(addsuffix .vo, $(COQLIBS_FP)) $(LIBDIR)/why3/coq/floating_point/ cp $(addsuffix .vo, $(COQLIBS_FP)) $(LIBDIR)/why3/coq/floating_point/
...@@ -958,6 +965,9 @@ update-coq-option: bin/why3realize.@OCAMLBEST@ drivers/coq-realizations.aux theo ...@@ -958,6 +965,9 @@ update-coq-option: bin/why3realize.@OCAMLBEST@ drivers/coq-realizations.aux theo
update-coq-seq: bin/why3realize.@OCAMLBEST@ drivers/coq-realizations.aux theories/seq.why update-coq-seq: bin/why3realize.@OCAMLBEST@ drivers/coq-realizations.aux theories/seq.why
for f in $(COQLIBS_SEQ_FILES); do WHY3CONFIG="" bin/why3realize.@OCAMLBEST@ -L theories -D drivers/coq-realize.drv -T seq.$$f -o lib/coq/seq/; done for f in $(COQLIBS_SEQ_FILES); do WHY3CONFIG="" bin/why3realize.@OCAMLBEST@ -L theories -D drivers/coq-realize.drv -T seq.$$f -o lib/coq/seq/; done
update-coq-bv: bin/why3realize.@OCAMLBEST@ drivers/coq-realizations.aux theories/bv.why
for f in $(COQLIBS_BV_FILES); do WHY3CONFIG="" bin/why3realize.@OCAMLBEST@ -L theories -D drivers/coq-realize.drv -T bv.$$f -o lib/coq/bv/; done
update-coq-fp: bin/why3realize.@OCAMLBEST@ drivers/coq-realizations.aux theories/floating_point.why update-coq-fp: bin/why3realize.@OCAMLBEST@ drivers/coq-realizations.aux theories/floating_point.why
for f in $(COQLIBS_FP_FILES); do WHY3CONFIG="" bin/why3realize.@OCAMLBEST@ -L theories -D drivers/coq-realize.drv -T floating_point.$$f -o lib/coq/floating_point/; done for f in $(COQLIBS_FP_FILES); do WHY3CONFIG="" bin/why3realize.@OCAMLBEST@ -L theories -D drivers/coq-realize.drv -T floating_point.$$f -o lib/coq/floating_point/; done
...@@ -1641,7 +1651,8 @@ STDLIBS = algebra \ ...@@ -1641,7 +1651,8 @@ STDLIBS = algebra \
real \ real \
relations \ relations \
set \ set \
sum sum \
bv
# function ? tptp ? # function ? tptp ?
STDMODS = array matrix hashtbl impset pqueue queue random ref stack string STDMODS = array matrix hashtbl impset pqueue queue random ref stack string
(* bitvector modules, is not in smt-libv2.drv since cvc4 and z3 don't (* bitvector modules, is not in smt-libv2.drv since cvc4 and z3 don't
have the same name for the function to_int *) have the same name for the function to_int *)
theory bv.BV64 theory bv.BV64
syntax type t "(_ BitVec 64)"
syntax function zero "#x0000000000000000"
syntax function ones "#xFFFFFFFFFFFFFFFF"
syntax function bw_and "(bvand %1 %2)"
syntax function bw_or "(bvor %1 %2)"
syntax function bw_xor "(bvxor %1 %2)"
syntax function bw_not "(bvnot %1)"
syntax function add "(bvadd %1 %2)"
syntax function sub "(bvsub %1 %2)"
syntax function neg "(bvneg %1)"
syntax function mul "(bvmul %1 %2)"
syntax function udiv "(bvudiv %1 %2)"
syntax function urem "(bvurem %1 %2)"
syntax function lsr_bv "(bvlshr %1 %2)"
syntax function lsl_bv "(bvshl %1 %2)"
syntax function asr_bv "(bvashr %1 %2)"
syntax converter of_int "(_ bv%1 64)" syntax converter of_int "(_ bv%1 64)"
syntax function to_uint "(bv2nat %1)" syntax function to_uint "(bv2nat %1)"
remove prop to_uint_of_int remove prop to_uint_of_int
remove prop to_uint_extensionality remove prop to_uint_extensionality
remove prop to_uint_bounds remove prop to_uint_bounds
syntax predicate eq "(= %1 %2)"
remove prop Extensionality
remove prop to_uint_add remove prop to_uint_add
remove prop to_uint_sub remove prop to_uint_sub
...@@ -36,66 +15,14 @@ theory bv.BV64 ...@@ -36,66 +15,14 @@ theory bv.BV64
remove prop to_uint_urem remove prop to_uint_urem
remove prop to_uint_lsr remove prop to_uint_lsr
remove prop to_uint_lsl remove prop to_uint_lsl
remove prop Nth_zero
remove prop Nth_ones
remove prop Nth_bw_or
remove prop Nth_bw_and
remove prop Nth_bw_xor
remove prop Nth_bw_not
remove prop Nth_rotate_left
remove prop Nth_rotate_right
remove prop Nth_bv_is_nth
remove prop Lsr_nth_low
remove prop Lsr_nth_high
remove prop Asr_nth_low
remove prop Asr_nth_high
remove prop Lsl_nth_low
remove prop Lsl_nth_high
syntax predicate ult "(bvult %1 %2)"
syntax predicate ule "(bvule %1 %2)"
syntax predicate ugt "(bvugt %1 %2)"
syntax predicate uge "(bvuge %1 %2)"
syntax predicate slt "(bvslt %1 %2)"
syntax predicate sle "(bvsle %1 %2)"
syntax predicate sgt "(bvsgt %1 %2)"
syntax predicate sge "(bvsge %1 %2)"
syntax function nth_bv
"(not (= (bvand (bvlshr %1 %2) (_ bv1 64)) (_ bv0 64)))"
syntax function rotate_left "(bvor (bvshl %1 (bvurem %2 (_ bv64 64))) (bvlshr %1 (bvsub (_ bv64 64) (bvurem %2 (_ bv64 64)))))"
syntax function rotate_right "(bvor (bvlshr %1 (bvurem %2 (_ bv64 64))) (bvshl %1 (bvsub (_ bv64 64) (bvurem %2 (_ bv64 64)))))"
end end
theory bv.BV32 theory bv.BV32
syntax type t "(_ BitVec 32)"
syntax function zero "#x00000000"
syntax function ones "#xFFFFFFFF"
syntax converter of_int "(_ bv%1 32)" syntax converter of_int "(_ bv%1 32)"
...@@ -105,66 +32,14 @@ theory bv.BV32 ...@@ -105,66 +32,14 @@ theory bv.BV32
"(not (= (bvand (bvlshr %1 %2) (_ bv1 32)) (_ bv0 32)))"
syntax function rotate_left "(bvor (bvshl %1 (bvurem %2 (_ bv32 32))) (bvlshr %1 (bvsub (_ bv32 32) (bvurem %2 (_ bv32 32)))))"
syntax function rotate_right "(bvor (bvlshr %1 (bvurem %2 (_ bv32 32))) (bvshl %1 (bvsub (_ bv32 32) (bvurem %2 (_ bv32 32)))))"
end end
theory bv.BV16 theory bv.BV16
syntax type t "(_ BitVec 16)"
syntax function zero "#x0000"
syntax function ones "#xFFFF"
syntax converter of_int "(_ bv%1 16)" syntax converter of_int "(_ bv%1 16)"
...@@ -174,66 +49,14 @@ theory bv.BV16 ...@@ -174,66 +49,14 @@ theory bv.BV16
"(not (= (bvand (bvlshr %1 %2) (_ bv1 16)) (_ bv0 16)))"
syntax function rotate_left "(bvor (bvshl %1 (bvurem %2 (_ bv16 16))) (bvlshr %1 (bvsub (_ bv16 16) (bvurem %2 (_ bv16 16)))))"
syntax function rotate_right "(bvor (bvlshr %1 (bvurem %2 (_ bv16 16))) (bvshl %1 (bvsub (_ bv16 16) (bvurem %2 (_ bv16 16)))))"
end end
theory bv.BV8 theory bv.BV8
syntax type t "(_ BitVec 8)"
syntax function zero "#x00"
syntax function ones "#xFF"
syntax converter of_int "(_ bv%1 8)" syntax converter of_int "(_ bv%1 8)"
...@@ -243,35 +66,4 @@ theory bv.BV8 ...@@ -243,35 +66,4 @@ theory bv.BV8
"(not (= (bvand (bvlshr %1 %2) (_ bv1 8)) (_ bv0 8)))"
syntax function rotate_left "(bvor (bvshl %1 (bvurem %2 (_ bv8 8))) (bvlshr %1 (bvsub (_ bv8 8) (bvurem %2 (_ bv8 8)))))"
syntax function rotate_right "(bvor (bvlshr %1 (bvurem %2 (_ bv8 8))) (bvshl %1 (bvsub (_ bv8 8) (bvurem %2 (_ bv8 8)))))"
end end
...@@ -2,6 +2,103 @@ ...@@ -2,6 +2,103 @@
prelude ";;; SMT-LIB2 driver: bit-vectors, common part" prelude ";;; SMT-LIB2 driver: bit-vectors, common part"
theory bv.BV_Gen
theory bv.BV64
theory bv.BV32
theory bv.BV16
theory bv.BV8
theory bv.BVConverter_32_64 theory bv.BVConverter_32_64
syntax function toBig "((_ zero_extend 32) %1)" syntax function toBig "((_ zero_extend 32) %1)"
syntax function toSmall "((_ extract 31 0) %1)" syntax function toSmall "((_ extract 31 0) %1)"
...@@ -39,13 +136,6 @@ theory bv.Pow2int ...@@ -39,13 +136,6 @@ theory bv.Pow2int
remove prop Power_1 remove prop Power_1
remove prop Power_sum remove prop Power_sum
remove prop pow2pos remove prop pow2pos
remove prop Div_mult_inst
remove prop Div_double
remove prop Div_pow
remove prop Div_double_neg
remove prop Div_pow2
remove prop Div_div_pow
remove prop Mod_pow2_gen
remove prop pow2_0 remove prop pow2_0
remove prop pow2_1 remove prop pow2_1
remove prop pow2_2 remove prop pow2_2
...@@ -68,34 +68,11 @@ end ...@@ -68,34 +68,11 @@ end
have the same name for the function to_uint *) have the same name for the function to_uint *)
syntax converter of_int "((_ int2bv 64) %1)" syntax converter of_int "((_ int2bv 64) %1)"
syntax function to_uint "(bv2int %1)" syntax function to_uint "(bv2int %1)"
syntax function to_int "(ite (not (= (bvand %1 #x80000000) zero))
(bv2int %1) (- (not %1) (- (1))))"
...@@ -105,66 +82,14 @@ theory bv.BV64 ...@@ -105,66 +82,14 @@ theory bv.BV64
end end
syntax converter of_int "((_ int2bv 32) %1)" syntax converter of_int "((_ int2bv 32) %1)"
...@@ -174,66 +99,14 @@ theory bv.BV32 ...@@ -174,66 +99,14 @@ theory bv.BV32
