Commit 17260fb4 authored by Andrei Paskevich's avatar Andrei Paskevich
Pmodule: clone type definitions
parent 0db025e5
......@@ -462,14 +462,34 @@ let cl_find_xs cl xs =
let cl_clone_ls inst cl ls =
if Mls.mem ls inst.inst_ls then raise (CannotInstantiate ls.ls_name);
let constr = ls.ls_constr in
let id = id_clone ls.ls_name in
let at = List.map (cl_trans_ty cl) ls.ls_args in
let vt = Opt.map (cl_trans_ty cl) ls.ls_value in
let ls' = create_lsymbol ~constr id at vt in
cl.ls_table <- Mls.add ls ls' cl.ls_table;
ls'
let cl_add_ls cl ({ls_name = id} as ls) ls' =
let cl_init_ty cl ({ts_name = id} as ts) ty =
let rec restore_ity ty = match ty.ty_node with
| Tyapp (s,tl) ->
ity_app_fresh (restore_its s) (List.map restore_ity tl)
| Tyvar v -> ity_var v in
let its = restore_its ts and ity = restore_ity ty in
if not (Sid.mem id cl.cl_local) then raise (NonLocal id);
let stv = Stv.of_list ts.ts_args in
if not (Stv.subset (ity_freevars Stv.empty ity) stv) ||
its_impure its || not ity.ity_pure then raise (BadInstance id);
cl.ty_table <- Mts.add ts ity cl.ty_table
let cl_init_ts cl ({ts_name = id} as ts) ts' =
let its = restore_its ts and its' = restore_its ts' in
if List.length ts.ts_args <> List.length ts'.ts_args ||
its_impure its || its_impure its' then raise (BadInstance id);
cl.ts_table <- Mts.add its.its_ts its' cl.ts_table
let cl_init_ls cl ({ls_name = id} as ls) ls' =
let mtch sb ty ty' = try ty_match sb ty' (cl_trans_ty cl ty)
with TypeMismatch _ -> raise (BadInstance id) in
let sbs = match ls.ls_value,ls'.ls_value with
......@@ -480,23 +500,23 @@ let cl_add_ls cl ({ls_name = id} as ls) ls' =
with Invalid_argument _ -> raise (BadInstance id));
let cl_found_ls inst cl uc ls =
let nls = match Mls.find_opt ls inst.inst_ls with
| None ->
let ns = Theory.get_namespace uc.muc_theory in
(try Some (ns_find_ls ns [ls.ls_name.id_string])
with Not_found -> None)
| nls -> nls in
match nls with
| Some ls' -> cl_add_ls cl ls ls'; true
| None -> false
let cl_init_pr cl {pr_name = id} _ =
let cl_init m inst =
let cl = empty_clones m in
Mts.iter (cl_init_ty cl) inst.inst_ty;
Mts.iter (cl_init_ts cl) inst.inst_ts;
Mls.iter (cl_init_ls cl) inst.inst_ls;
Mpr.iter (cl_init_pr cl) inst.inst_pr;
cl
(* clone declarations *)
let clone_decl inst cl uc d = match d.d_node with
| Dtype _ | Ddata _ -> assert false (* impossible *)
| Dparam ls ->
if cl_found_ls inst cl uc ls then uc else
if Mls.mem ls inst.inst_ls then uc else
let d = create_param_decl (cl_clone_ls inst cl ls) in
add_pdecl ~vc:false uc (create_pure_decl d)
| Dlogic ldl ->
......@@ -530,7 +550,111 @@ let clone_decl inst cl uc d = match d.d_node with
let d = create_prop_decl k' pr' (cl_trans_fmla cl f) in
let clone_type_decl _inst _cl _tdl = assert false
let clone_type_decl inst cl tdl =
let def =
List.fold_left (fun m d -> Mits.add d.itd_its d m) Mits.empty tdl in
let htd = Hits.create 5 in
let rec visit alg ({its_ts = {ts_name = id} as ts} as s) d =
if not (Hits.mem htd s) then
let alg = Sits.add s alg in
let id' = id_clone id in
let cloned = Mts.mem ts inst.inst_ts || Mts.mem ts inst.inst_ty in
let conv_pj v = create_pvsymbol
(id_clone v.pv_vs.vs_name) ~ghost:v.pv_ghost (conv_ity alg v.pv_ity) in
let save_rs o n =
cl.rs_table <- Mrs.add o n cl.rs_table;
match o.rs_logic, n.rs_logic with
| RLls o, RLls n -> cl.ls_table <- Mls.add o n cl.ls_table;
| RLnone, RLnone -> () (* constructors with invariants *)
| _ -> assert false in
let save_itd itd =
List.iter2 save_rs d.itd_constructors itd.itd_constructors;
List.iter2 save_rs d.itd_fields itd.itd_fields;
Hits.add htd s (Some itd) in
(* alias *)
if s.its_def <> None then begin
if cloned then raise (CannotInstantiate id);
let def = conv_ity alg (Opt.get s.its_def) in
let itd = create_alias_decl id' ts.ts_args def in
cl.ts_table <- Mts.add ts itd.itd_its cl.ts_table;
save_itd itd
end else
(* abstract *)
if d.itd_fields = [] && d.itd_constructors = [] &&
d.itd_invariant = [] then begin
if cloned then Hits.add htd s None else begin
let itd = create_abstract_type_decl id' ts.ts_args s.its_privmut in
save_itd itd
end else
(* variant *)
if s.its_mfields = [] && d.itd_constructors <> [] &&
let conv_fd m fd =
let v = Opt.get fd.rs_field in Mpv.add v (conv_pj v) m in
let fldm = List.fold_left conv_fd Mpv.empty d.itd_fields in
let conv_pj pj = match Mpv.find_opt pj fldm with
| Some pj' -> true, pj' | None -> false, conv_pj pj in
let conv_cs cs =
id_clone cs.rs_name, List.map conv_pj cs.rs_cty.cty_args in
let csl = List.map conv_cs d.itd_constructors in
match Mts.find_opt ts cl.ts_table with
| Some s' ->
let itd = create_rec_variant_decl s' csl in
save_itd itd
| None ->
let itd = create_flat_variant_decl id' ts.ts_args csl in
save_itd itd
end else begin
(* flat record *)
let mfld = Spv.of_list s.its_mfields in
let priv = d.itd_constructors = [] in
let mut = its_mutable s in
let pjl = List.map (fun fd -> Opt.get fd.rs_field) d.itd_fields in
let fdl = List.map (fun v -> Spv.mem v mfld, conv_pj v) pjl in
let inv =
if d.itd_invariant = [] then [] else
if d.itd_fields = [] then
List.map (cl_trans_fmla cl) d.itd_invariant else
let ovl = List.map (fun v -> v.pv_vs) pjl in
let nvl = List.map (fun (_,v) -> t_var v.pv_vs) fdl in
let conv_inv f =
let f = t_exists_close ovl [] f in
match (cl_trans_fmla cl f).t_node with
| Tquant (Texists, tq) ->
let xvl,_,f = t_open_quant tq in
let add s xv nv = Mvs.add xv nv s in
t_subst (List.fold_left2 add Mvs.empty xvl nvl) f
| _ -> assert false (* can't be *) in
List.map conv_inv d.itd_invariant in
let itd = create_flat_record_decl id' ts.ts_args priv mut fdl inv in
save_itd itd
and conv_ity alg ity =
let rec down ity = match ity.ity_node with
| Ityreg {reg_its = s; reg_args = tl}
| Ityapp (s,tl,_) | Itypur (s,tl) ->
if Sits.mem s alg then begin
if not (Mts.mem s.its_ts cl.ts_table) then
let id = id_clone s.its_ts.ts_name in
let s = create_itysymbol_pure id s.its_ts.ts_args in
cl.ts_table <- Mts.add s.its_ts s cl.ts_table
end else Opt.iter (visit alg s) (Mits.find_opt s def);
List.iter down tl
| Ityvar _ -> () in
down ity;
cl_trans_ity cl ity in
Mits.iter (visit Sits.empty) def;
Lists.map_filter (fun d -> Hits.find htd d.itd_its) tdl
let clone_pdecl inst cl uc d = match d.pd_node with
| PDtype tdl ->
let tdl = clone_type_decl inst cl tdl in
......@@ -559,12 +683,7 @@ let add_clone uc mi =
muc_units = Uclone mi :: uc.muc_units }
let clone_export uc m inst =
let check_local id =
if not (Sid.mem id m.mod_local) then raise (NonLocal id) in
Mts.iter (fun ts _ -> check_local ts.ts_name) inst.inst_ts;
Mls.iter (fun ls _ -> check_local ls.ls_name) inst.inst_ls;
Mpr.iter (fun pr _ -> check_local pr.pr_name) inst.inst_pr;
let cl = cl_init m inst in
let rec add_unit uc u = match u with
| Udecl d -> clone_pdecl inst cl uc d
| Uuse m -> use_export uc m
