Commit 170ce1dc authored by Andrei Paskevich's avatar Andrei Paskevich
Fast WP: fix the handling of "abstract"
Submitted by Johannes Kanig
parent de46b1a1
......@@ -1044,6 +1044,11 @@ module Subst : sig
(s',f) is the new state [s'] and a formula [f] which defines the new
values in [s'] with respect to the input state [s]. *)
val extract_glue : wp_env -> Sreg.t -> t -> t -> term
(* The formula [extract_glue env regs s1 s2] expresses what has not changed
between [s1] and [s2], concerning program variables. The set of
val merge : t -> t -> t -> t * term * term
(* Given a start state and two states that parted from there, return a new
"join" state and two formulas. The first formula links the first branch
......@@ -1073,15 +1078,15 @@ end = struct
(* a substitution or state knows the current variables to use for each region
and each mutable program variable. *)
(* the reg_names field is a simple name hint; a mapping reg |-> name means
that [name] should be used as a base for new variables in region [reg].
This mapping is not required to be complete for regions. *)
type t =
{ now : subst;
other : subst Mvs.t;
reg_names : vsymbol Mreg.t;
(* the actual state knows not only the current state, but also all labeled
past states. *)
......@@ -1106,13 +1111,11 @@ end = struct
belonging to this program variable are also added to the state, if not
already there. Note that [add_pvar] doesn't really change the state,
only adds new knowledge. *)
(* for simple variables (1 variable = 1 mutable region), we register the
variable name as a name hint for the region. Also, we enter a
dummy program variable in the substitution map, so that we know that we
have to do something with this variable, but still know it is a program
variable. Previously, we did not enter it at all in the map, which made
us forget to substitute it.
See also [havoc], [merge] and [term]. *)
(* for simple variables (1 variable = 1 mutable region), we do not
introduce a new program variable each time, instead we use directly the
[update_var] term. See also [havoc]. This is a heuristics which assumes
that in this case, the program variable would be an overhead. In
particular for simple references it is an important optimization. *)
let ity = pv.pv_ity in
if ity_immutable ity then s
else
......@@ -1164,8 +1167,8 @@ end = struct
Mreg.add reg (fresh_var_from_region s.reg_names reg) acc)
regset s.now.subst_regions in
let touched_regs = Mreg.set_inter regs regset in
(* We special case simple variables, when the mapping is the dummy
* variable. So no new names/equations are introduced for those. *)
(* We special case simple variables: no new variable is introduced for the
* program variable, we directly use the "update_var" term. *)
let vars, f = Mvs.fold (fun vs _ ((acc_vars, acc_f) as acc) ->
if pv_is_touched_by_regions vs regset then begin
let new_term = update_var env touched_regs vs in
......@@ -1189,9 +1192,7 @@ end = struct
"current" substitution accordingly. *)
match t.t_node with
| Tvar vs ->
(* the normal case here is to replace the program variable [vs] by its
"now" value. The special case is where it is a simple variable; we
directly insert the "update" term here. *)
(* We simply replace the program variable [vs] by its "now" value. *)
begin try Mvs.find vs s.now.subst_vars
with Not_found -> t
......@@ -1219,6 +1220,22 @@ end = struct
| _ ->
t_map (term s) t
let extract_glue env regions s1 s2 =
(* we are only interested in "now" program vars *)
let touched_regions =
Mreg.filter (fun r _ -> Sreg.mem r regions) s2.now.subst_regions in
let s1 = s1.now.subst_vars and s2 = s2.now.subst_vars in
(* We iterate over the first state, because the second one potentially
* contains more variables *)
Mvs.fold
(fun var old_f acc ->
let f = Mvs.find var s2 in
if t_equal f old_f || is_simple_var var <> None then acc
else
let new_value = update_var env touched_regions var in
t_and_simp acc (t_equ_simp f new_value)
) s1 t_true
let subst_inter a b =
(* compute the intersection of two substitutions. *)
{ subst_vars = Mvs.set_inter a.subst_vars b.subst_vars;
......@@ -1684,9 +1701,6 @@ and fast_wp_desc (env : wp_env) (s : Subst.t) (r : res_type) (e : expr)
for the exceptions that are actually listed. *)
let wp1_exn_filtered =
Mexn.filter (fun ex _ -> Mexn.mem ex xpost) wp1.exn in
(* ??? the glue is missing in this call to apply_state_to_post. This
means that "abstract" also forgets which immutable *components* are
not modified. To be fixed. *)
let xq = Mexn.mapi (fun ex q -> Mexn.find ex xresult, q.ne) xpost in
wp_nimplies wp1.post.ne wp1_exn_filtered ((result, post.ne), xq)
in
......@@ -1698,6 +1712,9 @@ and fast_wp_desc (env : wp_env) (s : Subst.t) (r : res_type) (e : expr)
if Mexn.mem ex acc then acc
else Mexn.add ex post acc)
wp1.exn xpost in
let regs = regs_of_writes e1.e_effect in
let glue = Subst.extract_glue env regs pre_abstr_state wp1.post.s in
let post = { post with ne = t_and_simp glue post.ne } in
let ok = t_and_simp_l [wp1.ok; (Subst.term s spec.c_pre); ok_post] in
{ ok = wp_label e ok;
post = post;
