Commit 16c786ef authored by sylvain dailler's avatar sylvain dailler
Updating of the documentation of the why3 server protocol
parent d0a05a2a
...@@ -37,13 +37,20 @@ the following: ...@@ -37,13 +37,20 @@ the following:
arg(i) - the commandline arguments of the command to run arg(i) - the commandline arguments of the command to run
The server does not acknowledge the receipt of this message. However, it will The server does not acknowledge the receipt of this message. However, it will
run the executable with its arguments and time/memory limit. When the run the executable with its arguments and time/memory limit.
executable has terminated, the server sends a message like this to the client When the executable has started, the server sends a message like this to the
who sent the 'run' request: client who sent the 'run' request:
id;exitcode;time;timeout;file S;id
Character "S" followed by semi-colon to indicate that the request is started.
When the executable has terminated, the server sends a message like
this to the client who sent the 'run' request:
F;id;exitcode;time;timeout;file
Their meaning is the following: Their meaning is the following:
F - single F character indicating the task is finished
id - the identifier of the request to which this answer belongs id - the identifier of the request to which this answer belongs
exitcode - the exitcode of the executed program exitcode - the exitcode of the executed program
time - the time taken by the executed program time - the time taken by the executed program
