Commit 13ffc5b8 authored by MARCHE Claude's avatar MARCHE Claude
LCP: use a type invariant
parent ee8e9fa5
...@@ -71,6 +71,9 @@ comparison on arrays, a sorting routine, and LCP. ...@@ -71,6 +71,9 @@ comparison on arrays, a sorting routine, and LCP.
The client code (LRS.java) uses these to solve the LRS problem. Verify The client code (LRS.java) uses these to solve the LRS problem. Verify
that it does so correctly. that it does so correctly.
(Based on code by Robert Sedgewick and Kevin Wayne.)
...@@ -117,7 +120,7 @@ let lcp (a:array int) (x y:int) : int ...@@ -117,7 +120,7 @@ let lcp (a:array int) (x y:int) : int
!l !l
(** test harness for lcp *) (** test harness for lcp *)
let test1 () = let test () =
let arr = Array.make 4 0 in let arr = Array.make 4 0 in
arr[0]<-1; arr[1]<-2; arr[2]<-2; arr[3]<-5; arr[0]<-1; arr[1]<-2; arr[2]<-2; arr[3]<-5;
let x = lcp arr 1 2 in let x = lcp arr 1 2 in
...@@ -273,13 +276,15 @@ module SuffixArray ...@@ -273,13 +276,15 @@ module SuffixArray
use import array.Array use import array.Array
use import LCP use import LCP
use import PrefixSort use import PrefixSort
use map.MapInjection
type suffixArray = { type suffixArray = {
values : array int; values : array int;
suffixes : array int; suffixes : array int;
invariant { self.values.length = self.suffixes.length /\
use map.MapInjection permutation self.suffixes.elts self.suffixes.length /\
sorted self.values self.suffixes }
predicate inv(s:suffixArray) = predicate inv(s:suffixArray) =
s.values.length = s.suffixes.length /\ s.values.length = s.suffixes.length /\
...@@ -287,20 +292,20 @@ predicate inv(s:suffixArray) = ...@@ -287,20 +292,20 @@ predicate inv(s:suffixArray) =
sorted s.values s.suffixes sorted s.values s.suffixes
let select (s:suffixArray) (i:int) : int let select (s:suffixArray) (i:int) : int
requires { inv s /\ 0 <= i < s.values.length } requires { 0 <= i < s.values.length }
ensures { result = s.suffixes[i] } ensures { result = s.suffixes[i] }
= s.suffixes[i] = s.suffixes[i]
(* needed to establish invariant in function create *) use import array.ArrayPermut
(** needed to establish invariant in function create *)
lemma permut_permutation : lemma permut_permutation :
forall a1 a2:array int. forall a1 a2:array int.
permut a1 a2 -> permutation a1.elts a1.length -> permutation a2.elts a2.length permut a1 a2 -> permutation a1.elts a1.length -> permutation a2.elts a2.length
(** constructor of suffixArray structure *)
let create (a:array int) : suffixArray let create (a:array int) : suffixArray
ensures { result.values = a /\ inv result } ensures { result.values = a }
let n = a.length in let n = a.length in
let suf = Array.make n 0 in let suf = Array.make n 0 in
...@@ -318,7 +323,7 @@ let lcp (s:suffixArray) (i:int) : int ...@@ -318,7 +323,7 @@ let lcp (s:suffixArray) (i:int) : int
LCP.lcp s.values s.suffixes[i] s.suffixes[i-1] LCP.lcp s.values s.suffixes[i] s.suffixes[i-1]
let test2 () = let test () =
let sa = create arr in let sa = create arr in
...@@ -470,5 +475,3 @@ use import int.MinMax ...@@ -470,5 +475,3 @@ use import int.MinMax
end end
(* Based on code by Robert Sedgewick and Kevin Wayne. *)
