GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
13378fb6
13378fb6
MARCHE Claude
update proof of power: missing coq file
69a45b73
examples/programs/power/power_WP_M_WP_parameter_fast_exp_imperative_3.v
13378fb6
This
file
is
generated
Why3
s
Coq
driver
Beware
Only
edit
allowed
sections
below
Require
Import
ZArith
Require
Import
Rbase
Require
Import
ZOdiv
Definition
unit
unit
Parameter
mark
Type
Parameter
at1
forall
a
Type
a
mark
a
Implicit
Arguments
at1
Parameter
old
forall
a
Type
a
a
Implicit
Arguments
old
Axiom
Abs_le
forall
x
Z
y
Z
Zabs
x
y
Z
y
Z
x
Z
x
y
Z
Parameter
power
Z
Z
Z
Axiom
Power_0
forall
x
Z
power
x
Z
Z
Axiom
Power_s
forall
x
Z
n
Z
Z
n
Z
power
x
n
x
power
x
n
Z
Z
Z
Axiom
Power_1
forall
x
Z
power
x
Z
x
Axiom
Power_sum
forall
x
Z
n
Z
m
Z
Z
n
Z
Z
m
Z
power
x
n
m
Z
power
x
n
power
x
m
Z
Axiom
Power_mult
forall
x
Z
n
Z
m
Z
Z
n
Z
Z
m
Z
power
x
n
m
Z
power
power
x
n
m
Axiom
Power_mult2
forall
x
Z
y
Z
n
Z
Z
n
Z
power
x
y
Z
n
power
x
n
power
y
n
Z
Inductive
ref
a
Type
mk_ref
a
ref
a
Implicit
Arguments
mk_ref
Definition
contents
a
Type
u
ref
a
a
match
u
mk_ref
contents1
contents1
Implicit
Arguments
contents
YOU
MAY
EDIT
THE
CONTEXT
BELOW
DO
NOT
EDIT
BELOW
Theorem
forall
x
Z
forall
n
Z
Z
n
Z
forall
e
Z
forall
p
Z
forall
r
Z
Z
e
Z
r
power
p
e
Z
power
x
n
Z
e
Z
ZOmod
e
2
Z
Z
forall
p1
Z
p1
p
p
Z
forall
e1
Z
e1
ZOdiv
e
2
Z
r
power
p1
e1
Z
power
x
n
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
x
n
Hn
e0
p0
r0
He0
Hind
intros
He0
Hmod
p1
Hp
e1
He
rewrite
Hind
apply
f_equal
subst
assert
h
e0
e0
2
e0
2
Z
assert
e0
mod
2
generalize
ZOmod_lt_pos
e0
2
unfold
Zabs
omega
rewrite
ZO_div_mod_eq
e0
2
at
omega
rewrite
Power_mult2
auto
zarith
rewrite
h
at
3.
rewrite
Power_sum
omega
Qed
DO
NOT
EDIT
BELOW
