Commit 1267c59a authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
fixed bug #13853 (mutual recursive functions and exceptions)
parent fabf5327
module T
use import int.Int
exception MyExc
(* g can raise MyExc *)
let rec f (x: int) : int = {} raise MyExc {} | MyExc -> {}
with g (x: int) : int = {} f x {} | MyExc -> {}
Local Variables:
compile-command: "unset LANG; make -C ../../.. bench/programs/good/mutual_exns"
End:
...@@ -1763,9 +1763,9 @@ and expr_desc gl env loc ty = function ...@@ -1763,9 +1763,9 @@ and expr_desc gl env loc ty = function
let c = type_c env c in let c = type_c env c in
Eany c, c.c_result_type, c.c_effect Eany c, c.c_result_type, c.c_effect
and triple gl env (p, e, q) = and triple ?(sat_exn=false) gl env (p, e, q) =
let e = expr gl env e in let e = expr gl env e in
let q = saturation e.expr_loc e.expr_effect q in let q = if sat_exn then saturation e.expr_loc e.expr_effect q else q in
let ef = e.expr_effect in let ef = e.expr_effect in
let ef, p = term_effect ef p in let ef, p = term_effect ef p in
let ef, q = post_effect ef q in let ef, q = post_effect ef q in
...@@ -1811,11 +1811,11 @@ and letrec gl env dl = (* : env * recfun list *) ...@@ -1811,11 +1811,11 @@ and letrec gl env dl = (* : env * recfun list *)
in in
List.fold_left add1 env dl List.fold_left add1 env dl
in in
let one_step m0 = let one_step ?(sat_exn=false) m0 =
let type1 m (i, bl, env, var, t) = let type1 m (i, bl, env, var, t) =
let decvar = option_map (fun (v,_,_) -> v.pv_pure) var in let decvar = option_map (fun (v,_,_) -> v.pv_pure) var in
let env = make_env env ?decvar m0 in let env = make_env env ?decvar m0 in
let t, c = triple gl env t in let t, c = triple ~sat_exn gl env t in
let v = create_pvsymbol (id_clone i.i_impure.vs_name) (tarrow bl c) let v = create_pvsymbol (id_clone i.i_impure.vs_name) (tarrow bl c)
~effect:i.i_effect ~pure:i.i_pure ~effect:i.i_effect ~pure:i.i_pure
in in
...@@ -1825,7 +1825,7 @@ and letrec gl env dl = (* : env * recfun list *) ...@@ -1825,7 +1825,7 @@ and letrec gl env dl = (* : env * recfun list *)
in in
let rec fixpoint m = let rec fixpoint m =
(* printf "fixpoint...@\n"; *) (* printf "fixpoint...@\n"; *)
let m', dl' = one_step m in let m', _ = one_step m in
let same_effect (i,bl,_,_,_) = let same_effect (i,bl,_,_,_) =
let c = Mvs.find i.i_impure m and c' = Mvs.find i.i_impure m' in let c = Mvs.find i.i_impure m and c' = Mvs.find i.i_impure m' in
let v = tarrow bl c and v' = tarrow bl c' in let v = tarrow bl c and v' = tarrow bl c' in
...@@ -1834,7 +1834,10 @@ and letrec gl env dl = (* : env * recfun list *) ...@@ -1834,7 +1834,10 @@ and letrec gl env dl = (* : env * recfun list *)
eq_type_v v v' eq_type_v v v'
(* E.equal c.c_effect c'.c_effect *) (* E.equal c.c_effect c'.c_effect *)
in in
if List.for_all same_effect dl then m, dl' else fixpoint m' if List.for_all same_effect dl then
one_step ~sat_exn:true m
else
fixpoint m'
in in
let add_empty_effect m (i, bl, _, _, (p, _, q)) = let add_empty_effect m (i, bl, _, _, (p, _, q)) =
let tyl, ty = uncurrying i.i_impure.vs_ty in let tyl, ty = uncurrying i.i_impure.vs_ty in
