Commit 119e2920 authored by MARCHE Claude's avatar MARCHE Claude
Examples fibonacci and edit_distance updated
parent 4a5df15c
......@@ -21,6 +21,10 @@ theory Word
use export list.Length
type char
val eq (c1 c2:char) : bool
ensures { result <-> c1 = c2 }
type word = list char
inductive dist word word int =
......@@ -158,7 +162,7 @@ module EditDistance
invariant { min_suffix w1 w2 (i+1) (j+1) !oldt }
let temp = !oldt in
oldt := t[j];
if w1[i] = w2[j] then
if eq w1[i] w2[j] then
t[j] <- temp
else
t[j] <- (min t[j] t[j + 1]) + 1
......@@ -283,18 +283,19 @@ module FibonacciLogarithmic
use import int.Int
use import int.Fibonacci
use import int.EuclideanDivision
use import int.ComputerDivision
use import Mat22
constant m1110 : t = { a11 = 1; a12 = 1;
a21 = 1; a22 = 0 }
val constant m1110 : t
ensures { result = { a11 = 1; a12 = 1;
a21 = 1; a22 = 0 } }
(* computes ((1 1) (1 0))^n in O(log(n)) time
since it is a matrix of the shape ((a+b b) (b a)),
we only return the pair (a, b) *)
let rec logfib n variant { n }
let rec logfib (n:int) variant { n }
requires { n >= 0 }
ensures { let a, b = result in
power m1110 n = { a11 = a+b; a12 = b; a21 = b; a22 = a } }
......@@ -317,9 +318,11 @@ module FibonacciLogarithmic
thus, we can compute F(n) in O(log(n)) using funtion logfib above
lemma fib_m :
forall n: int. n >= 0 ->
let p = power m1110 n in fib (n+1) = p.a11 /\ fib n = p.a21
let rec lemma fib_m (n: int)
requires { n >= 0 }
variant { n }
ensures { let p = power m1110 n in fib (n+1) = p.a11 /\ fib n = p.a21 }
= if n = 0 then () else fib_m (n-1)
let fibo n requires { n >= 0 } ensures { result = fib n } =
let _, b = logfib n in b
