Commit 112aa37f authored by MARCHE Claude's avatar MARCHE Claude
install why.o
parent f5efdfc0
...@@ -234,6 +234,7 @@ install_no_local_lib:: ...@@ -234,6 +234,7 @@ install_no_local_lib::
cp -f src/why3.cm* $(OCAMLLIB)/why3 cp -f src/why3.cm* $(OCAMLLIB)/why3
cp -f META $(OCAMLLIB)/why3 cp -f META $(OCAMLLIB)/why3
if test -f src/why3.a; then cp -f src/why3.a $(OCAMLLIB)/why3; fi if test -f src/why3.a; then cp -f src/why3.a $(OCAMLLIB)/why3; fi
if test -f src/why3.o; then cp -f src/why3.o $(OCAMLLIB)/why3; fi
ifeq (@enable_local@,yes) ifeq (@enable_local@,yes)
install install-lib: install install-lib:
