Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit 0d0a403d authored by Francois Bobot's avatar Francois Bobot
Un peu de documentation
parent 50f410a8
......@@ -17,22 +17,39 @@
(** Call provers and parse there outputs *)
type prover_answer =
| Valid
| Invalid
| Timeout
| Unknown of string
| Valid
(** The task is valid according to the prover *)
| Invalid
(** The task is invalid *)
| Timeout
(** the task timeout, ie it takes more time than specified*)
| Unknown of string
(** The prover can't determined the validity or not of the task *)
| Failure of string
| HighFailure
(** The prover report a failure *)
| HighFailure
(** An error occured during the call to the prover or none of
the given regexp match the output of the prover *)
type prover_result = {
pr_answer : prover_answer;
(* The answer of the prover on the given task*)
pr_output : string;
(* The output of the prover currently stderr and stdout *)
pr_time : float;
(* The time taken by the prover *)
val print_prover_answer : Format.formatter -> prover_answer -> unit
(** Pretty-print a {! prover_answer} *)
val print_prover_result : Format.formatter -> prover_result -> unit
(** Pretty-print a prover_result. The answer and the time are output.
The output of the prover is printed if and only if the answer is an
[HighFailure] *)
val call_on_buffer :
?debug : bool ->
......@@ -44,4 +61,6 @@ val call_on_buffer :
filename : string ->
Buffer.t ->
unit -> prover_result
(** Call a prover on the task printed in the {!type: Buffer.t} given.
@param debug : set the debug flag.
Print on stderr the commandline called and the output of the prover. *)
......@@ -17,7 +17,7 @@
(** Drivers for calling external provers *)
(** Manage Why drivers *)
open Format
open Util
......@@ -17,6 +17,8 @@
(** Apply printers and registered transformations mentionned in drivers *)
val print_task : Driver.driver -> Format.formatter -> Task.task -> unit
val prove_task :
......@@ -119,16 +119,17 @@ val catch_unsupportedtype : (Ty.ty -> 'a) -> (Ty.ty -> 'a)
(** [catch_unsupportedtype f] return a function which applied on [arg] :
- return [f arg] if [f arg] doesn't raise the {!
Unsupported} exception.
- raise [unsupportedType (arg,s)] if [f arg] raises [Unsupported s]*)
- raise [Error (unsupportedType (arg,s))] if [f arg]
val catch_unsupportedterm : (Term.term -> 'a) -> (Term.term -> 'a)
(** same as {! catch_unsupportedtype} but raise {!
UnsupportedExpression} instead of {! UnsupportedType}*)
(** same as {! catch_unsupportedtype} but use [UnsupportedExpression]
instead of [UnsupportedType]*)
val catch_unsupportedfmla : (Term.fmla -> 'a) -> (Term.fmla -> 'a)
val catch_unsupportedDeclaration : (Decl.decl -> 'a) -> (Decl.decl -> 'a)
UnsupportedDeclaration} instead of {! UnsupportedType}*)
[UnsupportedDeclaration] instead of [UnsupportedType] *)
(** Manage the config file of Why *)
open Util
type config_prover = {
......@@ -17,3 +17,7 @@
(** A transformation between polymorphic logic and multi-sorted logic*)
(** {{:http://www.lri.fr/~lescuyer/pdf/CADE-CL07.ps}
Handling Polymorphism in Automated Deduction}.
Jean-Francois Couchot et Stephane Lescuyer *)
(* Copyright (C) 2010- *)
(* Francois Bobot *)
(* Jean-Christophe Filliatre *)
(* Johannes Kanig *)
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
(** Move the conjunctions to top level and split the axiom or goal *)
val split_pos_goal : Task.task Register.tlist_reg
val split_pos_neg_goal : Task.task Register.tlist_reg
val split_pos_axiom : Task.task Register.tlist_reg
val split_pos_neg_axiom : Task.task Register.tlist_reg
val split_pos_all : Task.task Register.tlist_reg
val split_pos_neg_all : Task.task Register.tlist_reg
(** naming convention :
- pos : move the conjuctions in positive sub-formula to top level
- pos : move the conjuctions in negative sub-formula to top level
- goal : apply the transformation only to goal
- axiom : apply the transformation only to axioms
- all : apply the transformation to goal and axioms *)
(** Hash tables for hash consing *)
(*s Hash tables for hash consing.
Hash consed values are of the
(** Hashtable with weak key used for memoization *)
module type S = sig
type key
......@@ -25,6 +25,7 @@
(** Parse rc files *)
type rc_value =
| RCint of int
......@@ -44,8 +45,8 @@ val string : rc_value -> string
val from_file : string -> (string list * (string * rc_value) list) list
(** returns the records of the file [f]
@raises Not_found is f does not exists
@raises Failure "lexing" in case of incorrect syntax *)
@raise Not_found is f does not exists
@raise Failure "lexing" in case of incorrect syntax *)
val get_home_dir : unit -> string
(** returns the home dir of the user *)
(** Useful functions *)
(* useful option combinators *)
val of_option : 'a option -> 'a
