Commit 0c051a6e authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
code for Array.fill
parent 1c0ee079
......@@ -65,10 +65,18 @@ module Array
{ length result = length a and
forall i:int. 0 <= i < length result -> result[i] = a[i] }
parameter fill : a:array 'a -> ofs:int -> len:int -> v:'a ->
let fill (a:array 'a) (ofs:int) (len:int) (v:'a) =
{ 0 <= ofs and ofs + len <= length a }
unit
writes a
label Init:
for k = 0 to len - 1 do
invariant {
(forall i:int.
(0 <= i < ofs or ofs + len <= i < length a) -> a[i] = (at a Init)[i])
(forall i:int. ofs <= i < ofs + k -> a[i] = v)
a[ofs + k] <- v
done
{ (forall i:int.
(0 <= i < ofs or ofs + len <= i < length a) -> a[i] = (old a)[i])
......@@ -169,7 +177,9 @@ module TestArray
let test_fill () =
let a = make 17 True in
fill a 10 4 False;
assert { a[10] = False }
assert { a[9] = True };
assert { a[10] = False };
assert { a[14] = True }
let test_blit () =
let a1 = make 17 True in
