Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 0b83243e authored by MARCHE Claude's avatar MARCHE Claude
FoVeOOS competition
parent 0241585e
COST Verification Competition. vladimir@cost-ic0701.org
Challenge 1: Maximum in an array
Given: A non-empty integer array a.
Verify that the index returned by the method max() given below points to
an element maximal in the array.
module ArrayMax
use import int.Int
use import int.MinMax
use import module ref.Ref
use import module array.Array
let max (a: array int) =
{ 0 < length a }
let x = ref 0 in
let y = ref (length a - 1) in
while !x <> !y do
invariant { 0 <= !x <= !y < length a /\
forall i:int.
0 <= i < !x \/ !y < i < length a ->
a[i] <= max a[!x] a[!y]
variant { !y - !x }
if a[!x] <= a[!y] then x := !x+1 else y := !y-1
done;
!x
{ 0 <= result < length a /\
forall i:int. 0 <= i < a.length -> a[i] <= a[result] }
Local Variables:
compile-command: "why3ide array_max.mlw"
End:
