Commit 0affb677 authored by Andrei Paskevich's avatar Andrei Paskevich
Mlw: cloning (wip)
parent 1312788c
...@@ -103,11 +103,11 @@ type pmodule = { ...@@ -103,11 +103,11 @@ type pmodule = {
and mod_unit = and mod_unit =
| Udecl of pdecl | Udecl of pdecl
| Uuse of pmodule | Uuse of pmodule
| Uinst of mod_inst | Uclone of mod_inst
| Umeta of meta * meta_arg list | Umeta of meta * meta_arg list
| Uscope of string * bool * mod_unit list | Uscope of string * bool * mod_unit list
and mod_inst = private { and mod_inst = {
mi_mod : pmodule; mi_mod : pmodule;
mi_ts : itysymbol Mts.t; mi_ts : itysymbol Mts.t;
mi_ls : lsymbol Mls.t; mi_ls : lsymbol Mls.t;
...@@ -166,6 +166,9 @@ let open_scope uc s = match uc.muc_import with ...@@ -166,6 +166,9 @@ let open_scope uc s = match uc.muc_import with
let close_scope uc ~import = let close_scope uc ~import =
let th = Theory.close_scope uc.muc_theory ~import in let th = Theory.close_scope uc.muc_theory ~import in
match List.rev uc.muc_units, uc.muc_import, uc.muc_export with match List.rev uc.muc_units, uc.muc_import, uc.muc_export with
| [Uscope (_,_,ul1)], _ :: sti, _ :: ste -> (* empty scope *)
{ uc with muc_theory = th; muc_units = ul1;
muc_import = sti; muc_export = ste; }
| Uscope (s,_,ul1) :: ul0, _ :: i1 :: sti, e0 :: e1 :: ste -> | Uscope (s,_,ul1) :: ul0, _ :: i1 :: sti, e0 :: e1 :: ste ->
let i1 = if import then merge_ns false e0 i1 else i1 in let i1 = if import then merge_ns false e0 i1 else i1 in
let _ = if import then merge_ns true e0 e1 else e1 in let _ = if import then merge_ns true e0 e1 else e1 in
...@@ -368,17 +371,18 @@ let rec cl_find_its cl its = ...@@ -368,17 +371,18 @@ let rec cl_find_its cl its =
match its.its_def with match its.its_def with
| Some _ -> cl_make_its_alias cl its | Some _ -> cl_make_its_alias cl its
| None -> its | None -> its
else try Mts.find its.its_ts cl.ts_table else (*try*) Mts.find its.its_ts cl.ts_table
with Not_found -> cl_make_its_pure cl its (* with Not_found -> cl_make_its_pure cl its*)
and cl_find_ts cl ts = and cl_find_ts cl ts =
if not (Sid.mem ts.ts_name cl.cl_local) then if not (Sid.mem ts.ts_name cl.cl_local) then
match ts.ts_def with match ts.ts_def with
| Some _ -> (cl_make_its_alias cl (restore_its ts)).its_ts | Some _ -> (cl_make_its_alias cl (restore_its ts)).its_ts
| None -> ts | None -> ts
else try (Mts.find ts cl.ts_table).its_ts else (*try*) (Mts.find ts cl.ts_table).its_ts
with Not_found -> (cl_make_its_pure cl (restore_its ts)).its_ts (* with Not_found -> (cl_make_its_pure cl (restore_its ts)).its_ts*)
and cl_make_its_pure cl ({its_ts = ts} as its) = and cl_make_its_pure cl ({its_ts = ts} as its) =
let id = id_clone ts.ts_name in let id = id_clone ts.ts_name in
let nts = match its.its_def with let nts = match its.its_def with
...@@ -386,6 +390,7 @@ and cl_make_its_pure cl ({its_ts = ts} as its) = ...@@ -386,6 +390,7 @@ and cl_make_its_pure cl ({its_ts = ts} as its) =
| None -> create_itysymbol_pure id ts.ts_args in | None -> create_itysymbol_pure id ts.ts_args in
cl.ts_table <- Mts.add its.its_ts nts cl.ts_table; cl.ts_table <- Mts.add its.its_ts nts cl.ts_table;
nts nts
and cl_make_its_alias cl its = and cl_make_its_alias cl its =
let odf = Opt.get its.its_def in let odf = Opt.get its.its_def in
...@@ -427,9 +432,9 @@ let cl_find_ls cl ls = ...@@ -427,9 +432,9 @@ let cl_find_ls cl ls =
ls' ls'
let _cl_trans_fmla cl f = t_s_map (cl_trans_ty cl) (cl_find_ls cl) f let cl_trans_fmla cl f = t_s_map (cl_trans_ty cl) (cl_find_ls cl) f
let _cl_find_pr cl pr = let cl_find_pr cl pr =
if not (Sid.mem pr.pr_name cl.cl_local) then pr if not (Sid.mem pr.pr_name cl.cl_local) then pr
else (*try*) Mpr.find pr cl.pr_table else (*try*) Mpr.find pr cl.pr_table
...@@ -439,18 +444,19 @@ let _cl_find_pr cl pr = ...@@ -439,18 +444,19 @@ let _cl_find_pr cl pr =
pr' pr'
let _cl_find_pv cl pv = let cl_find_pv cl pv =
if not (Sid.mem pv.pv_vs.vs_name cl.cl_local) then pv if not (Sid.mem pv.pv_vs.vs_name cl.cl_local) then pv
else Mpv.find pv cl.pv_table else Mpv.find pv cl.pv_table
let _cl_find_rs cl rs = let cl_find_rs cl rs =
if not (Sid.mem rs.rs_name cl.cl_local) then rs if not (Sid.mem rs.rs_name cl.cl_local) then rs
else Mrs.find rs cl.rs_table else Mrs.find rs cl.rs_table
let _cl_find_xs cl xs = let cl_find_xs cl xs =
if not (Sid.mem xs.xs_name cl.cl_local) then xs if not (Sid.mem xs.xs_name cl.cl_local) then xs
else Mexn.find xs cl.xs_table else Mexn.find xs cl.xs_table
(* initialize the clone structure *) (* initialize the clone structure *)
let cl_init_ts cl ({ts_name = id} as ts) ts' = let cl_init_ts cl ({ts_name = id} as ts) ts' =
...@@ -460,37 +466,137 @@ let cl_init_ts cl ({ts_name = id} as ts) ts' = ...@@ -460,37 +466,137 @@ let cl_init_ts cl ({ts_name = id} as ts) ts' =
then raise (BadInstance (id, ts'.ts_name)); then raise (BadInstance (id, ts'.ts_name));
cl.ts_table <- Mts.add ts (restore_its ts') cl.ts_table cl.ts_table <- Mts.add ts (restore_its ts') cl.ts_table
let cl_init_ls cl ({ls_name = id} as ls) ls' = let cl_clone_ls inst cl ls =
if not (Sid.mem id cl.cl_local) then raise (NonLocal id); if Mls.mem ls inst.inst_ls then raise (CannotInstantiate ls.ls_name);
(* TODO: check later let constr = ls.ls_constr in
let mtch sb ty ty' = let id = id_clone ls.ls_name in
try ty_match sb ty' (cl_trans_ty cl ty) let at = List.map (cl_trans_ty cl) ls.ls_args in
with TypeMismatch _ -> raise (BadInstance (id, ls'.ls_name)) let vt = Opt.map (cl_trans_ty cl) ls.ls_value in
in let ls' = create_lsymbol ~constr id at vt in
let sb = match ls.ls_value,ls'.ls_value with cl.ls_table <- Mls.add ls ls' cl.ls_table;
ls'
let cl_add_ls cl ({ls_name = id} as ls) ({ls_name = id'} as ls') =
let mtch sb ty ty' = try ty_match sb ty' (cl_trans_ty cl ty)
with TypeMismatch _ -> raise (BadInstance (id, id')) in
let sbs = match ls.ls_value,ls'.ls_value with
| Some ty, Some ty' -> mtch Mtv.empty ty ty' | Some ty, Some ty' -> mtch Mtv.empty ty ty'
| None, None -> Mtv.empty | None, None -> Mtv.empty
| _ -> raise (BadInstance (id, ls'.ls_name)) | _ -> raise (BadInstance (id, id')) in
in ignore (try List.fold_left2 mtch sbs ls.ls_args ls'.ls_args
ignore (try List.fold_left2 mtch sb ls.ls_args ls'.ls_args with Invalid_argument _ -> raise (BadInstance (id, id')));
with Invalid_argument _ -> raise (BadInstance (id, ls'.ls_name)));
cl.ls_table <- Mls.add ls ls' cl.ls_table cl.ls_table <- Mls.add ls ls' cl.ls_table
let cl_init_pr cl {pr_name = id} = let cl_found_ls inst cl uc ls =
if not (Sid.mem id cl.cl_local) then raise (NonLocal id) let nls = match Mls.find_opt ls inst.inst_ls with
| None ->
let _cl_init th inst = let ns = Theory.get_namespace uc.muc_theory in
let cl = empty_clones th.th_local in (try Some (ns_find_ls ns [ls.ls_name.id_string])
Mts.iter (cl_init_ts cl) inst.inst_ts; with Not_found -> None)
Mls.iter (cl_init_ls cl) inst.inst_ls; | nls -> nls in
Spr.iter (cl_init_pr cl) inst.inst_lemma; match nls with
Spr.iter (cl_init_pr cl) inst.inst_goal; | Some ls' -> cl_add_ls cl ls ls'; true
cl | None -> false
(* clone declarations *) (* clone declarations *)
let clone_decl inst cl uc d = match d.d_node with
| Dtype _ | Ddata _ -> assert false
| Dparam ls ->
if cl_found_ls inst cl uc ls then uc else
let d = create_param_decl (cl_clone_ls inst cl ls) in
add_pdecl ~vc:false uc (create_pure_decl d)
| Dlogic ldl ->
let get_ls (ls,_) = ignore (cl_clone_ls inst cl ls) in
let get_logic (_,ld) =
Opt.get (ls_defn_of_axiom (cl_trans_fmla cl (ls_defn_axiom ld))) in
List.iter get_ls ldl;
let d = create_logic_decl (List.map get_logic ldl) in
| Dind (s, idl) ->
let get_ls (ls,_) = cl_clone_ls inst cl ls in
let get_case (pr,f) =
if Spr.mem pr inst.inst_lemma || Spr.mem pr inst.inst_goal
then raise (CannotInstantiate pr.pr_name);
let pr' = create_prsymbol (id_clone pr.pr_name) in
cl.pr_table <- Mpr.add pr pr' cl.pr_table;
pr', cl_trans_fmla cl f in
let get_ind ls (_,la) = ls, List.map get_case la in
let lls = List.map get_ls idl in
let d = create_ind_decl s (List.map2 get_ind lls idl) in
| Dprop (k,pr,f) ->
let k' = match k with
| Pskip | Pgoal -> Pskip
| Plemma when Spr.mem pr inst.inst_goal -> Pskip
| Paxiom when Spr.mem pr inst.inst_goal -> Pgoal
| Paxiom when Spr.mem pr inst.inst_lemma -> Plemma
| Paxiom -> Paxiom (* TODO: Plemma *)
| Plemma -> Paxiom in
let d = create_prop_decl k' pr' (cl_trans_fmla cl f) in
let clone_pdecl inst cl uc d = match d.pd_node with
| PDtype _tdl -> assert false (* TODO *)
| PDlet _ld -> assert false (* TODO *)
| PDexn xs ->
let ity = cl_trans_ity cl xs.xs_ity in
let xs' = create_xsymbol (id_clone xs.xs_name) ity in
cl.xs_table <- Mexn.add xs xs' cl.xs_table;
add_pdecl ~vc:false uc (create_exn_decl xs')
| PDpure ->
List.fold_left (clone_decl inst cl) uc d.pd_pure
let add_clone uc mi =
(* TODO: add TDclone to the muc_theory *)
{ uc with muc_units = Uclone mi :: uc.muc_units }
let clone_export uc m inst =
let check_local id =
if not (Sid.mem id m.mod_local) then raise (NonLocal id) in
Mts.iter (fun ts _ -> check_local ts.ts_name) inst.inst_ts;
Mls.iter (fun ls _ -> check_local ls.ls_name) inst.inst_ls;
Spr.iter (fun pr -> check_local pr.pr_name) inst.inst_goal;
Spr.iter (fun pr -> check_local pr.pr_name) inst.inst_lemma;
let cl = empty_clones m.mod_local in
let rec add_unit uc u = match u with
| Udecl d -> clone_pdecl inst cl uc d
| Uuse m -> use_export uc m
| Uclone mi ->
add_clone uc { mi_mod = mi.mi_mod;
mi_ts = Mts.map (cl_find_its cl) mi.mi_ts;
mi_ls = Mls.map (cl_find_ls cl) mi.mi_ls;
mi_pr = Mpr.map (cl_find_pr cl) mi.mi_pr;
mi_pv = Mpv.map (cl_find_pv cl) mi.mi_pv;
mi_rs = Mrs.map (cl_find_rs cl) mi.mi_rs;
mi_xs = Mexn.map (cl_find_xs cl) mi.mi_xs}
| Umeta (m,al) ->
let cl_marg = function
| MAty ty -> MAty (cl_trans_ty cl ty)
| MAts ts -> MAts (cl_find_ts cl ts)
| MAls ls -> MAls (cl_find_ls cl ls)
| MApr pr -> MApr (cl_find_pr cl pr)
| a -> a in
add_meta uc m (List.map cl_marg al)
| Uscope (n,import,ul) ->
let uc = open_scope uc n in
let uc = List.fold_left add_unit uc ul in
close_scope ~import uc in
let uc = List.fold_left add_unit uc m.mod_units in
let mi = {
mi_mod = m;
mi_ts = cl.ts_table;
mi_ls = cl.ls_table;
mi_pr = cl.pr_table;
mi_pv = cl.pv_table;
mi_rs = cl.rs_table;
mi_xs = cl.xs_table} in
add_clone uc mi
let cl_type cl inst ts = let cl_type cl inst ts =
if Mts.mem ts inst.inst_ts then if Mts.mem ts inst.inst_ts then
...@@ -570,73 +676,7 @@ let cl_decl cl inst d = match d.d_node with ...@@ -570,73 +676,7 @@ let cl_decl cl inst d = match d.d_node with
| Dlogic ldl -> cl_logic cl inst ldl | Dlogic ldl -> cl_logic cl inst ldl
| Dind idl -> cl_ind cl inst idl | Dind idl -> cl_ind cl inst idl
| Dprop p -> cl_prop cl inst p | Dprop p -> cl_prop cl inst p
let cl_marg cl = function
| a -> a
let cl_smap cl sm = {
sm_ts = Mts.map (cl_find_ts cl) sm.sm_ts;
sm_ls = Mls.map (cl_find_ls cl) sm.sm_ls;
sm_pr = Mpr.map (cl_find_pr cl) sm.sm_pr}
let cl_tdecl cl inst td = match td.td_node with
| Decl d -> Decl (cl_decl cl inst d)
| Use th -> Use th
| Clone (th,sm) -> Clone (th, cl_smap cl sm)
| Meta (id,al) -> Meta (id, List.map (cl_marg cl) al)
let clone_theory cl add_td acc th inst =
let add acc td =
let td =
try Some (mk_tdecl (cl_tdecl cl inst td))
with EmptyDecl -> None
in
Opt.fold add_td acc td
in
let acc = List.fold_left add acc th.th_decls in
let sm = {
sm_ts = cl.ts_table;
sm_ls = cl.ls_table;
sm_pr = cl.pr_table}
in
add_td acc (mk_tdecl (Clone (th, sm)))
let clone_export muc m inst =
let cl = cl_init th inst in
let uc = clone_theory cl add_tdecl uc th inst in
let g_ts _ ts = not (Mts.mem ts inst.inst_ts) in
let g_ls _ ls = not (Mls.mem ls inst.inst_ls) in
let f_ts p ts =
try let ts = Mts.find ts cl.ts_table in store_path uc p ts.ts_name; ts
with Not_found -> ts in
let f_ls p ls =
try let ls = Mls.find ls cl.ls_table in store_path uc p ls.ls_name; ls
with Not_found -> ls in
let f_pr p pr =
try let pr = Mpr.find pr cl.pr_table in store_path uc p pr.pr_name; pr
with Not_found -> pr in
let rec f_ns p ns = {
ns_ts = Mstr.map (f_ts p) (Mstr.filter g_ts ns.ns_ts);
ns_ls = Mstr.map (f_ls p) (Mstr.filter g_ls ns.ns_ls);
ns_pr = Mstr.map (f_pr p) ns.ns_pr;
ns_ns = Mstr.mapi (fun n -> f_ns (n::p)) ns.ns_ns; } in
let ns = f_ns [] th.th_export in
match uc.uc_import, uc.uc_export with
| i0 :: sti, e0 :: ste -> { uc with
uc_import = merge_ns false ns i0 :: sti;
uc_export = merge_ns true ns e0 :: ste; }
| _ -> assert false
let clone_export _muc _m _inst = assert false (* TODO *)
(** {2 WhyML language} *) (** {2 WhyML language} *)
...@@ -695,14 +735,14 @@ let print_mname fmt {mod_theory = th} = ...@@ -695,14 +735,14 @@ let print_mname fmt {mod_theory = th} =
let rec print_unit fmt = function let rec print_unit fmt = function
| Udecl d -> Pdecl.print_pdecl fmt d | Udecl d -> Pdecl.print_pdecl fmt d
| Uuse m -> Format.fprintf fmt "use export %a" print_mname m | Uuse m -> Format.fprintf fmt "use export %a" print_mname m
| Uinst mi -> Format.fprintf fmt "clone export %a with ..." | Uclone mi -> Format.fprintf fmt "clone export %a with ..."
print_mname mi.mi_mod print_mname mi.mi_mod
| Umeta (m,al) -> Format.fprintf fmt "@[<hov 2>meta %s %a@]" | Umeta (m,al) -> Format.fprintf fmt "@[<hov 2>meta %s %a@]"
m.meta_name (Pp.print_list Pp.comma Pretty.print_meta_arg) al m.meta_name (Pp.print_list Pp.comma Pretty.print_meta_arg) al
| Uscope (s,i,[Uuse m]) -> Format.fprintf fmt "use%s %a%s" | Uscope (s,i,[Uuse m]) -> Format.fprintf fmt "use%s %a%s"
(if i then " import" else "") print_mname m (if i then " import" else "") print_mname m
(if s = m.mod_theory.th_name.id_string then "" else " as " ^ s) (if s = m.mod_theory.th_name.id_string then "" else " as " ^ s)
| Uscope (s,i,[Uinst mi]) -> Format.fprintf fmt "clone%s %a%s with ..." | Uscope (s,i,[Uclone mi]) -> Format.fprintf fmt "clone%s %a%s with ..."
(if i then " import" else "") print_mname mi.mi_mod (if i then " import" else "") print_mname mi.mi_mod
(if s = mi.mi_mod.mod_theory.th_name.id_string then "" else " as " ^ s) (if s = mi.mi_mod.mod_theory.th_name.id_string then "" else " as " ^ s)
| Uscope (s,i,ul) -> Format.fprintf fmt "@[<hov 2>scope%s %s@\n%a@]@\nend" | Uscope (s,i,ul) -> Format.fprintf fmt "@[<hov 2>scope%s %s@\n%a@]@\nend"
...@@ -56,7 +56,7 @@ type pmodule = private { ...@@ -56,7 +56,7 @@ type pmodule = private {
