Commit 0a224a4a authored by Andrei Paskevich's avatar Andrei Paskevich
no more "Kept" theories
parent e6c48023
...@@ -107,11 +107,6 @@ theory bool.Bool ...@@ -107,11 +107,6 @@ theory bool.Bool
end end
theory transform.encoding_decorate.Kept
meta cloned "encoding_decorate : kept" type t
Local Variables: Local Variables:
mode: why mode: why
...@@ -66,10 +66,6 @@ theory int.Int ...@@ -66,10 +66,6 @@ theory int.Int
remove prop Total remove prop Total
end end
mode: why mode: why
...@@ -121,10 +121,6 @@ theory int.EuclideanDivision ...@@ -121,10 +121,6 @@ theory int.EuclideanDivision
remove prop Div_1 remove prop Div_1
end end
mode: why mode: why
...@@ -16,11 +16,6 @@ theory Builtin ...@@ -16,11 +16,6 @@ theory Builtin
t2u (d2t (sort tty x)) = x t2u (d2t (sort tty x)) = x
end end
theory Kept
(* If a driver tags this type by "encoding decorate : kept", all the type which clone this one will be kept by the encoding*)
type t
theory Prelude_mono theory Prelude_mono
logic sort int int : int logic sort int int : int
logic int : int logic int : int
