Commit 08f037e6 authored by Andrei Paskevich's avatar Andrei Paskevich
clone: several bugfixes and missing checks
parent dfb52c23
......@@ -614,13 +614,40 @@ module Context = struct
| Duse _ | Dclone _ ->
d :: acc
exception NonLocal of ident
exception BadInstance of ident * ident
let clone_theory th inst =
let cl = empty_clones th.th_local in
Mts.iter (cl_add_ts cl) inst.inst_ts;
Mls.iter (cl_add_ls cl) inst.inst_ls;
let add = cl_add_decl cl inst in
let decls = ctxt_fold add [] th.th_ctxt in
cl, decls
let check_ts ts ts' = let id = ts.ts_name in
if not (Sid.mem id th.th_local) then raise (NonLocal id);
if List.length ts.ts_args <> List.length ts'.ts_args
then raise (BadInstance (id, ts'.ts_name));
cl_add_ts cl ts ts'
in
let check_ls ls ls' = let id = ls.ls_name in
let tymatch sb ty ty' =
try Ty.matching sb ty' (cl_trans_ty cl ty)
with TypeMismatch -> raise (BadInstance (id, ls'.ls_name))
in
let sb = match ls.ls_value,ls'.ls_value with
| Some ty, Some ty' -> tymatch Mid.empty ty ty'
| None, None -> Mid.empty
| _ -> raise (BadInstance (id, ls'.ls_name))
in
ignore (try List.fold_left2 tymatch sb ls.ls_args ls'.ls_args
with Invalid_argument _ -> raise (BadInstance (id, ls'.ls_name)));
cl_add_ls cl ls ls'
in
let check_pr pr = let id = pr.pr_name in
in
Mts.iter check_ts inst.inst_ts;
Mls.iter check_ls inst.inst_ls;
Spr.iter check_pr inst.inst_lemma;
Spr.iter check_pr inst.inst_goal;
cl, ctxt_fold (cl_add_decl cl inst) [] th.th_ctxt
let add_final ctxt cl =
let add id id' acc = (id,id') :: acc in
......@@ -758,24 +785,34 @@ module Theory = struct
assert false
let clone_export uc th inst =
let cl, ctxt = Context.add_clone uc.uc_ctxt th inst in
let f_ts n t ns = add_ts true n (Hts.find cl.Context.ts_table t) ns in
let f_ls n l ns = add_ls true n (Hls.find cl.Context.ls_table l) ns in
let f_pr n p ns = add_pr true n (Hpr.find cl.Context.pr_table p) ns in
let rec merge_namespace acc ns =
let cl,ctxt = Context.add_clone uc.uc_ctxt th inst in
let add_local _ id' acc =
if Mid.mem id' uc.uc_ctxt.ctxt_known then acc else Sid.add id' acc in
let local = Hid.fold add_local cl.Context.id_table uc.uc_local in
let find_ts ts = if Sid.mem ts.ts_name th.th_local
then Hts.find cl.Context.ts_table ts else ts in
let find_ls ls = if Sid.mem ls.ls_name th.th_local
then Hls.find cl.Context.ls_table ls else ls in
let find_pr pr = if Sid.mem pr.pr_name th.th_local
then Hpr.find cl.Context.pr_table pr else pr in
let f_ts n ts ns = add_ts true n (find_ts ts) ns in
let f_ls n ls ns = add_ls true n (find_ls ls) ns in
let f_pr n pr ns = add_pr true n (find_pr pr) ns in
let rec f_ns n s = add_ns true n (merge_namespace empty_ns s)
and merge_namespace acc ns =
let acc = Mnm.fold f_ts ns.ns_ts acc in
let acc = Mnm.fold f_ls ns.ns_ls acc in
let acc = Mnm.fold f_pr ns.ns_pr acc in
let acc = Mnm.fold f_ns ns.ns_ns acc in acc
and f_ns n ns acc = add_ns true n (merge_namespace empty_ns ns) acc in
let acc = Mnm.fold f_ns ns.ns_ns acc in acc in
let ns = merge_namespace empty_ns th.th_export in
match uc.uc_import, uc.uc_export with
| i0 :: sti, e0 :: ste -> { uc with
uc_import = merge_ns false ns i0 :: sti;
uc_export = merge_ns true ns e0 :: ste;
uc_local = local;
uc_ctxt = ctxt }
| _ ->
assert false
......@@ -160,7 +160,10 @@ module Context : sig
exception UnknownIdent of ident
exception RedeclaredIdent of ident
exception CannotInstantiate of ident
......@@ -1129,16 +1129,24 @@ and add_decl env th = function
| CStsym (p,q) ->
let ts1 = find_tysymbol_ns p t.th_export in
let ts2 = find_tysymbol q th in
if Mts.mem ts1 s.inst_ts
then error ~loc (Clash ts1.ts_name.id_short);
{ s with inst_ts = Mts.add ts1 ts2 s.inst_ts }
| CSlsym (p,q) ->
let ls1 = find_lsymbol_ns p t.th_export in
let ls2 = find_lsymbol q th in
if Mls.mem ls1 s.inst_ls
then error ~loc (Clash ls1.ls_name.id_short);
{ s with inst_ls = Mls.add ls1 ls2 s.inst_ls }
| CSlemma p ->
let pr = find_prop_ns p t.th_export in
if Spr.mem pr s.inst_lemma || Spr.mem pr s.inst_goal
then error ~loc (Clash pr.pr_name.id_short);
{ s with inst_lemma = Spr.add pr s.inst_lemma }
| CSgoal p ->
{ s with inst_goal = Spr.add pr s.inst_goal }
in
let s = List.fold_left add_inst empty_inst s in
