Commit 069f9ece authored by Guillaume Melquiond's avatar Guillaume Melquiond
Fix Coq output of mutually-defined inductive predicates.
parent b422bc17
...@@ -874,24 +874,32 @@ let print_recursive_decl ~old info fmt dl = ...@@ -874,24 +874,32 @@ let print_recursive_decl ~old info fmt dl =
end; end;
List.iter (print_equivalence_lemma ~old info fmt) dl_syn List.iter (print_equivalence_lemma ~old info fmt) dl_syn
let print_ind info fmt (pr,f) = let print_ind info fmt (pr,f) =
fprintf fmt "@[<hov 4>| %a : %a@]" print_pr pr (print_fmla info) f fprintf fmt "@[<hov 4>| %a : %a@]" print_pr pr (print_fmla info) f
let print_ind_decl info s fmt (ps,bl) = let print_ind_decl info fmt ps bl =
let _, _, all_ty_params = ls_ty_vars ps in let _, _, all_ty_params = ls_ty_vars ps in
lsymbols_under_definition := Sls.add ps Sls.empty; lsymbols_under_definition := Sls.add ps Sls.empty;
fprintf fmt "(* Why3 assumption *)@\n@[<hov 2>%s %a %a: %aProp :=@ @[<hov>%a@].@]@\n" fprintf fmt " %a %a: %aProp :=@ @[<hov>%a@]"
(match s with Ind -> "Inductive" | Coind -> "CoInductive") print_ls ps print_implicit_params all_ty_params
(print_arrow_list (print_ty info)) ps.ls_args (print_arrow_list (print_ty info)) ps.ls_args
(print_list newline (print_ind info)) bl; (print_list newline (print_ind info)) bl;
fprintf fmt "@\n";
lsymbols_under_definition := Sls.empty lsymbols_under_definition := Sls.empty
let print_ind_decl info s fmt d = let print_ind_decls info s fmt tl =
if not (Mid.mem (fst d).ls_name info.info_syn) then let none =
(print_ind_decl info s fmt d; forget_tvs ()) List.fold_left (fun first (ps,bl) ->
if Mid.mem ps.ls_name info.info_syn then first
else begin
if first then
fprintf fmt "(* Why3 assumption *)@\n@[<hov 2>%s"
else fprintf fmt "@\nwith";
print_ind_decl info fmt ps bl;
forget_tvs ();
false
end) true tl in
if not none then fprintf fmt ".@]@\n@\n"
let print_prop_decl ~prev info fmt (k,pr,f) = let print_prop_decl ~prev info fmt (k,pr,f) =
ignore prev; ignore prev;
...@@ -944,7 +952,7 @@ let print_decl ~old info fmt d = ...@@ -944,7 +952,7 @@ let print_decl ~old info fmt d =
| Dlogic ll -> | Dlogic ll ->
print_recursive_decl ~old info fmt ll print_recursive_decl ~old info fmt ll
| Dind (s, il) -> | Dind (s, il) ->
print_list nothing (print_ind_decl info s) fmt il print_ind_decls info s fmt il
| Dprop (_,pr,_) when not info.realization && Mid.mem pr.pr_name info.info_syn -> | Dprop (_,pr,_) when not info.realization && Mid.mem pr.pr_name info.info_syn ->
| Dprop pr -> | Dprop pr ->
