Commit 05ea6612 authored by MARCHE Claude's avatar MARCHE Claude
fix detection of obsolete sessions in case of empty theories
Since why3replay does not store theories without goals, the next time the
session is reloaded, why3replay would complain the session contains
detached theories.
parent bb20ba6d
...@@ -1302,6 +1302,7 @@ module AssoGoals = Termcode.Pairing(Goal)(Goal) ...@@ -1302,6 +1302,7 @@ module AssoGoals = Termcode.Pairing(Goal)(Goal)
let found_obsolete = ref false let found_obsolete = ref false
let found_detached = ref false let found_detached = ref false
(* FIXME: distinguish found_new_goals and found_detached *)
let save_detached_proof s parent old_pa_n = let save_detached_proof s parent old_pa_n =
let old_pa = old_pa_n in let old_pa = old_pa_n in
...@@ -1534,7 +1535,7 @@ let make_theory_section ?merge ~detached (s:session) parent_name (th:Theory.theo ...@@ -1534,7 +1535,7 @@ let make_theory_section ?merge ~detached (s:session) parent_name (th:Theory.theo
match merge with match merge with
| Some (old_s, old_th, env, use_shapes) -> | Some (old_s, old_th, env, use_shapes) ->
merge_theory ~use_shapes env old_s old_th s theory merge_theory ~use_shapes env old_s old_th s theory
| _ -> () | _ -> if tasks <> [] then found_detached := true (* should be found_new_goals instead of found_detached *)
end; end;
theory theory
...@@ -1584,7 +1585,6 @@ let merge_file_section ~use_shapes ~old_ses ~old_theories ~file_is_detached ~env ...@@ -1584,7 +1585,6 @@ let merge_file_section ~use_shapes ~old_ses ~old_theories ~file_is_detached ~env
make_theory_section ~detached:false ~merge:(old_ses,old_th,env,use_shapes) s fn th make_theory_section ~detached:false ~merge:(old_ses,old_th,env,use_shapes) s fn th
with Not_found -> with Not_found ->
(* if no theory was found we make a new theory section *) (* if no theory was found we make a new theory section *)
found_detached := true;
Debug.dprintf debug_merge "[Session_itp.merge_file_section] theory NOT FOUND in old session: %s@." theory_name; Debug.dprintf debug_merge "[Session_itp.merge_file_section] theory NOT FOUND in old session: %s@." theory_name;
make_theory_section ~detached:false s fn th make_theory_section ~detached:false s fn th
in in
