Commit 05bb92ba authored by Andrei Paskevich's avatar Andrei Paskevich
Parser: "(+)_spec" can be user-defined, "(+)'spec" can not.
parent a8f712d7
This diff is collapsed.
...@@ -239,8 +239,10 @@ rule token = parse ...@@ -239,8 +239,10 @@ rule token = parse
{ RIGHTSQ } { RIGHTSQ }
| "]" (quote+ as s) | "]" (quote+ as s)
{ RIGHTSQ_QUOTE s } { RIGHTSQ_QUOTE s }
| ")" (['\'' '_'] alpha suffix core_suffix* as s) | ")" ('\'' alpha suffix core_suffix* as s)
{ RIGHTPAR_QUOTE s } { RIGHTPAR_QUOTE s }
| ")" ('_' alpha suffix core_suffix* as s)
{ RIGHTPAR_USCORE s }
| op_char_pref op_char_4* quote* as s | op_char_pref op_char_4* quote* as s
{ OPPREF s } { OPPREF s }
| op_char_1234* op_char_1 op_char_1234* quote* as s | op_char_1234* op_char_1 op_char_1234* quote* as s
...@@ -151,6 +151,7 @@ ...@@ -151,6 +151,7 @@
%token <string> QUOTE_LIDENT %token <string> QUOTE_LIDENT
%token <string> RIGHTSQ_QUOTE (* ]'' *) %token <string> RIGHTSQ_QUOTE (* ]'' *)
%token <string> RIGHTPAR_QUOTE (* )'spec *) %token <string> RIGHTPAR_QUOTE (* )'spec *)
%token <string> RIGHTPAR_USCORE (* )_spec *)
(* keywords *) (* keywords *)
...@@ -1263,12 +1264,16 @@ lident_rich: ...@@ -1263,12 +1264,16 @@ lident_rich:
lident_op: lident_op:
| LEFTPAR lident_op_str RIGHTPAR | LEFTPAR lident_op_str RIGHTPAR
{ mk_id $2 $startpos($2) $endpos($2) } { mk_id $2 $startpos($2) $endpos($2) }
| LEFTPAR lident_op_str RIGHTPAR_USCORE
{ mk_id ($2^$3) $startpos $endpos }
| LEFTPAR lident_op_str RIGHTPAR_QUOTE | LEFTPAR lident_op_str RIGHTPAR_QUOTE
{ mk_id ($2^$3) $startpos $endpos } { mk_id ($2^$3) $startpos $endpos }
lident_op_nq: lident_op_nq:
{ let loc = floc $startpos $endpos in { let loc = floc $startpos $endpos in
Loc.errorm ~loc "Symbol (%s)%s cannot be user-defined" $2 $3 } Loc.errorm ~loc "Symbol (%s)%s cannot be user-defined" $2 $3 }
