Commit 02b4a09b authored by Andrei Paskevich's avatar Andrei Paskevich
Undo the last four commits. Never listen to people
coming to you late in the evening and talking French.
parent 5b56b45d
...@@ -43,11 +43,18 @@ let iprinter,tprinter,lprinter,pprinter = ...@@ -43,11 +43,18 @@ let iprinter,tprinter,lprinter,pprinter =
create_ident_printer bl ~sanitizer:lsanitize, create_ident_printer bl ~sanitizer:lsanitize,
create_ident_printer bl ~sanitizer:usanitize create_ident_printer bl ~sanitizer:usanitize
let thash = Hid.create 63
let lhash = Hid.create 63
let phash = Hid.create 63
let forget_all () = let forget_all () =
forget_all iprinter; forget_all iprinter;
forget_all tprinter; forget_all tprinter;
forget_all lprinter; forget_all lprinter;
forget_all pprinter forget_all pprinter;
Hid.clear thash;
Hid.clear lhash;
Hid.clear phash
let tv_set = ref Sid.empty let tv_set = ref Sid.empty
...@@ -77,9 +84,11 @@ let print_th fmt th = ...@@ -77,9 +84,11 @@ let print_th fmt th =
fprintf fmt "%s" n fprintf fmt "%s" n
let print_ts fmt ts = let print_ts fmt ts =
Hid.replace thash ts.ts_name ts;
fprintf fmt "%s" (id_unique tprinter ts.ts_name) fprintf fmt "%s" (id_unique tprinter ts.ts_name)
let print_ls fmt ls = let print_ls fmt ls =
Hid.replace lhash ls.ls_name ls;
let n = if ls.ls_constr let n = if ls.ls_constr
then id_unique lprinter ~sanitizer:String.capitalize ls.ls_name then id_unique lprinter ~sanitizer:String.capitalize ls.ls_name
else id_unique lprinter ls.ls_name else id_unique lprinter ls.ls_name
...@@ -87,6 +96,7 @@ let print_ls fmt ls = ...@@ -87,6 +96,7 @@ let print_ls fmt ls =
let print_pr fmt pr = let print_pr fmt pr =
Hid.replace phash pr.pr_name pr;
fprintf fmt "%s" (id_unique pprinter pr.pr_name) fprintf fmt "%s" (id_unique pprinter pr.pr_name)
(** Types *) (** Types *)
...@@ -302,6 +312,18 @@ let print_prop_decl fmt (k,pr,f) = ...@@ -302,6 +312,18 @@ let print_prop_decl fmt (k,pr,f) =
print_pr pr print_fmla f; print_pr pr print_fmla f;
forget_tvs () forget_tvs ()
let print_inst fmt (id1,id2) =
if Hid.mem thash id2 then
let n = id_unique tprinter id1 in
fprintf fmt "type %s = %a" n print_ts (Hid.find thash id2)
else if Hid.mem lhash id2 then
let n = id_unique lprinter id1 in
fprintf fmt "logic %s = %a" n print_ls (Hid.find lhash id2)
else if Hid.mem phash id2 then
let n = id_unique pprinter id1 in
fprintf fmt "prop %s = %a" n print_pr (Hid.find phash id2)
else assert false
let print_decl fmt d = match d.d_node with let print_decl fmt d = match d.d_node with
| Dtype tl -> print_list newline print_type_decl fmt tl | Dtype tl -> print_list newline print_type_decl fmt tl
| Dlogic ll -> print_list newline print_logic_decl fmt ll | Dlogic ll -> print_list newline print_logic_decl fmt ll
...@@ -313,6 +335,9 @@ let print_tdecl fmt = function ...@@ -313,6 +335,9 @@ let print_tdecl fmt = function
print_decl fmt d print_decl fmt d
| Use th -> | Use th ->
fprintf fmt "@[<hov 2>(* use %a *)@]" print_th th fprintf fmt "@[<hov 2>(* use %a *)@]" print_th th
| Clone (th,inst) ->
fprintf fmt "@[<hov 2>(* clone %a with %a *)@]"
print_th th (print_list comma print_inst) inst
let print_decls fmt dl = let print_decls fmt dl =
fprintf fmt "@[<hov>%a@\n@]" (print_list newline2 print_decl) dl fprintf fmt "@[<hov>%a@\n@]" (print_list newline2 print_decl) dl
...@@ -40,19 +40,11 @@ let cloned_from cl i1 i2 = ...@@ -40,19 +40,11 @@ let cloned_from cl i1 i2 =
try i1 = i2 || Sid.mem i2 (Mid.find i1 cl.cl_map) try i1 = i2 || Sid.mem i2 (Mid.find i1 cl.cl_map)
with Not_found -> false with Not_found -> false
let merge_clone = let add_clone =
let add m id s acc =
let s =
try Sid.union s (Mid.find id m)
with Not_found -> s
in
Mid.add id s acc
in
let r = ref 0 in let r = ref 0 in
fun cl th -> fun cl th sl ->
if Mid.is_empty th.th_clone then cl else incr r;
{ cl_map = Mid.fold (add cl.cl_map) th.th_clone cl.cl_map; { cl_map = merge_clone cl.cl_map th sl; cl_tag = !r }
cl_tag = (incr r; !r) }
(** Known identifiers *) (** Known identifiers *)
...@@ -215,11 +207,13 @@ let rec use_export names acc td = ...@@ -215,11 +207,13 @@ let rec use_export names acc td =
| Use th when Sid.mem th.th_name used -> | Use th when Sid.mem th.th_name used ->
acc acc
let names = Some Spr.empty in
let used = Sid.add th.th_name used in let used = Sid.add th.th_name used in
let cl = merge_clone cl th in
let acc = used, cl, res, task in let acc = used, cl, res, task in
List.fold_left (use_export names) acc th.th_decls List.fold_left (use_export names) acc th.th_decls
| Clone (th,sl) ->
let cl = add_clone cl th sl in
used, cl, res, task
| Decl d -> | Decl d ->
begin match d.d_node with begin match d.d_node with
| Dprop (Pgoal,pr,_) | Dprop (Pgoal,pr,_)
...@@ -89,6 +89,7 @@ type theory = { ...@@ -89,6 +89,7 @@ type theory = {
and tdecl = and tdecl =
| Decl of decl | Decl of decl
| Use of theory | Use of theory
| Clone of theory * (ident * ident) list
and clone_map = Sid.t Mid.t and clone_map = Sid.t Mid.t
...@@ -221,6 +222,11 @@ let merge_clone cl th sl = ...@@ -221,6 +222,11 @@ let merge_clone cl th sl =
in in
List.fold_left (add th.th_clone) cl sl List.fold_left (add th.th_clone) cl sl
let add_clone uc th sl =
let decls = Clone (th,sl) :: uc.uc_decls in
let clone = merge_clone uc.uc_clone th sl in
{ uc with uc_decls = decls; uc_clone = clone }
(** Clone *) (** Clone *)
...@@ -423,22 +429,6 @@ let cl_add_decl cl inst d = match d.d_node with ...@@ -423,22 +429,6 @@ let cl_add_decl cl inst d = match d.d_node with
let pr',f' = cl_new_prop cl (pr,f) in let pr',f' = cl_new_prop cl (pr,f) in
Some (create_prop_decl k' pr' f') Some (create_prop_decl k' pr' f')
let clone_fold add_tdecl v th inst =
let cl = cl_init th inst in
let add acc td = match td with
| Decl d ->
begin match cl_add_decl cl inst d with
| Some d -> add_tdecl acc (Decl d)
| None -> acc
| Use _ ->
add_tdecl acc td
in
let (res,clmap) = List.fold_left add v th.th_decls in
let add_idid id id' acc = (id,id') :: acc in
let sl = Hid.fold add_idid cl.id_table [] in
res, merge_clone clmap th sl
let cl_add_tdecl cl inst uc td = match td with let cl_add_tdecl cl inst uc td = match td with
let decls = match cl_add_decl cl inst d with let decls = match cl_add_decl cl inst d with
...@@ -448,6 +438,8 @@ let cl_add_tdecl cl inst uc td = match td with ...@@ -448,6 +438,8 @@ let cl_add_tdecl cl inst uc td = match td with
{ uc with uc_decls = decls } { uc with uc_decls = decls }
| Use _ -> | Use _ ->
{ uc with uc_decls = td :: uc.uc_decls } { uc with uc_decls = td :: uc.uc_decls }
| Clone (th,sl) ->
add_clone uc th sl
let clone_export uc th inst = let clone_export uc th inst =
let cl = cl_init th inst in let cl = cl_init th inst in
...@@ -456,8 +448,7 @@ let clone_export uc th inst = ...@@ -456,8 +448,7 @@ let clone_export uc th inst =
let add_idid id id' acc = (id,id') :: acc in let add_idid id id' acc = (id,id') :: acc in
let sl = Hid.fold add_idid cl.id_table [] in let sl = Hid.fold add_idid cl.id_table [] in
let cm = merge_clone uc.uc_clone th sl in let uc = add_clone uc th sl in
let uc = { uc with uc_clone = cm } in
let add_local id' () acc = Sid.add id' acc in let add_local id' () acc = Sid.add id' acc in
let lc = Hid.fold add_local cl.nw_local uc.uc_local in let lc = Hid.fold add_local cl.nw_local uc.uc_local in
...@@ -54,6 +54,7 @@ type theory = private { ...@@ -54,6 +54,7 @@ type theory = private {
and tdecl = private and tdecl = private
...@@ -87,8 +88,7 @@ val empty_inst : th_inst ...@@ -87,8 +88,7 @@ val empty_inst : th_inst
val use_export : theory_uc -> theory -> theory_uc val use_export : theory_uc -> theory -> theory_uc
val clone_export : theory_uc -> theory -> th_inst -> theory_uc val clone_export : theory_uc -> theory -> th_inst -> theory_uc
val clone_fold : (('a * clone_map) -> tdecl -> ('a * clone_map)) -> val merge_clone : clone_map -> theory -> (ident * ident) list -> clone_map
('a * clone_map) -> theory -> th_inst -> ('a * clone_map)
(* exceptions *) (* exceptions *)
