Commit 02aa1780 authored by François Bobot's avatar François Bobot
Clean up after commit "Add parameter to encoding_arrays..."
15eb1b44
parent 454aaf47
(* Why driver for SMT syntax *)
prelude ";;; this is a prelude for Z3"
prelude "(set-logic AUFNIRA)"
printer "smtv2"
filename "%f-%t-%g.smt"
valid "^unsat"
unknown "^\\(unknown\\|sat\\|Fail\\)" "Unknown"
time "why3cpulimit time : %s s"
(* À discuter *)
transformation "simplify_recursive_definition"
transformation "inline_trivial"
transformation "eliminate_builtin"
transformation "eliminate_definition"
transformation "eliminate_inductive"
transformation "eliminate_algebraic_smt"
transformation "simplify_formula"
(*transformation "simplify_trivial_quantification"*)
transformation "encoding_smt"
theory BuiltIn
syntax type int "Int"
syntax type real "Real"
syntax logic (=) "(= %1 %2)"
theory int.Int
prelude ";;; this is a prelude for Z3 integer arithmetic"
syntax logic zero "0"
syntax logic one "1"
syntax logic (+) "(+ %1 %2)"
syntax logic (-) "(- %1 %2)"
syntax logic (*) "(* %1 %2)"
syntax logic (-_) "(- %1)"
syntax logic (<=) "(<= %1 %2)"
syntax logic (<) "(< %1 %2)"
syntax logic (>=) "(>= %1 %2)"
syntax logic (>) "(> %1 %2)"
remove prop CommutativeGroup.Comm.Comm
remove prop CommutativeGroup.Assoc.Assoc
remove prop CommutativeGroup.Unit_def
remove prop CommutativeGroup.Inv_def
remove prop Assoc.Assoc
remove prop Mul_distr
remove prop Comm.Comm
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Antisymm
remove prop Total
remove prop NonTrivialRing
remove prop CompatOrderAdd
meta "encoding : kept" type int
theory real.Real
prelude ";;; this is a prelude for Z3 real arithmetic"
syntax logic zero "0.0"
syntax logic one "1.0"
syntax logic (/) "(/ %1 %2)"
syntax logic inv "(/ 1.0 %1)"
remove prop Inverse
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Total
meta "encoding : kept" type real
(* L'encodage des types sommes bloquent cette théorie builtin *)
theory bool.Bool
syntax type bool "bool"
syntax logic True "true"
syntax logic False "false"
syntax logic andb "(and %1 %2)"
syntax logic orb "(or %1 %2)"
syntax logic xorb "(xor %1 %2)"
syntax logic notb "(not %1)"
meta cloned "encoding_decorate : kept" type bool
theory int.EuclideanDivision
syntax logic div "(div %1 %2)"
syntax logic mod "(mod %1 %2)"
remove prop Mod_bound
remove prop Div_mod
remove prop Mod_1
remove prop Div_1
theory real.FromInt
syntax logic from_int "(from_int %1)"
remove prop Add
remove prop Sub
remove prop Mul
remove prop Neg
theory real.Truncate
syntax logic floor "(to_int %1)"
remove prop Floor_down
remove prop Floor_monotonic
theory array.Array
syntax type t "(Array %1 %2)"
meta "encoding : lskept" logic get
meta "encoding : lskept" logic set
meta "encoding : lskept" logic create_const
meta "smt_dist_syntax" logic get, "(select %1 %2)"
meta "smt_dist_syntax" logic set, "(store %1 %2 %3)"
meta "smt_dist_syntax" logic create_const, "(const[%t0] %1)"
Local Variables:
mode: why
compile-command: "unset LANG; make -C .. bench"
End:
(* Copyright (C) 2010- *)
(* François Bobot *)
(* Jean-Christophe Filliâtre *)
(* Claude Marché *)
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
val lsymbol_distinction : Task.task Trans.trans
val phase0 : Task.task Trans.trans
(* Copyright (C) 2010- *) (* Copyright (C) 2010- *)
(* François Bobot *) (* François Bobot *)
(* Jean-Christophe Filliâtre *) (* Jean-Christophe Filliâtre *)
(* Claude Marché *) (* Claude Marché *)
(* Andrei Paskevich *) (* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *) (* This software is free software; you can redistribute it and/or *)
...@@ -184,6 +184,7 @@ let inst_nothing _env = Trans.identity ...@@ -184,6 +184,7 @@ let inst_nothing _env = Trans.identity
(** goal *) (** goal *)
let inst_goal _env = let inst_goal _env =
Trans.compose (inst_nothing _env) $
Trans.tgoal (fun pr f -> Trans.tgoal (fun pr f ->
let env = f_app_fold add_mono_instantiation Mls.empty f in let env = f_app_fold add_mono_instantiation Mls.empty f in
metas_of_env env [create_decl (create_prop_decl Pgoal pr f)]) metas_of_env env [create_decl (create_prop_decl Pgoal pr f)])
...@@ -191,6 +192,7 @@ let inst_goal _env = ...@@ -191,6 +192,7 @@ let inst_goal _env =
(** goal + context *) (** goal + context *)
let inst_all _env = let inst_all _env =
Trans.bind (Trans.fold fold_add_instantion Mls.empty) Trans.bind (Trans.fold fold_add_instantion Mls.empty)
(fun env -> Trans.add_tdecls (metas_of_env env [])) (fun env -> Trans.add_tdecls (metas_of_env env []))
