Commit de3ea1e9 authored by Ryan Herbert's avatar Ryan Herbert
dev.org debugging info for nightmarejs
see vidjil/vdj#474
parent c689f1ac
...@@ -305,6 +305,17 @@ The cache is stored for each user and is updated only when a change occurs (mess ...@@ -305,6 +305,17 @@ The cache is stored for each user and is updated only when a change occurs (mess
Note that using =nightmare= for our unit testing Note that using =nightmare= for our unit testing
requires the installation of =xvfb=. requires the installation of =xvfb=.
**** Debugging
If there is a problem with the nightmare or electron (nightmare
dependency), you may encounter a lack of output or error messages.
To address this issue, run:
#+BEGIN_SRC sh
cd browser/test/QUnit
DEBUG=nightmare*,electron:* node nightmare.js
#+END_SRC
*** Functional *** Functional
**** Architecture **** Architecture
