Commit 6fd2fe69 authored by Mathieu Giraud's avatar Mathieu Giraud
doc/algo.org: update help on e-value
parent f18ca797
...@@ -180,12 +180,12 @@ few more reads, but may in some rare cases falsely cluster reads from ...@@ -180,12 +180,12 @@ few more reads, but may in some rare cases falsely cluster reads from
different clones. Setting =-w= to lower values is not recommended. different clones. Setting =-w= to lower values is not recommended.
The =-e= option sets the maximal e-value accepted for segmenting a sequence. The =-e= option sets the maximal e-value accepted for segmenting a sequence.
If a segmentation has a higher e-value, it will not be segmented. It is an upper bound on the number of exepcted windows found by chance by the seed-based heuristic.
The e-value computation takes into account both the number of reads in the The e-value computation takes into account both the number of reads in the
input sequence and the number of locus searched for. input sequence and the number of locus searched for.
The default value is 'all', but the recommended value is to use something The default value is 1.0, but values such as 1000, 1e-3 or even less can be used
like 1, 1e-2 or 1. to have a more or less permissive segmentation.
Further help on this point will come in next releases. The threshold can be disabled with =-e all=.
** Threshold on clone output ** Threshold on clone output
