Commit 1c7e9d80 authored by Mathieu Giraud's avatar Mathieu Giraud
tests/testRepresentative.cpp: update unit tests
parent 176dd42f
...@@ -15,26 +15,26 @@ void testRepresentative() { ...@@ -15,26 +15,26 @@ void testRepresentative() {
Sequence representative = krc.getRepresentative(); Sequence representative = krc.getRepresentative();
// Seq3 is the longest it should be taken when performing 0 extra iteration // Seq3 is the longest it should be taken when performing 0 extra iteration
TAP_TEST(representative.label.find("seq3-[37,73]") == 0, TEST_KMER_REPRESENTATIVE, TAP_TEST(representative.label.find("representative--seq3-[37,73]") == 0, TEST_KMER_REPRESENTATIVE,
"If we take the first representative we should have seq3, and not at the beginning (" << representative.label << " instead)"); "If we take the first representative we should have seq3, and not at the beginning (" << representative.label << " instead)");
krc.setStabilityLimit(1); krc.setStabilityLimit(1);
krc.compute(); krc.compute();
representative = krc.getRepresentative(); representative = krc.getRepresentative();
"When allowing one step before stability, we should still have seq3 (" << representative.label << " instead)"); "When allowing one step before stability, we should still have seq3 (" << representative.label << " instead)");
krc.setStabilityLimit(2); krc.setStabilityLimit(2);
TAP_TEST(representative.label.find("seq1-[0,41]") == 0, TEST_KMER_REPRESENTATIVE, TAP_TEST(representative.label.find("representative--seq1-[0,41]") == 0, TEST_KMER_REPRESENTATIVE,
"When allowing two steps before stability, we should reach seq1 (" << representative.label << " instead)"); "When allowing two steps before stability, we should reach seq1 (" << representative.label << " instead)");
krc.setRevcomp(true); krc.setRevcomp(true);
krc.setRequiredSequence("ATCGCGCCCT"); // revcomp krc.setRequiredSequence("ATCGCGCCCT"); // revcomp
TAP_TEST(representative.label.find("seq2-[33,52]") == 0, TEST_KMER_REPRESENTATIVE_REQUIRED_SEQ, TAP_TEST(representative.label.find("representative--seq2-[33,52]") == 0, TEST_KMER_REPRESENTATIVE_REQUIRED_SEQ,
"When requiring sequence ATCGCGCCCT, we should have seq2 (" << representative.label << " instead)"); "When requiring sequence ATCGCGCCCT, we should have seq2 (" << representative.label << " instead)");
krc.setRevcomp(false); krc.setRevcomp(false);
