Commit 161ae156 authored by Ryan Herbert's avatar Ryan Herbert
Dockerfile update keyserver
keyserver was still set to the old rby server, now it correctly point to
an sks installation on vda.
parent 85229d9f
...@@ -35,7 +35,7 @@ run echo "vidjil-server vidjil/ssl-name string VidjilTeam" >> preseed.txt ...@@ -35,7 +35,7 @@ run echo "vidjil-server vidjil/ssl-name string VidjilTeam" >> preseed.txt
run echo "vidjil-server vidjil/ssl-email string team@vidjil.org" >> preseed.txt run echo "vidjil-server vidjil/ssl-email string team@vidjil.org" >> preseed.txt
run debconf-set-selections preseed.txt run debconf-set-selections preseed.txt
run gpg --recv-keys --keyserver rby.vidjil.org 9187987418E1A625 run gpg --recv-keys --keyserver vda.vidjil.org 8EA70E25
run apt-get update ; apt-get install --no-install-recommends --no-install-suggests -y -q sudo curl apt-utils uwsgi-plugin-python nginx-full fcgiwrap run apt-get update ; apt-get install --no-install-recommends --no-install-suggests -y -q sudo curl apt-utils uwsgi-plugin-python nginx-full fcgiwrap
run apt-get update ; DEBIAN_FRONTEND=noninteractive apt-get -y -q --allow-unauthenticated install vidjil-archive-keyring run apt-get update ; DEBIAN_FRONTEND=noninteractive apt-get -y -q --allow-unauthenticated install vidjil-archive-keyring
run apt-get update ; DEBIAN_FRONTEND=noninteractive apt-get install --no-install-recommends --no-install-suggests -y -q --allow-unauthenticated vidjil-server run apt-get update ; DEBIAN_FRONTEND=noninteractive apt-get install --no-install-recommends --no-install-suggests -y -q --allow-unauthenticated vidjil-server
