Commit fb8e8fd2 authored by HERBERT Ryan's avatar HERBERT Ryan
default.py multi-sample runs in progress
Fixed a bug where attempting to view a multi-sample run would crash if
other files were currently running
parent 2b978a04
...@@ -258,28 +258,6 @@ def get_data(): ...@@ -258,28 +258,6 @@ def get_data():
data["run_id"] = row.id data["run_id"] = row.id
data["run_name"] = run_name data["run_name"] = run_name
data["sample_set_id"] = sample_set.id
data["config_name"] = config_name
data["samples"]["info"] = []
data["samples"]["timestamp"] = []
data["samples"]["sequence_file_id"] = []
data["samples"]["results_file_id"] = []
data["samples"]["config_id"] = []
data["samples"]["names"] = []
data["samples"]["db_key"] = []
data["samples"]["ids"] = []
for i in range(len(data["samples"]["original_names"])) :
data["samples"]["original_names"][i] = data["samples"]["original_names"][i].split('/')[-1]
data["samples"]["info"].append('')
data["samples"]["timestamp"].append('')
data["samples"]["sequence_file_id"].append('')
data["samples"]["results_file_id"].append('')
data["samples"]["config_id"].append('')
data["samples"]["names"].append('')
data["samples"]["db_key"].append('')
data["samples"]["ids"].append('')
## récupération des infos stockées sur la base de données ## récupération des infos stockées sur la base de données
query = db( ( db.sample_set.id == request.vars["sample_set_id"] ) query = db( ( db.sample_set.id == request.vars["sample_set_id"] )
& ( db.sample_set.id == db.sample_set_membership.sample_set_id ) & ( db.sample_set.id == db.sample_set_membership.sample_set_id )
...@@ -295,18 +273,30 @@ def get_data(): ...@@ -295,18 +273,30 @@ def get_data():
query2.append(row) query2.append(row)
sequence_file_id = row.sequence_file.id sequence_file_id = row.sequence_file.id
i=0 data["sample_set_id"] = sample_set.id
for row in query2 :
data["samples"]["timestamp"][i] = str(row.sequence_file.sampling_date) data["config_name"] = config_name
data["samples"]["info"][i] = row.sequence_file.info data["samples"]["info"] = []
data["samples"]["commandline"][i] = command data["samples"]["timestamp"] = []
data["samples"]["sequence_file_id"][i] = row.sequence_file.id data["samples"]["sequence_file_id"] = []
data["samples"]["results_file_id"][i] = row.results_file.id data["samples"]["results_file_id"] = []
data["samples"]["config_id"][i] = request.vars["config"] data["samples"]["config_id"] = []
data["samples"]["names"][i] = row.sequence_file.filename.split('.')[0] data["samples"]["names"] = []
data["samples"]["ids"][i] = row.sequence_file.id data["samples"]["db_key"] = []
i+=1 data["samples"]["ids"] = []
row = query2[i]
data["samples"]["info"].append(row.sequence_file.info)
data["samples"]["timestamp"].append(str(row.sequence_file.sampling_date))
data["samples"]["sequence_file_id"].append(row.sequence_file.id)
data["samples"]["results_file_id"].append(row.results_file.id)
data["samples"]["config_id"].append(request.vars['config'])
data["samples"]["names"].append(row.sequence_file.filename.split('.')[0])
data["samples"]["ids"].append(row.sequence_file.id)
data["samples"]["commandline"].append(command)
log.debug("get_data (%s) c%s -> %s" % (request.vars["sample_set_id"], request.vars["config"], fused_file)) log.debug("get_data (%s) c%s -> %s" % (request.vars["sample_set_id"], request.vars["config"], fused_file))
return gluon.contrib.simplejson.dumps(data, separators=(',',':')) return gluon.contrib.simplejson.dumps(data, separators=(',',':'))
