Commit f8f89bb6 authored by Mathieu Giraud's avatar Mathieu Giraud
tests/should-to-tap.sh: ensure that the exit code is 0
parent 12bcb3cc
...@@ -70,6 +70,7 @@ cd "$DIR" ...@@ -70,6 +70,7 @@ cd "$DIR"
OUTPUT_DIR=. OUTPUT_DIR=.
TAP_FILE=${BASE%.*}.tap TAP_FILE=${BASE%.*}.tap
LOG_FILE=${BASE%.*}.log LOG_FILE=${BASE%.*}.log
EXIT_CODE=
OUTPUT_FILE= OUTPUT_FILE=
FILE_TO_GREP= FILE_TO_GREP=
NO_LAUNCHER= NO_LAUNCHER=
...@@ -83,6 +84,7 @@ TMP_TAP_FILE=$(mktemp tap.XXXX) ...@@ -83,6 +84,7 @@ TMP_TAP_FILE=$(mktemp tap.XXXX)
nb_tests=0 nb_tests=0
# Count number of tests to be performed # Count number of tests to be performed
nb_tests=`grep -Ec '^[^$#!]' $BASE` nb_tests=`grep -Ec '^[^$#!]' $BASE`
nb_tests=$((nb_tests+1))
echo "1.."$nb_tests echo "1.."$nb_tests
test_nb=1 test_nb=1
...@@ -135,9 +137,11 @@ while read line; do ...@@ -135,9 +137,11 @@ while read line; do
echo "Launching '$cmd'" >&2 echo "Launching '$cmd'" >&2
if [ -z "$OUTPUT_FILE" ]; then if [ -z "$OUTPUT_FILE" ]; then
eval $cmd > $LOG_FILE eval $cmd > $LOG_FILE
EXIT_CODE=$?
FILE_TO_GREP=$LOG_FILE FILE_TO_GREP=$LOG_FILE
else else
eval $cmd > /dev/null eval $cmd > /dev/null
EXIT_CODE=$?
FILE_TO_GREP=$OUTPUT_FILE FILE_TO_GREP=$OUTPUT_FILE
fi fi
launched=1 launched=1
...@@ -211,7 +215,23 @@ while read line; do ...@@ -211,7 +215,23 @@ while read line; do
fi fi
fi fi
line_nb=$((line_nb+1)) line_nb=$((line_nb+1))
done < $BASE done < $BASE
# Check exit code
if [ $EXIT_CODE -eq 0 ]; then
echo "ok $test_nb - Exit code 0"
else
echo "not ok $test_nb - Exit code $EXIT_CODE"
error=1
echo >&2; echo >&2; echo $SEPARATOR_LINE >&2
echo "error: exit code $EXIT_CODE" >&2
cat $FILE_TO_GREP >&2
echo $SEPARATOR_LINE >&2; echo >&2; echo >&2
fi
} > $TMP_TAP_FILE } > $TMP_TAP_FILE
mv $TMP_TAP_FILE $TAP_FILE mv $TMP_TAP_FILE $TAP_FILE
