Commit f6b40975 authored by RyanHerb's avatar RyanHerb
docker/vidjil/Dockerfile generic repo address
The repository address was set to a server-specific address. This one
should always point to the correct server
parent 193a8769
...@@ -16,10 +16,10 @@ run set -x \ ...@@ -16,10 +16,10 @@ run set -x \
&& chmod +x /usr/local/bin/gosu \ && chmod +x /usr/local/bin/gosu \
&& apt-get purge -y --auto-remove ca-certificates wget && apt-get purge -y --auto-remove ca-certificates wget
run echo deb http://rby.vidjil.org:8080/archive sid/all/ >> /etc/apt/sources.list run echo deb http://app.vidjil.org:8080/archive sid/all/ >> /etc/apt/sources.list
run echo deb http://rby.vidjil.org:8080/archive sid/amd64/ >> /etc/apt/sources.list run echo deb http://app.vidjil.org:8080/archive sid/amd64/ >> /etc/apt/sources.list
run echo deb http://rby.vidjil.org:8080/archive wheezy/all/ >> /etc/apt/sources.list run echo deb http://app.vidjil.org:8080/archive wheezy/all/ >> /etc/apt/sources.list
run echo deb http://rby.vidjil.org:8080/archive wheezy/amd64/ >> /etc/apt/sources.list run echo deb http://app.vidjil.org:8080/archive wheezy/amd64/ >> /etc/apt/sources.list
run echo "vidjil-server vidjil/reconfigure-webserver string nginx" > preseed.txt run echo "vidjil-server vidjil/reconfigure-webserver string nginx" > preseed.txt
run echo "vidjil-server vidjil/restart-webserver boolean false" >> preseed.txt run echo "vidjil-server vidjil/restart-webserver boolean false" >> preseed.txt
