Commit f26e9d0b authored by Mikaël Salson's avatar Mikaël Salson
Makefile: Include algo/lib/ in release
parent 41314ce0
...@@ -78,8 +78,8 @@ cleanall: clean ...@@ -78,8 +78,8 @@ cleanall: clean
RELEASE_TAG="notag" RELEASE_TAG="notag"
RELEASE_H = $(VIDJIL_ALGO_SRC)/release.h RELEASE_H = $(VIDJIL_ALGO_SRC)/release.h
RELEASE_SOURCE = $(wildcard $(VIDJIL_ALGO_SRC)/*.cpp) $(wildcard $(VIDJIL_ALGO_SRC)/*.h) $(wildcard $(VIDJIL_ALGO_SRC)/core/*.cpp) $(wildcard $(VIDJIL_ALGO_SRC)/tests/*.cpp) $(wildcard $(VIDJIL_ALGO_SRC)/core/*.h) $(wildcard $(VIDJIL_ALGO_SRC)/tests/*.h) $(wildcard $(VIDJIL_ALGO_SRC)/cgi/*.cpp) RELEASE_SOURCE = $(wildcard $(VIDJIL_ALGO_SRC)/*.cpp) $(wildcard $(VIDJIL_ALGO_SRC)/*.h) $(wildcard $(VIDJIL_ALGO_SRC)/core/*.cpp) $(wildcard $(VIDJIL_ALGO_SRC)/tests/*.cpp) $(wildcard $(VIDJIL_ALGO_SRC)/core/*.h) $(wildcard $(VIDJIL_ALGO_SRC)/tests/*.h) $(wildcard $(VIDJIL_ALGO_SRC)/cgi/*.cpp) $(wildcard $(VIDJIL_ALGO_SRC)/lib/*.cpp) $(wildcard $(VIDJIL_ALGO_SRC)/lib/*.h)
RELEASE_MAKE = ./Makefile $(VIDJIL_ALGO_SRC)/Makefile $(VIDJIL_ALGO_SRC)/core/Makefile $(VIDJIL_ALGO_SRC)/tests/Makefile germline/Makefile data/Makefile RELEASE_MAKE = ./Makefile $(VIDJIL_ALGO_SRC)/Makefile $(VIDJIL_ALGO_SRC)/core/Makefile $(VIDJIL_ALGO_SRC)/tests/Makefile $(VIDJIL_ALGO_SRC)/lib/Makefile germline/Makefile data/Makefile
RELEASE_TESTS = data/get-sequences $(wildcard data/*.fa) $(wildcard data/*.fq) $(VIDJIL_ALGO_SRC)/tests/should-to-tap.sh $(wildcard $(VIDJIL_ALGO_SRC)/tests/*.should_get) $(wildcard $(VIDJIL_ALGO_SRC)/tests/bugs/*.fa) $(wildcard $(VIDJIL_ALGO_SRC)/tests/bugs/*.should_get) $(VIDJIL_ALGO_SRC)/tests/format-json.sh RELEASE_TESTS = data/get-sequences $(wildcard data/*.fa) $(wildcard data/*.fq) $(VIDJIL_ALGO_SRC)/tests/should-to-tap.sh $(wildcard $(VIDJIL_ALGO_SRC)/tests/*.should_get) $(wildcard $(VIDJIL_ALGO_SRC)/tests/bugs/*.fa) $(wildcard $(VIDJIL_ALGO_SRC)/tests/bugs/*.should_get) $(VIDJIL_ALGO_SRC)/tests/format-json.sh
RELEASE_FILES = $(RELEASE_SOURCE) $(RELEASE_TESTS) $(RELEASE_MAKE) germline/get-germline germline/split-from-imgt.py doc/algo.org doc/LICENSE data/segmentation.fasta RELEASE_FILES = $(RELEASE_SOURCE) $(RELEASE_TESTS) $(RELEASE_MAKE) germline/get-germline germline/split-from-imgt.py doc/algo.org doc/LICENSE data/segmentation.fasta
RELEASE_ARCHIVE = vidjil-$(RELEASE_TAG).tgz RELEASE_ARCHIVE = vidjil-$(RELEASE_TAG).tgz
Supports Markdown
