Commit f21d372a authored by Mathieu Giraud's avatar Mathieu Giraud
core/cluster-junctions.{cpp,h}: remove neato graph output
This feature was seldom used.
Now we have the browser: It could show a distance graph in a next future.
parent 1e6b2b92
...@@ -321,16 +321,8 @@ list<list<junction> > comp_matrix::nocluster() ...@@ -321,16 +321,8 @@ list<list<junction> > comp_matrix::nocluster()
return cluster; return cluster;
void comp_matrix::stat_cluster( list<list<junction> > cluster, string neato_file, ostream &out ) void comp_matrix::stat_cluster( list<list<junction> > cluster, ostream &out )
ofstream f_graph;
f_graph.open((neato_file + ".dot").c_str());
f_graph << "graph pairs {" << endl ;
f_graph << " ratio = 1.618 " << endl ;
f_graph << " node [shape=box,colorscheme=pastel19,style=filled]" << endl ;
f_graph << " graph [overlap=true]" << endl ;
int n_cluster=0; //nombre de cluster int n_cluster=0; //nombre de cluster
int n_100cluster=0; //nombre de cluster de taille superieur a 100 int n_100cluster=0; //nombre de cluster de taille superieur a 100
int max_size=0; //taille du plus gros cluster int max_size=0; //taille du plus gros cluster
...@@ -340,7 +332,6 @@ void comp_matrix::stat_cluster( list<list<junction> > cluster, string neato_file ...@@ -340,7 +332,6 @@ void comp_matrix::stat_cluster( list<list<junction> > cluster, string neato_file
float jc2=0; //nombre de junction clusterisé(%) float jc2=0; //nombre de junction clusterisé(%)
float moy=0; //taille moyenne des clusters float moy=0; //taille moyenne des clusters
int color=0;
//recherche du plus gros cluster //recherche du plus gros cluster
for (list <list <string> >::iterator it = cluster.begin(); for (list <list <string> >::iterator it = cluster.begin();
it != cluster.end(); ++it ) it != cluster.end(); ++it )
...@@ -361,42 +352,11 @@ void comp_matrix::stat_cluster( list<list<junction> > cluster, string neato_file ...@@ -361,42 +352,11 @@ void comp_matrix::stat_cluster( list<list<junction> > cluster, string neato_file
if (size> max_size) max_size=size; if (size> max_size) max_size=size;
if (size>=100) { if (size>=100) {
color++;
n_100cluster++; n_100cluster++;
//boucle neato
string j1,j2;
int n=0;
for (list<string>::iterator it2 = li.begin();
it2 != li.end() ; ++it2 )
n++;
if (n<=16){
j1=*it2;
if (it2 != li.begin())
f_graph << " " <<"n"<<count[j2]<<"_"<<j2<< " -- " <<"n"<<count[j1]<<"_"<<j1<< " [style=dashed,color=red]" << endl ;
f_graph << " " <<"n"<<count[j1]<<"_"<<j1<< " [fillcolor=" << 1+(color%9) << "]" << endl ;
j2=j1;
f_graph << "}" << endl ;
f_graph.close();
string com = "neato "+neato_file+".dot -Tpdf -o "+neato_file+".pdf" ; // TODO: use out_dir + GRAPH_FILE
out << " " << com << endl ;
if (system(com.c_str()) == -1) {
perror("Launching neato");
exit(4);
if(n_j2c!=0) if(n_j2c!=0)
moy=n_j2c/n_cluster; moy=n_j2c/n_cluster;
...@@ -66,7 +66,7 @@ class comp_matrix { ...@@ -66,7 +66,7 @@ class comp_matrix {
void del(); void del();
void stat_cluster( list<list<junction> > cluster, string neato_file, ostream &out=cout); void stat_cluster( list<list<junction> > cluster, ostream &out=cout);
private: private:
...@@ -89,7 +89,6 @@ enum { CMD_WINDOWS, CMD_ANALYSIS, CMD_SEGMENT, CMD_GERMLINES } ; ...@@ -89,7 +89,6 @@ enum { CMD_WINDOWS, CMD_ANALYSIS, CMD_SEGMENT, CMD_GERMLINES } ;
#define UNSEGMENTED_FILENAME "unsegmented.fa" #define UNSEGMENTED_FILENAME "unsegmented.fa"
#define EDGES_FILENAME "edges" #define EDGES_FILENAME "edges"
#define COMP_FILENAME "comp.data" #define COMP_FILENAME "comp.data"
#define GRAPH_FILENAME "graph"
#define JSON_SUFFIX ".data" #define JSON_SUFFIX ".data"
// "tests/data/leukemia.fa" // "tests/data/leukemia.fa"
...@@ -929,7 +928,7 @@ int main (int argc, char **argv) ...@@ -929,7 +928,7 @@ int main (int argc, char **argv)
clones_windows = comp.cluster(forced_edges, w, cout, epsilon, minPts) ; clones_windows = comp.cluster(forced_edges, w, cout, epsilon, minPts) ;
comp.stat_cluster(clones_windows, out_dir + prefix_filename + GRAPH_FILENAME, cout ); comp.stat_cluster(clones_windows, cout );
comp.del(); comp.del();
else else
