Commit ee304088 authored by Mathieu Giraud's avatar Mathieu Giraud
functional/browser_test.rb: debug, print data and analyis file
parent e9d45017
...@@ -82,10 +82,12 @@ class BrowserTest < MiniTest::Test ...@@ -82,10 +82,12 @@ class BrowserTest < MiniTest::Test
$b.div(:id => 'demo_file_menu').a(:id => 'import_data_anchor').click $b.div(:id => 'demo_file_menu').a(:id => 'import_data_anchor').click
# select data file # select data file
print " data: " + data_path + "\n"
$b.div(:id => 'file_menu').file_field(:name,"json").set(data_path) $b.div(:id => 'file_menu').file_field(:name,"json").set(data_path)
# select analysis file # select analysis file
if analysis_path != nil if analysis_path != nil
print " analysis: " + analysis_path + "\n"
$b.div(:id => 'file_menu').file_field(:name, "pref").set(analysis_path) $b.div(:id => 'file_menu').file_field(:name, "pref").set(analysis_path)
end end
