Commit e62baa46 authored by Mathieu Giraud's avatar Mathieu Giraud
index.html: remove an old entry in the menu
Closes #2840.
parent 7f1e4dbc
Pipeline #11118 passed with stages
in 14 seconds
...@@ -181,11 +181,6 @@ ...@@ -181,11 +181,6 @@
<span id="top_label"></span></br> <span id="top_label"></span></br>
<input id="top_slider" type="range" min="5" max="100" step="5" value="10" onchange="m.displayTop(this.value)" /> <input id="top_slider" type="range" min="5" max="100" step="5" value="10" onchange="m.displayTop(this.value)" />
</div> </div>
<div class="menu_box">
tag visibility</br>
<ul id="tagList">
</ul>
</div>
</div></div> </div></div>
</div> </div>
