Commit e3d2c1fe authored by Marc Duez's avatar Marc Duez
parents 9015e0ac fada90bd
...@@ -37,6 +37,7 @@ from operator import itemgetter ...@@ -37,6 +37,7 @@ from operator import itemgetter
VIDJIL_JSON_VERSION = "2014.10" VIDJIL_JSON_VERSION = "2014.10"
FUSE_VERSION = "vidjil fuse"
GERMLINES_ORDER = ['TRA', 'TRB', 'TRG', 'TRD', 'DD', 'IGH', 'DHJH', 'IJK', 'IJL'] GERMLINES_ORDER = ['TRA', 'TRB', 'TRG', 'TRD', 'DD', 'IGH', 'DHJH', 'IJK', 'IJL']
...@@ -288,6 +289,10 @@ class ListWindows: ...@@ -288,6 +289,10 @@ class ListWindows:
self.d["clusters"] = [] self.d["clusters"] = []
self.d["germlines"] = {} self.d["germlines"] = {}
self.d["vidjil_json_version"] = VIDJIL_JSON_VERSION
self.d["producer"] = FUSE_VERSION
self.d["timestamp"] = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
def __str__(self): def __str__(self):
return "<ListWindows: %s %d>" % ( self.d["reads"].d["segmented"], len(self) ) return "<ListWindows: %s %d>" % ( self.d["reads"].d["segmented"], len(self) )
...@@ -376,7 +381,7 @@ class ListWindows: ...@@ -376,7 +381,7 @@ class ListWindows:
print print
time = os.path.getmtime(file_path) time = os.path.getmtime(file_path)
self.d["timestamp"] = [datetime.datetime.fromtimestamp(time).strftime("%Y-%m-%d %H:%M:%S")] self.d["samples"].d["timestamp"] = [datetime.datetime.fromtimestamp(time).strftime("%Y-%m-%d %H:%M:%S")]
def getTop(self, top): def getTop(self, top):
result = [] result = []
...@@ -417,8 +422,6 @@ class ListWindows: ...@@ -417,8 +422,6 @@ class ListWindows:
obj.d["clones"]=self.fuseWindows(self.d["clones"], other.d["clones"], l1, l2) obj.d["clones"]=self.fuseWindows(self.d["clones"], other.d["clones"], l1, l2)
obj.d["samples"] = self.d["samples"] + other.d["samples"] obj.d["samples"] = self.d["samples"] + other.d["samples"]
obj.d["reads"] = self.d["reads"] + other.d["reads"] obj.d["reads"] = self.d["reads"] + other.d["reads"]
obj.d["timestamp"] = self.d["timestamp"]
obj.d["vidjil_json_version"] = [VIDJIL_JSON_VERSION]
obj.d["germlines"] = dict(self.d["germlines"].items() + other.d["germlines"].items()) obj.d["germlines"] = dict(self.d["germlines"].items() + other.d["germlines"].items())
return obj return obj
...@@ -501,6 +504,7 @@ class ListWindows: ...@@ -501,6 +504,7 @@ class ListWindows:
self.d["vidjil_json_version"] = [VIDJIL_JSON_VERSION] self.d["vidjil_json_version"] = [VIDJIL_JSON_VERSION]
self.d["samples"].d["original_names"] = [file_path] self.d["samples"].d["original_names"] = [file_path]
self.d["samples"].d["producer"] = ["EC-NGS central pipeline"]
listw = [] listw = []
listc = [] listc = []
...@@ -542,7 +546,6 @@ class ListWindows: ...@@ -542,7 +546,6 @@ class ListWindows:
else: else:
w.d["seg"]["3start"] = 0 w.d["seg"]["3start"] = 0
w.d["seg"]["5end"] = len(w.d["sequence"]) w.d["seg"]["5end"] = len(w.d["sequence"])
w.d["name"]=w.d["seg"]["5"] + " -x/y/-z " + w.d["seg"]["3"]
w.d["seg"]["3end"]=0 w.d["seg"]["3end"]=0
w.d["seg"]["5start"]=0 w.d["seg"]["5start"]=0
w.d["seg"]["4end"]=0 w.d["seg"]["4end"]=0
...@@ -552,6 +555,8 @@ class ListWindows: ...@@ -552,6 +555,8 @@ class ListWindows:
listw.append((w , w.d["reads"][0])) listw.append((w , w.d["reads"][0]))
raw_clonotype = tab.get("clonotype") raw_clonotype = tab.get("clonotype")
w.d["name"]=raw_clonotype # w.d["seg"]["5"] + " -x/y/-z " + w.d["seg"]["3"]
clonotype = raw_clonotype.split(' ') clonotype = raw_clonotype.split(' ')
if (len(clonotype) > 1) : if (len(clonotype) > 1) :
listc.append((w, raw_clonotype)) listc.append((w, raw_clonotype))
...@@ -761,7 +766,7 @@ w6.d ={"id" : "bbb", "reads" : [12], "top" : 2 } ...@@ -761,7 +766,7 @@ w6.d ={"id" : "bbb", "reads" : [12], "top" : 2 }
lw1 = ListWindows() lw1 = ListWindows()
lw1.d["timestamp"] = 'ts' lw1.d["timestamp"] = 'ts'
lw1.d["reads"] = json.loads('{"total": [30], "segmented": [25] }', object_hook=lw1.toPython) lw1.d["reads"] = json.loads('{"total": [30], "segmented": [25], "germline": {} }', object_hook=lw1.toPython)
lw1.d["clones"].append(w5) lw1.d["clones"].append(w5)
lw1.d["clones"].append(w6) lw1.d["clones"].append(w6)
...@@ -772,7 +777,7 @@ w8.d ={"id" : "ccc", "reads" : [2], "top" : 8, "test" : ["plop"] } ...@@ -772,7 +777,7 @@ w8.d ={"id" : "ccc", "reads" : [2], "top" : 8, "test" : ["plop"] }
lw2 = ListWindows() lw2 = ListWindows()
lw2.d["timestamp"] = 'ts' lw2.d["timestamp"] = 'ts'
lw2.d["reads"] = json.loads('{"total": [40], "segmented": [34] }', object_hook=lw1.toPython) lw2.d["reads"] = json.loads('{"total": [40], "segmented": [34], "germline": {} }', object_hook=lw1.toPython)
lw2.d["clones"].append(w7) lw2.d["clones"].append(w7)
lw2.d["clones"].append(w8) lw2.d["clones"].append(w8)
